Question about Adidas Digital Chronograph Black Strap Square ADP6011 Watch for Women
How to change de time - Adidas Digital Chronograph Black Strap Square ADP6011 Watch for Women
Push the SET/LIGHT and LAP/RESET button simultaneously.. push MODE button to go to time setting option.........chill
Posted on Aug 19, 2013
Eve mon crois watch 9441-FS instruktionbook
Watch controls (eve mon crois) TL= top left button TR= top right button BL= bottom left button BR= bottom right button TL= toggle light TR= view date BR= view alarm time BL= toggle options 1 press --> stopwatch 2 press --> change alarm time 3 press --> change digital time 4 press --> return to regular view (When on option) Stopwatch: TR= stop/start stopwatch BR= reset stopwatch time BL= next option Change alarm time: TR= +1 to selected (flashing) unit BR= change selected (flashing) unit BL= next option Change digital time: TR= +1 to selected (flashing) unit BR= change selected (flashing) unit BL= next option Normal view: (controls shown at top) In normal view when: TR is held down --> BR= toggle alarm on/off TL is held down --> BL= toggle through days BR is held down --> TR= toggle alarm on/off (for accurate digital time go to the option of change digital time and set it to the next minute from when you are make sure that the the counting seconds are flashing. When the next minute comes press TR this will reset the seconds to '00' without changing the minute and you will now be accurate to the clock you used by less than a second) I got this info through a long time of just experimenting with the buttons, still working on finding a way of changing the date but for now this should be enough to get you by with the watch. Hope this helps somebody :)
Jan 30, 2014 | Watches
Tip
How to set your Global Atomic G-Force digital watch
This watch says "Strong Ideas" on the back instead of a 4 digit number.
Press LIGHT briefly and your LCD will be back lit for 5 seconds.
Press MODE to cycle through normal, alarm, dual time, and stopwatch display mode.
Hold MODE for 3 seconds to enable the radio to receive time signals. Once RC is activated, the watch will search for time signal automatically every day.
Hold LIGHT for 8 seconds to disable the RC function.
Press MODE, SET, and ADJUST simultaneously to reset the watch.
Press ADJUST while in normal mode to toggle year/time display.
Press SET while in year display to alternate Month-Day or Day-Month.
Hold SET for 2 seconds while in normal mode to cycle through world atomic radios (US/GB/DE/JP) push ADJUST to change, and SET to continue. Next the language will flash (GB/FR/DE/ES/IT). Next is DST on/off. Next, in order are hour, minute, second, year, month, day, and 12/24 Hr format.
(US only) Press SET to display timezone. The default is PA, use the ADJUST button to cycle through MO, CE, or EA as desired.
Press SET while in alarm mode to toggle alarm on/off.
Hold SET for 2 seconds while in alarm mode to change the hour and minute with the ADJUST button.
Press SET for 2 seconds while in dual time mode and ADJUST +/- 23 hours from normal time.
Press MODE to exit most settings.
Press ADJUST in stopwatch mode to start/stop the timer accumulatively.
Press SET to reset stopwatch to zero, or split measurements if timer is running.
Change the battery with a new CR2025 to prevent damage that low or dead batteries can cause by leaking.
Do not use solvents to clean the watch, use only a dry or water moistened cloth.
Do not use buttons when the watch is wet. Water may penetrate the watch and cause damage to it.
on Dec 31, 2011 | Watches
Torgoen - T27105 n'est marche pas,je vient juste de l'acheter mais il marche pas
Lis les instructions de mise en marche de la montre. Lis aussi la section en cas de probl`eme. Si elle refuse de se mettre en marche, retourne au magasin et demande un remboursement. La prochaine fois que tu veux acheter une montre demande au marchand de v'erifier le bon 'etat de marche.
Jan 28, 2014 | Torgoen T27105 T27 Pilot Watch
I dont now how i can change de week date
Unscrew the crown,let it pop out by gently turning it towards you , anticlockwise....gently pull the crown out to the first stop and turn the crown......day one way and the date the opposite way. The time is set by pulling the crown out to the next stop.
Oct 26, 2012 | Rolex Day-Date President 118238 Wristwatch
How to change a timex wr50m from military time to regular time
in the setting after you have set the date, you have to choose whether 12 or 24. choose 12.
Jul 14, 2011 | Watches
How do i set the time on a dunlop sports watch?
Ma montre , spur DUNLOP dun 103 g10 , est pourvue d'une feuille explicative concernant un mod?le diff?rant !
2 personnes ont pass? des heures ? essayer de la r?gler sans succ?s
comment ? puis-je la rendre fonctionnelle ?
Merci de votre r?ponse
Meilleures salutations
Gerry GRAEF
50, rue du Premier-Mars
CH-2206 Les Geneveys-sur-Coffrane
Sep 23, 2010 | Bulova Watch
Need manual for g-force watch global atomic
Hi, Since you didn't specify the model or module number of the watch, try this link:
http://world.casio.com/wat/download/en/manual/
Take the four-digit module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions.
I hope this helps you. Thanks, Bill
Sep 07, 2010 | Watches
How do I change the time?
mcdevito75 here, The 2 buttons you need are the MODE and SET the MODE button usually on the right of the case next to the stem (winder) press and hold for 2--3 seconds, now see the display flashing if so then press the set button usually on the left of the caseing, after each function is set (hour, minute) press Mode button to move onto next function to set, after all is set, presss mo
de again for steady display. If this doesn"t work, see a small watch repair shop in your area.
Jul 17, 2010 | Watches
Wrist watch- at times the watch isn't showing
Manger de la marde vous êtes des crosseurs!
Vous mériteriez d'être poursuivis pour faire perdre tant de temps aux gens, pour vous approprier les solutions que les bonnes gens trouvent et ensuite faire de l'argent avec.
Oct 26, 2009 | Polar A5 Wrist Watch
Festina 16177 / 8- Tour de France 2005 - second hand not moving
The large sweep hand is not the second hand,it is the 1,100th sec hand on chrono.The second hand during time mode is the small dial at the bottom which should be going round
Jul 22, 2008 | Festina 16177 3 Watch
Adidas Digital Chronograph Black Strap Square ADP6011 Watch for Women Logo
105 people viewed this question
Top Adidas Watches Experts
Ansel Alberto
Ansel Alberto
Vuk B
Are you an Adidas Watch Expert? Answer questions, earn points and help others
