I have a Toshiba projection tv model TP55E80 The screen went dark, but the out line you can see still has the picture. Does the tube have to be changed and if so do you know how to change the bulb?
The screen went dark, but you can see the picture at the edge of the tv. Does the bulb have to be changed out, if so do you know how to change the bulb?
TVtechmaniac
  • 140 Answers
SOURCE: 56" RCA HDTV Projection Model # R56WH78
This is a rear projection CRT TV (picture tubes)Not service-friendly (disassembly,getting parts)more problems compared to other brands....
Posted on Sep 12, 2007
BMW Rider
  • 232 Answers
SOURCE: toshiba projection tv problem
Hi, you have a failed convergence circuit, you didn`t list model & chassis number so I can`t tell you which IC`s your set uses. this is not an easy job for a layperson that has never done this before, (requires removal of main board and un-soldering two large IC`s and replacing them) If you want more info ask away but be sure to give model/chassis so I know which set were dealing with, good luck, BMW Rider
Posted on Dec 07, 2007
  • 80 Answers
SOURCE: Dark picture problem
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Posted on Oct 16, 2008
  • 65 Answers
SOURCE: chage bulb tv is still dark
The wrong or faulty lamp may cause darkness
Posted on Apr 22, 2009
  • 668 Answers
SOURCE: dull dark picture on kdf-e50a12u rear projection
Depending how long you have owned it and if a Lamp was ever replaced, it probably needs to be replaced. You can check with SONY at
1800-222-SONY and see if they could sell and send you one.
Hope this helps,
Skyassoc
Posted on Jul 21, 2009
Toshiba model CF30D50 has sound and will change channels, but picture is dark, can see vedio 1 and 2 faintly, but can get no picture on TV channels
Its a older set with 3 picture tubes---when was the last time the mirror and three lens for the tubes were cleaned?
Dec 13, 2012 | Toshiba Televison & Video
I have sound but no picture. Turns on/off with no problem. Checked settings including playing DVD and other video settings- picture just went out
The model indicated has 3 picture tubes (right model?) and will blank or turn the tubes off for several reasons--almost all are protection.
In this kind of set if vertical loss of sweep (in old sets you would see just a white line left to right) it will not permit the tubes to be on as it would burn a line instantly in all three tubes screens.
If this model not likely to be a do it yourself repair.
May 28, 2012 | Toshiba TP55H95 55" Rear Projection...
LINES AT THE TOP AND BOTTOM OF PHILLIPS MODEL NO. 60PP9202/17F
no lamp for this model, it uses three picture tubes but the three D looking picture is a convergence circuit problem and is fixable.
Apr 04, 2012 | Philips 60PP9202 60" Rear Projection...
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
Arched lines in dark screens whether it's Cable or DVD playing Model number: KP-57WV600 Sony 57inch rear projection TV
Ur convergence it dead.Do u know how to solders? Tries these websites. Tv repair World.com or Tvrepairkits.com have it.Buy a convergence kit used what in that kit ur tv well get back to normal.The shop will cost u $300 for parts and labors.
Jan 01, 2010 | Sony KP-57WV600 57" Rear Projection...
Toshiba Tube TV 32AF45 Picture Squeeze in middle
Try unplugging TV while it is on and let sit for 20 minutes. Re-connect and see...
It sounds like your horzontal control is bad. It requires a new circuit board.
Mastersage!
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Toshiba tv - no picture
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 04, 2008 | Toshiba 57H81 57" Rear Projection...
Hitachi 51GWX Scrambled Picture
STK392-560 STKS convergence CHIPs Replace both of them.
Feb 24, 2008 | Hitachi 51GWX20B 51" Rear Projection...
Toshiba TP 50H50 Blank Screen
IT sounds like you lost your high voltage going to the picture tubes. This could be due either to part of the main power supply going out due to a defective capicator or semiconductor, or something more serious in the High voltage distribution network. With the age of the set, I would be most inclined to replace it with a new HDTV, and Toshiba still are pretty reliable sets. If you can afford it, a Sony KDS-55A20 puts out a beautiful picture for around $2300.
Mar 11, 2007 | Toshiba TP50H50 50" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
