Question about Samsung SW62ASP Top Load Washer
Machine has filled up with water, has DE on screen, manouvered clothing & turned off twice.u
  • 17,970 Answers
Hi Carol:
The "DE error code" is indicative of a Door Error. This indicates that the washing machine door is not shutting, locking or opening.
Here is a link to a service manual that should help you diagnose it. Keep in mind that LG models are sometimes difficult to diagnose.
VIsit this link: LG Washine Machine Service Manual
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Posted on Feb 11, 2012
Machine is filling with water but the drum wont turn or spin
MOST LIKELY THE MOTOR IS SHOT OR THE BELT AROUND THE DRUM CAME OFF THE DRUM
Feb 06, 2013 | Washing Machines
I leave the door open on my front load washer so it can dry and not have a smell. Twice now I have came home to a flooded house. The machine apparently starts to fill with water on it's own and all the...
Turn off the water at the Fill vale if it now does not fill fit a new Solonoid valve to the fill on the machine...if it still fills with the water turned off then the problem is with the drain Too Low allowing water from the sink to enter machine.....
Feb 10, 2011 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite top load washer will not begin wash cycle and keeps flashing "FL" and beeping twice every few seconds. Tried unplugging it to see if the electronics would re-boot. How can i correct this...
Hi
Thanks for using FixYa. Error LF or FL means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | Kenmore 24032\24036 Top Load Washer
Slow to fill on most cycles, top loader. Kenmore washer takes forever to fill to the level needed to wash clothes.Model # 110 (92284800), Serial #CC0523352.
Turn off the water. Remove the cold water hose from the machine. Clean the sediment out of the screen on the water valve.You can remove the screen with a bent paper clip. Replace the screen after cleaning.
Aug 24, 2009 | Kenmore Washing Machines
Grease on my freshly washed cloths
This sounds like a seal problem in the base of the agitator. This seal is what keeps the water inside the machine and the grease out of the wash basin. It is not something that should be attempted to repair if you are not mechanically inclined.
To get the grease out of your clothes, use an engine de-greaser which can be bought from any automotive parts store. You just spray the de-greaser on the area where the grease is located and rub it in by hand. You will need to use lots of soap to remove the de-greaser from your clothes, and might have to wash the item twice, to get rid of the de-greaser smell from the clothes.
Note, the de-greaser will break down all oil stains and grease stains, and is an oil by-product. This has worked for me on many occasions, but I have only used it on denim jeans and cotton shirts, with excellent results.
Aug 14, 2009 | Fisher Washing Machines
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
My front loader doesn't use enough water.
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2009 | Kenmore Elite 45986 Front Load Washer
Samsung SW62ASP Top Load Washer Logo
81 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
easy alberta
easy alberta
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
