Question about Panasonic Cameras
Lumix fh2 digital camera focus lens does not shoot out when the camera is turned on anymore
  • 734 Answers
Many digital cameras die this way. Some cameras may work if refrigerate for a while. But it is the design or the quality of the electronic parts.
Posted on Feb 11, 2012
SOURCE: Lumix FS-15 "System error (focus)"
I have the same issue with my 3 month old Lumix DMC FS15 plus it won't focus and gives the error message to "turn camera off and then on" This doesn't fix it.
Bottom line fix: Don't buy this camera again and don't recommend other buy it.
Posted on Jan 25, 2010
  • 298 Answers
SOURCE: replacement lens cap for Panasonic Lumix DMC-FZ7 digital camera
Please see below for a link to the Lens Cap with String. This is an original part direct from Panasonic. Used specifically with this camera.
Lumix DMC-F27 Lens Cap with String
Posted on Mar 26, 2008
  • 919 Answers
SOURCE: Olympus 1010 lens stuck out. Won't shoot either
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $87.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Mar 30, 2009
  • 125 Answers
SOURCE: samsung s860 camera lens will not close and is out of focus.
I hate to say it but your camera needs to be serviced. Might not be worth the repair. Try to take it to a local repair center that would offer you a free estimate....
Posted on May 30, 2009
  • 11967 Answers
SOURCE: Panasonic Lumix DMC FX 33 wont focus and shows
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 23, 2010
My Panasonic camera won't focus or shoot and the message displayed is to remove lens cap. What can I do?
There are so many possibilities, what went wrong, or even what you did wrong. When you put your camera in automatic, your lens is clean and you try to focus to something with contrast, it should work. If not, visit a photo store, and ask the staff if they can shoot a picture and tell you if something is wrong with the camera. Not giving more information makes me stop here. The manual, for checking how to setup the camera you ind here:
http://service.us.panasonic.com/OPERMANPDF/DMCLX3.PDF
Mar 04, 2015 | Panasonic Lumix DMC-LX3 Digital Camera
Camera repair
Check out with ifixit dot come, if you can buy a "lens kit" as you name it. Perhaps you also can find out how to replace the lens barrel and see what tools you need.
Still I think you are better off with a certified repair centre. And you also should check out what a new camera costs.
Feb 25, 2014 | Panasonic Cameras
Lumix DMC-ZR1
This is a lens mechanism fault. USe can of air and spray on surrounding the lens For cleaning the dust. and then try.
Aug 05, 2012 | Panasonic Lumix DMC-FZ28 Digital Camera
Camera screen is fuzzy
Try cleaning the lens with a camera cleaning kit, other than that it will need to be serviced by a professional.
Mar 10, 2012 | Panasonic Lumix DMC-FH2 / DMC-FS16 Digital...
I want to reset my lumix panasonic fs16 but afraid of what it will do to my camara
It will reset the camera setting back to the factory default settings the camera came with.
Jul 19, 2011 | Panasonic Lumix DMC-FH2 / DMC-FS16 Digital...
Auto focus doesn't work anymore. I can shoot only in manuel focus mode.
Take off the lens and clean the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Oct 13, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
FZ-20 "Please turn camera off then on again"
In a lot of smaller point and shoot cameras, there is a separate lens/motor/gear assembly inside that focuses. If this lens won't focus, that is the message you get. The focus lens gears are typically incredibly small, and the tiniest hair, or piece of dirt will jam them. I have not fixed this particular model, but I've cleaned the focus lens gears on countless Casio and Sony models, and gotten them to work again. Try getting to the focus lens and motor, and moving it by hand. You'll find it's likely jamming up somewhere.
Jan 29, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Cameras Logo
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
