Question about Xerox DocuColor 12 Color Copier
Doc 12 3-380 error
From other posts, I think this error is caused by having a dirty mirror or contact patch. Where are the areas that need to cleaned?
Thanks
Ken
That worked great. Pulled out the belt carriage and wiped off the silver patches. It works fine now
Thanks
Posted on Dec 04, 2008
  • 62 Answers
There is a silver patch on what is called the ibt belt. If you take out the drum cartridge you can see it if you look in at about the 7 o'clock position. You need to take that belt out to clean it however. If your happy you can do that let me know
Posted on Dec 01, 2008
How to deal with error code E00012-001of canon irc5870
E012 occurs if the machine cannot read the patch when trying to calibrate color. The main causes are- 1) dirty patch sensors, located on the right side of the machine when you open the right door, just above the transfer belt-typically a off white colored plastic piece. you would have to slide to the rear and blow (3) holes out with canned air. 2) ripped belt- would have to be replaced. 3) fatigued developer causing patch to be read incorrectly. 4) faulty motor on Image transfer Unit.
Jun 07, 2014 | Office Equipment & Supplies
After turning on computer, reoccuring grinding sound till eventually stops, printer denotes 'scanner failure' and prompts power off then on again!
Whats going on from the sound of it is something stopping moving the scanner up and down OR your scanner cant find its referance point. These dont normally bust a gear but do get dusty
You need to look at the scanner and see what it is doing on power up, is it trying to move as if threw the edge of the machine? (no white reference) so keeps trying and thats the noise the scanner movin a mm then another trying to find home but failing.. usally due to dirty mirrors or blown lamp..
Either way I'd watch a few times,... y0u know the lamp under the lid that moves up and down;0..
Yuor HP should turn on lamp and shine it in the inside edge of the machines copy glass near after power up
You can manual move it with power off to the other end and then after removing your hand plug it in and turn it on and see what the scanner does, I bet it moves fine untill it get near home then starts dancin untill it gives up throwin your error (aka dirty mirrors, just use clean lint free soft somethin, no chemicals just good clean of mirrors. or somethings stopping the carriage movin.
Let us know how you go.. Cheers
The Fix... if Im guessing right that is..... is to remove the Torx screws that HP use (need a a torx driver) that hold on the glass, it needs to come out so you can clean the scanner mirrors reflector and lamp (DANGER 240v live UNPLUG;) and ensure the systemt runs well up and down the scan rail, i think you have to fight to remove the plastic cover from the operations panel too,and on some the Doc feeder has to come off, but on yours I think its the op panel to go so you can get to a screw or something.
Dec 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
E000020-0081 ERROR
Hi soni_dipu,
I would like to clarify if what is the brand and model name of your machine.
Thank you for using FixYa.
Aug 30, 2011 | Office Equipment & Supplies
Error code E 020 0181 How do I clear error code? Cannon 1150 color laser copier
Hi
Error code E 020 0181 means that the patch sensor has turned bad or is dirty, to access this try removing eac dev unit and gently unscrew each top so that the patch sensor window is visible. Also, check whether the toner hopper is overfull, it happens sometimes that the toner motor worm gear splits as a result of the hopper becoming packed tight. This may cause the worm gear to split and break if the hopper is 1/2 full or less. You may need to replace toner motor, part number (FH7-1762-030). If the toner motor is fine, then check whether the web solenoid is activating. Clean the web solenoid and ensure free action. This would clear error E020. If the error still not disappears then make sure that the DC controller is fine and the connections from the controller are fine.
Hope this helps...
Daniel
Oct 11, 2010 | Canon CLC 1150 Color Copier
Display shows "Scanner Bulb Warming Up" then goes to "Scanner Error power off power on" and despite doing that doesn't get better. How do I reset
This error is caused by either a dirty scanner mirror or a dirty scanner glass. We have a step by step guide to dis-assembly and cleaning to correct this problem posted on our web site at: www.ccl-la.com Click on the printer repair page and the the HP link. The fix should take about 30 minutes to do but you should be right back printing when you finish.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 08, 2010 | HP LaserJet 3330 All-In-One Printer
I have an Epson powerlite s4 and a yellowish patch appears on the screen as I turn on the projector
The likely cause is either dirty optics inside the projector or some of the special mirrors inside the optics are burned. If the projector was used a lot then the special mirrors are probably burned. If it's just dust on the optics the unit could be opened and cleaned but you might have to take it in to a repair place to have that done.
Aug 25, 2009 | Epson PowerLite S3 Multimedia Projector
When I send a fax from my Brother Intellifax 2800, the person receiving the fax gets the fax but there is an inch and half black bar along the right side of the document. If I make a copy, the same...
Either, you have a dirty contact sensor glass (and I hope that is the case) or your contact sensor has a faulty section. The contact sensor is basically the method which your machine uses to scan documents. Even machines with a lamp and mirrors have a slip glass that can get dirty as well as mirrors. Lift up the doc feeder to reveal the glass strip that the document feeds across, you may notice it light up when you lift the cover up or touch the document sensor arm. Hopefully, there is dirt (usually tippex or white out) stuck on the glass in that particular area. Use a alcohol cleaner to remove those stubborn types of dirt and in future let the tippex or white out dry before scanning. It may even be the gum from a post it pad which is harder to see as you look into the feeder but just clean that glass well and hope that you don't need a new contact sensor. Maybe there's paper stuck there.
Jul 06, 2009 | Brother IntelliFAX 2800 Laser Fax
Canon 28-135mm IS lens makes clicking noises
Check out the mirrors on the camera, This is a pretty popular problem with the canon cameras. The lens gets dirty in the camera and it sends a error code
Feb 08, 2009 | Canon 28-135mm f/3.5-5.6 EF IS USM AF Lens
Unable to load playstation dics or any other discs for that matter
  1. The white plastic gear that moves the laser must make contact with the "motor". A bad contact here can cause disk read errors. Sometimes it looks Ok, but you may need to remove the lens and bend the white gear for good contact.
  2. The two rails on which the lens move must be very slippery - which can be lubricated with cooking or motor oil. Usually the holes where the rail is (on the right side of the lens) are dirty or you have to bore then out slightly, making the holes bigger.
  3. The lens uses little torx screw (black) that move the lens up and down on the rail. Usually the lens is too high and requires adjustment.
  4. Take the lens off these 2 rails and take the black plastic cover off. Turn the lense upside-down and you'll find there are 2 screws (silver, phillips or torx) that you have to remove to take the upper little lens off.
  5. Then you'll see a larger lens that is usually very dirty (this lens is a mirror to light). If that's dirty, it will give a disk read error. You'll have to take the little electric board off that you see on the other side of the big lens-mirror. It's probably dirty too, so clean it. Alcohol should work OK for this task.
  6. The lens bottom has 2 + 2 screws. You move the upper "little" lens up-down-left-right (this may require a special screwdriver)
  7. The motor "rail" that moves the lens must be very clean and oiled and the 2 rails too.
Jun 05, 2008 | Sony PlayStation 2 (PS2) Console
Re: canon ir3100cn E000020-0081
I just spent 20 min typing a detailed post why the e225 is already fixed and the e020-0081 is common and means the drumm patch sensor is dirty and then the web site erased it. Grr.
The drum patch sensor shines down at about the 11 o'clock position halfway down the drum. Remove the drum taking care not to scratch it or the transfer belt and clean the sensor window.
If the problem re-occurs then you may need new developer units.
May 06, 2008 | Canon imageRUNNER C3200 Copier
Xerox DocuColor 12 Color Copier Logo
191 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
