I need to install a print/scan enabler on a toshiba studio 350. How should i do it?
SOURCE: installation of e-studio 350
U need to confirm the driver support Vista 64bit.
U can obtain the driver at:
http://www.copiers.toshiba.com/support/controllers/ebridge350-450.shtml
SOURCE: what steps to take after installing a hard drive on a toshiba 350
After replace new hdd, u need to performs following:
Update of HDD program data and UI data.
1) Create partitions. (In case of using the download jig, this is not necessary.)
While pressing [3] and [CLEAR] button, turn the power ON.
When "Firmware Version Up Mode" appears on the LCD, key in [3] and press the [START]
button.
2) Format the HDD. (Setting Mode (08-690: 2))
3) Update with the download jig or USB storage.
4) Format the HDD. (Setting Mode (08-690: 2))
* When the FAX unit (GD-1150) is installed.
Start up with the FAX Clearing Mode (1*)
Perform the 1*-100 (FAX Set Up), 1*-102 (Clearing the image data) of the FAX Clearing Mode.
SOURCE: Toshiba Scanner E Studio 205
U can download the latest viewer at below:
http://www.copiers.toshiba.com/media/downloads/support/drivers/GDI/vwr20-v101-drivers.exe
Everything is inside the application, just follow the instruction.
SOURCE: How could i print pdf files with toshiba E-Studio 232
You need to buy GM1070 or GM1071,which are print enablers for es232.
