Question about Canon EOS 5D Mark II Digital Camera with 24-105mm lens
When i look thru the viewfinder i see a circle and the picture i take is also a circle
  • 734 Answers
Is it a fish eye lens?
Posted on Feb 11, 2012
Circle in viewfinder. can't take pictures
Please clarify as to what type/color/location of the circle in the viewfinder?
Aug 31, 2011 | Nikon FM10 35mm SLR Camera
When I look through the viewfinder the shape that surrounds my image is not a rectangle but a circle. So a lot of what I see in the viewfinder is blocked because it is in a "circle" shape.
This sounds to me like the ground glass or fresnel focussing screen is missing from the viewfinder. You need to have a professional camera repairer take a look at it.
Oct 25, 2010 | Contax 645 Medium Format Film Camera
What are the ways or steps on how to use this technology
digital cameras are replacing alot of film camera, but some die hards like film because of special feature.
Any electronics has a power switch. The power comes from a battery (or batteries) and the must be charged.
Look for a button with a green marking on it or a circle with a small vertical line inside of it.
This should turn the camera on.
Most cameras now adays are point and shoot. So, look at the small screen (if your camera has one) or look thru the viewfinder (like and older camera) find something you want to take a picture of then press the button on the top right hand side of the camera.
Standard place for the snapshot button. All instructions assume the lettering is right side up and in english.
Once the picture is taken, it can be viewed o the camera, edited or deleted. The amount of memory in your camera or additional card dictates how many pictures you can store.
The cameras usually connect to a computer to transfer the pictures.
If the pictures are stored on a memory card, there are stores that can read the information off these cards and print the pictures you want, and leave the ones you don't
I hope this was helpful.
good luck and don't forget to vote!!!
Sep 28, 2010 | Cameras
Blinking circle when i try to take a picture
The camera is cannot confirm focus, so it locks up. Try changing the button on the lens to M. Manually focus the lens on something and take a picture. Move the button back to A (autofocus). It should work ok.
If not, try moving the switch back and forth several times to clean any corrosion.
Try another lens on it to determine if its the camera or the lens.
Lightspiritphotography.com
Nov 21, 2009 | Canon EOS Rebel GII with 35-80 lens 35mm...
Does af illumination cause a shadow only thru viewfinder when taking picture in the dark?
The AF illumination should only come on until the shutter is pressed then it should go off and not have an effect on the picture.
Jul 18, 2009 | Nikon D90 Digital Camera with 18-105mm...
Can't see anything on screen or thru viewfinder
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 08, 2009 | Canon PowerShot S2 IS Digital Camera
Nikon D60 is suddenly taking very dark pictures
I have had "dark pictures" from each of my Nikon DSLR (D70, D80, D200, D300) cameras usually when taking pictures from a tripod and/or the self timer. Situations where you take your eye away from the viewfinder which allows stray light to enter thru the viewfinder and throw the auto exposure way off. Not sure if this is what is happening to you.
Jun 22, 2009 | Nikon D60 Digital Camera with 18-55mm +...
Minolta X-370 Spot driving me nuts!
If its inside the viewfinder, then you'll really need to take it in for a repair, but bear in mind, that will require disassembly and that will likely run you $75-$100, which is more than a used X370 goes for on eBay.
One thing I would check is the underside of the focussing screen as maybe it is on there. Remove the lens and then look thru the viewfinder. If you still see the spot, then its in the body and not in the lens.
Look inside at the underside of the prism - thats where the focussing screen is. Do not touch the screen with any cleaning fluid or your finger. instead, grab something fairly stiff but pliable, like the straw on the edge of a dust blower. and gently rub the general area on the screen where the spot might be. Then blow the area with air to clean it all up. Look thru the viewfinder again and see if that got it.
Its pretty rare for dust to get inside the viewfinders unless they had previously been open for a repair, so theres a good chance its stuck to the focussing screen. Don't touch it with solution or your finger though as the screen can be damaged easily.
Dec 29, 2008 | Minolta X-370S 35mm SLR Camera
Shutter sticking open
Hey jimicricket,
The mirror is what reflects what the lens is seeing up to the viewfinder, and if it is sticking in the up position that is why you can't see anything sometimes thru the viewfinder. I would have the camera looked at by an authorized service technician, and it's possible that it just needs a good cleaning.
Sincerely,
Allan
Go Ahead. Use Us.
May 28, 2008 | Canon T70 35mm SLR Camera
Canon EOS 5D Mark II Digital Camera with 24-105mm lens Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
