HP DV9410US Plugged in not Charging, and it just turns off for no reason
My HP laptop will not charge a Brand New Battery, and sometimes it will stay on for hours, and then other times it just shuts off for no apparent reason. I need help my daughter is homeschooled, and she needs this laptop for online school work...
  • 5,660 Answers
Greg, the Pavilion dv9000 series of Notebook PC's have several problems.
So many in fact, that HP had a recall on them.
However your problem may just be the laptop is dirty inside. Dirty enough, that using a can of compressed air from the outside, may not do the job.
If a Processor becomes too hot, it shuts off. (BIOS turns it off)
When a Processor exceeds it's thermal limit, it turns off so it will not burn up.
This is a fail safe feature built in.
However, there may be issues more than just the laptop is dirty inside;
ONE of the problems;
Graphics Chipset:
HP claimed it was due to the Nvidia graphics chipset, but in reality it is INADEQUATE cooling for the graphics chipset.
Poor cooling design. (Not Nvidia's fault)
Unfortunately the recall is over,
http://www.nvidiasettlement.com/index.html
To explain;
1) Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
2) The I.C. used for graphics is a GPU, Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
3) The GPU is mounted to the motherboard via a BGA surface mount.
To explain a BGA surface mount;
Compare to an older Intel Pentium 4 processor, that uses a Socket 478 processor socket,
http://en.wikipedia.org/wiki/Socket_478
The Processor has 478 contact pins on the bottom. The processor socket has 478 matching socket holes.
With a BGA surface mount there are no contact pins, nor socket holes.
Solder Balls take the place of the contact pins, and Copper Pads on the motherboard, take the place of the socket holes.
The chipset (Graphics chipset in this case), is set into place over the motherboard, with the Solder Balls lining up with the matching Copper Pads.
Heat is then applied at a specific temperature, and length of time.
The Solder Balls melt, which in turn solders the graphics chipset, to the Copper Pads.
{Which solders the graphics chipset to the motherboard}
The cooling system for the dv9000 series consists of a Cooling Tube, Heatsink, and Fan Assembly.
The Cooling Tube is a copper pipe slightly flattened, filled with Nitrogen, and sealed on both ends.
At one end of the Cooling Tube are two small metal plates.
Near the very end, is a metal plate that sits on top of the Processor.
Coming up the Cooling Tube is another small plate, and this one sits on the GPU. (Graphics chipset)
At the other end of the Cooling Tube is the Heatsink.
Next to the Heatsink is the Fan Assembly.
Heat is absorbed from the Processor, and graphics chipset, by the two small metal plates.
Heat is then absorbed from the metal plates by the Cooling Tube.
The Cooling Tube transfers the heat to the Heatsink.
The Heatsink is a thin piece of metal that has Tall, Thin, fins protruding from it.
The Heatsink absorbs the heat from the Cooling Tube, then radiates the heat away with the Tall, Thin fins. (Same principle as a house radiator, or automotive radiator)
Air flow from the Fan Assembly, helps to carry heat away from the fins of the Heatsink.
The cooling system is inadequate for the Processor, AND graphics chipset, but more so, inadequate for the graphics chipset, PERIOD.
With constant overheating of the graphics chipset, the solder connections of the BGA surface mount, begin to melt.
This causes a poor connection.
ALSO, it has been reported that the Electrolytic Capacitors on the motherboard, are a problem child.
Several reports of capacitor failure have come up.
Solution?
A) Cooling System:
http://www.youtube.com/watch?v=bnkQNmKauEc&feature=player_embedded
NOT posted for advertising for the video poster. Posted for the reference material.
The best method Greg is to use a BGA Rework Machine.
All the other methods are sketchy at best. May last a year, or a week.
B) Visual identification of bad capacitors.
(Electrolytic, specifically. Plus, the Electrolytic Capacitors used are
Radial Aluminum Electrolytic Capacitors ),
http://www.capacitorlab.com/visible-failures/index.htm
Shown with desktop computer motherboards, but the principle applies to laptop motherboards, also.
To include,
HP Support > Pavilion dv9410us > Service Manual,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3439687&
In the list click on the file name -
HP Pavilion dv9000 - Maintenance and Service Guide
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds, before the first page comes up.
WEAR an ESD wrist strap. Connect it's alligator clip to a good ground source.
(I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
No need for an ESD Antistatic Mat, IMHO)
Example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components of a computer.
Use a multi-compartment container, for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
Make a record as you disassemble. Make notes, drawings, and if possible use a digital camera, or video camera. (Use good lighting)
It's nice to have a Service Manual, and possibly a pictorial, or video, but even nicer to have a personal record, for your first time.
(Good to refer back to in case you are interrupted)
Post additional questions in a Comment.
Regards,
joecoolvette
Posted on Feb 11, 2012
HP Mini 2140 "Plugged in, charging" but not charging
Hello jorel, most likely its a failure of the system board particularly the charging section, a broken pin or a loose terminal. work will be internal, suggest you do away with the battery. its better to operate it at home, or bring the charger with you. Maybe its time to get a new one.
Dec 05, 2013 | HP 417035-001 - HP Pavilion dv2000 Series...
Help!!! Is my laptop battery broken?
99% charge is still pretty good so I'm not sure whether the HP health check is accurate. The only way to check is to unplug the mains voltage and see how long the laptop goes until it shuts down. This will help REFORM the battery to a degree and MAY restore your missing 1% of charge capacity. If the battery lasts more than 1.5 hours it's still pretty useable - why spend? Also if you do decide to buy a brand new battery and the old one lasts the best part of an hour you could keep it as a backup. Good luck.
Jun 07, 2013 | Battery Biz Computers & Internet
Plugged in Not Charging
got the presario notebook the pin is not recharging the battery cost tofix 200 $ get a quote from it guy
Feb 11, 2012 | HP DV9410US Pavilion Notebook
I have a compac presario cq60, I've recently got a brand new charger and battery both from hp as they both needed replacing. I've put the new battery in and plugged the charger in but I noticed that the...
First thing to check is that the battery is inserted properly. Take the battery out, make sure there's nothing on the contacts, and then put it back in. The problem could also be that the charging jack on your laptop is loose. If you hold the charging cable plug in the laptop with a little (not a lot) force, or push it a little to the front or back, does it stay charging? If it does then the jack is loose. Your temporary fix is to hold it the way you did while testing to see if it was the problem. Be aware, this fix is strictly temporary, eventually the jack will get loose enough and not make contact at all. Consider calling Compaq customer service and checking to see if it's covered by warranty.
Mar 24, 2011 | Computers & Internet
Hello, I am having problems with my Compaq nx6110 laptop not charging. It is not the battery, as I replaced it at the end of December. The problem seems to be that the charge isn't reaching the battery,...
If you remove the battery, does the AC Adapter power the computer? Does the laptop have a barrel type power connector? I have replaced several power connectors for broken center pin. Does wiggling the power connector affect the charging light?
Mar 20, 2010 | HP Compaq nx6110 Notebook
New hp laptop battery will not charge w/plugged in AC and turned
You probally have a dead motherboard port that charges the battery.
Sep 26, 2009 | Dell Latitude D600 Notebook
MEDION MD96640 - plugged in, not charging
There is a possibility that the battery is defective.
Turn the laptop off and remove the battery and AC power. Clean the brass contacts on the battery and the laptop.
Plug in AC power only, boot the laptop up without the battery and go into the BIOS and set the BIOS to default settings. Save the changes and let the laptop boot into Windows. Once in Windows power down the laptop again and remove the AC power.
Reinsert the battery and AC power and boot the laptop up. See if that has helped.
Good luck.
Sep 21, 2009 | Computers & Internet
HP DV6000 Won't Charge
The charging process is suspended temporarily because the battery has overheated. My brand new DV5 (3 weeks old) does the same, because it's really hot here.
Turn the laptop off and the battery should charge. Also, when you do not need the battery and are running off the mains, remove it from the laptop. Keeping a battery at 100% wears it 4 times faster than doing regular charge/discharge cycles.
Jul 02, 2009 | HP Pavilion dv6000t Notebook
HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
If you charged up your battery up for 2hrs but didnt increase the percentage or didn't charge up at all it means that your battery is faulty. I have also a same case with you.
Send it to the service center near you and ask them to rplace your battery. Replacement is free if machine is under warrant.y
Jun 03, 2009 | HP Pavilion dv6000z Notebook
Gateway laptop
if you payed the warranty like for 2 or 4 years, you could bring it back to them and they will change it for you. but if you didn't pay it you just have to describe for me your problem and i will solve it
Feb 09, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
