Question about SySTOR Systems Computers & Internet
My dvd rom is out
I have a hitachi dvd rom and i want to replace my pioneer rom on my systor 1 - 1 burner
  • Anonymous Mar 24, 2014
    device driver and communication port software
  • 849 Answers
You can replace it
Posted on Oct 24, 2008
Hi I have a 1 to 15 CD DVD Systor SATA 20x Duplicator Burner Copier System who buys 5 months ago, but now when I turn the machine on but the display controller is lit but I do not see the menu, I can not...
sounds like you may have a loose connection on some of your drives i would open it up and check it out. also if it has a usb interface you can re download the firmware for this. you may wanna try and unplug it for a few minutes to refresh the system. let me know if tghat helps that what i found when i did research on your issue for you.
Mar 15, 2011 | SySTOR Systems 111 Target SATA Standalone...
My Systor burner isn't burning DVD - R. Everytime I tried to burn it says "fail" and then spits it back out. What should I do?
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 20, 2011 | SySTOR Systems (410S16) Burner
Burner keeps surging
test you PSO power supply unit it might be faulty
hope this helps
Nov 24, 2010 | SySTOR Systems (400S52) Burner
My DVD burner has stopped working , the CD rom is okay, I did a factory re-set and now the burner does not show on the list of drives,I cannot re-install it as I do not have the installation disc, it was...
Hello!
Are you do firmware?
In most case when I do firmware upgrade with pioneer DVD, I can´t fix the problem.
Now you have trouble with chip on your DVD burner, the best solution is bay another, because you can´t try again firmware upgrade.
Only what you can do with dvd or cd rom is cleaning or change a laser, but you have diferent trouble.
Nov 02, 2009 | Pioneer (DVR-106D) DVD±RW Burner
Computer reading pioneer dvd rw burner as a cd rom not as a dvd r
Please select the recorder in drop down menu, once you select your DVD writer, you will be able to burn movies.
Sep 09, 2009 | Pioneer DVR-112D DVD RW Dual Layer Burner
My dvd writer plays disk but when i try to burn movies doesnt let me keeps telling me to insert disk helpi have dvd rom pioneer dvd 115
First check the program you are using has selected the dvd-rom drive on pc.
If its selected and its still a problem then try changing to different brand of blank DVDR . I have used Tuffdisc , Bulkpaq, Datasafe, and Verbatim and few others on similar model Pioneer DVD writer and it works fine.
Jul 07, 2009 | Pioneer DVR-X152 DVD±RW Dual Layer Burner
Pioneer DVR-1910LS not even recognizing DVD-R DL disks
your DVD ROM lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working again but be careful remember that no power should be attached to ROM.
or you can buy a lens cleaner from market and try that.
pls rate my solution
thankyou
Feb 09, 2009 | Pioneer (DVR-K15 BLACK) DVD RW Dual Layer...
Drive will not read cd rom, reads dvd and audio
CD rom drive is dead!
Time to go out and buy a new one. Rough cost is anywhere for a DVD BURNER is $25 - $40.
DVD burner are now the mainstream drives replacing CD roms.
But if you can still get a replacement CD rom from a computer in town should be cheaper than a DVD burner.
DVD burner can read and write DVD's and CD's.
Aug 14, 2008 | Pioneer Computers & Internet
Replacing cd/dvd burner in a hp laptop model:dv4030us
I have GSA-T20L, lightscribe DVD burner that I need drivers for.
Please help!
Oct 26, 2007 | SySTOR Systems (400S52) Burner
Computers & Internet Logo
83 people viewed this question
Top SySTOR Systems Computers & Internet Experts
David Payne
David Payne
Are you a SySTOR Systems Computer and Internet Expert? Answer questions, earn points and help others
