Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
My Kodak ESP c310 printer reads printhead jam. Instructions states open top and and close top of printer,press ok. the printer does not print just keeps flashing printhead jam. There is no paper ja
Green light keeps flashing and repeating problem.
SOURCE: Kodak ESP-3 Will not print calibration page. It goes thru the motions, spits out blank paper. This is supposed to happen prior to connecting to computer or installing software. Tried two printheads
FYI The printheads that were manufactured for the kodak printers were in a factory in America when they realised the printheads were getting too hot. As a result over half the printheads they produced do not work thus the amount of well known problems with the 5100, 5300, ESP3.
The only way to fix the problem is to contact Kodak and they will send a new one to you along with a free set of inks as a kind of compensation.
Hope this helps!
Posted on Oct 24, 2008
SOURCE: Paper jam in a Kodak ESP- Printer
Right here we go. As already said above somewhere, slide the ink cartridges to the right, with a torch look into the left hand side where they had been sat. If you can see a pad there which when pushed it springs up and down ( and you get a black inky finger) push a plastic lug type lever at the back of this pad towards the back of the printer and the pad will slide backwards to reveal two squeegee rubbers stuck up. that is now the cleaning head unjammed. shut the top press ok and away you go, Simples.
Posted on May 27, 2010
  • 285 Answers
SOURCE: error code 3820
try the baack of the printer. open it up from the back
Posted on Jan 28, 2009
sajid_najmi
  • 31 Answers
SOURCE: replacing printhead on Kodak ESP 5 Printer
you need to lift printer front access door , take both ink cartridges out,
the carrier (black piece) is called printhead.
When you see carefully at the center , there is a gray latch. you need to "pull it up", it will release the printhead.
MS
Posted on Jun 13, 2009
  • 295 Answers
SOURCE: kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
Posted on Jul 28, 2009
How to remove print head on a Kodak ESP 5250
If the ink cartridges and printhead are already in the printer, remove them, then reinstall them.
  1. Remove the color and black ink cartridges.
  2. Remove the existing printhead by lifting the latch in the center of the carriage. printhead_removal.jpg p342_0064aa.jpg ESP 3, 5, 7, 9, 3250, 5250, 5210,
    ESP Office 6150, 7250, 9250;
    HERO 7.1, 9.1, OFFICE HERO 6.1 ESP 1.2, 3.2, 3.2s, C110, C310, C315,
    ESP Office 2150, 2170;
    HERO 3.1, 5.1
  3. Close the printer access door.
Oct 21, 2014 | Office Equipment & Supplies
How do you remove ink cart.
To replace an ink cartridge on a Kodak ESP C310 follow these steps:
1) Make sure your printer is on.
2) Lift the printer access door, and wait for the carriage to move to a position where you can access it. The ink cartridges are located in the printhead.
3) Pinch the tab on the ink cartridge.
4) Lift the ink cartridge out of the printhead.
5) Remove the new ink cartridge from its bag.
IMPORTANT:To prevent the printhead from drying out, insert the ink cartridge into the printhead immediately.
6) Remove the protective cap from the cartridge.
7) Insert the ink cartridge into the printhead.
8) Press down on the ink cartridge tab until you hear a click.
9) Close the printer access door.
That completes changing the ink cartridges.
Thank
Mark
Aug 25, 2014 | Kodak EasyShare Office Equipment &...
My kodak printer esp 3.2 is giving me an error code 3533 paper jam but there is no paper jammed and when i put new paper in it, it still wont print and keeps giving me the same error code 3533
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Sep 12, 2013 | Kodak ESP C310 AllInOne InkJet Printer
My kodak esp c310 tells me paper jam how do i fix it
Turn the Printer on
Wait for the error message
open the printer
move the ink cartridge a little bit to the right
on the left side you have three gear wheels
move the frontmost forward to move the printer carriage it should go easy.
Close the Printer and press OK to test the printer.
If it not works move the gear wheel further and further and maybe backwards to remove stuff which block the carriage
Nov 28, 2011 | Kodak Office Equipment & Supplies
Need instructions how do I clean the ink heads of the ESP3250PP ALL-IN-ONE
For ESP 3250, 5250, 5210, Office 2150, 2170, 6150, 7250, 9250, C110, C310, and C315 printers:
  1. Press Home on the printer control panel.
  2. Press the down arrow button until Maintenance is selected, then press OK.
  3. Press the down arrow until Clean Printhead is selected, then press OK.
May 29, 2011 | Kodak Office Equipment & Supplies
How do I clean the ink heads of the ESP3250PP ALL-IN-ONE
Thanks!!
EJ Kudelka
May 29, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Kadak Easy Share 5300 printer. Screen reads "Please wait"-stuck
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Aug 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kadak Easy Share 5300 printer. Screen reads "Paper Jam Clear Jam
Try this one Take out the inks and printhead Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open Close the cartridge door once the cord is unplugged Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..." Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message. Thanks Josh - Kodak Tech Support
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
700 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
