Question about GE WHRE5550K Top Load Washer
Ge washer model whre5550k1ww leaking during operation
Check and ran cycel and dosn't leak found water inside by overflow tube but havn't see water leaking
5 Suggested Answers
  • 117 Answers
SOURCE: GE Washer WHDRR418E1WW overflows the tube. Yikes.
A washer that over flows in the fill cycle sounds like a faulty pressure switch. Part # WH12X10069 and 10 on this diagram. If it overfills the tub when the washer is off it's a faulty water valve. Best of luck Ryan
Posted on Feb 25, 2009
  • 121 Answers
SOURCE: i have an older top load ge.during agitation,the
The problem is the brakes are not holding. To repair this problem yoiu will have to replace the transmission. This page has a video and step-by-step instructions on how to replace the transmission.
http://www.appliance-repair-it.com/GE-washer-disassembly.html
Posted on Sep 16, 2010
  • 47 Answers
SOURCE: My old GE Profile top loading washer is
loosen the back screws and push the top forward, its got clips in front that just shift in, then you mast carefully lift the top due to the wires and vacuum pipe that control the level, just unplug the supply
Posted on Dec 12, 2010
oldTech2332
  • 2341 Answers
SOURCE: My GE model WHRE5550K1WW
A lot of times when that style washer doesn't spin it can be resolved by resetting the motor control board. This tip i wrote explains how to reset that control board for the motor. http://www.fixya.com/support/r10292912-will_ge_hotpiont_top_load_washer_not
GENE
Posted on Sep 01, 2011
Frigidarie Stackable Washer and Dryer leak
Check the Drain Tube, Check the Screen. When it gets to the FIRST Spin Cycle, Check the Water Level inside the Drum and see if it is Completely Draining... There is a Water Level Switch that should not be allowing it to Overflow so you may have an issue there... But first check for a Blockage
Aug 07, 2014 | Frigidaire FEX831CS Top Load Stacked...
Hotpoint washing machine model vbxr1090b2ww leaking from bottom of unit
Here are some solutions.
Hope this helps you...Jim...Please leave a comment...Thanks!
LEAKS ALL THE TIME Is your GE washer leaking all the time, even when not in use? If so the problem is the fill hoses or the valve. Look behind the washer to see if water is coming from the hoses. If not, take the cover off to the control panel. Once off, you should see if the water valve and if there is leakage - it needs replacing (if it is leaking). This is the most popular water valve for GE top-loading washers made after 1995 and the part number is WH13X86 Order Here. show?id=6bjnatppuce&bids=92089.1&type=10. Note that some models have a water valve with more than two coils. In this case, you will need to order the valve by model number at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 Buy Fill Hoses Here. show?id=6bjnatppuce&bids=92089.1&type=10
LEAKS DURING FILL CYCLE Is your GE washer leaking during the fill cycle? If so the problem may be in the valve. Follow instructions above, only this time start the fill cycle before looking at the valve.
If your washer overflows with water during fill cycle your problem is the water level control or the water valve. If you must cut the water off from the house plumbing to stop the water then there is no need for testing, just replace the water valve. First, you need to turn on the washer. The washer should start to fill with water, now cut the washer off and on repeatedly (note to yourself whether the water turned off every time). If it does cut off every time you cut the washer off, then it's most likely in the water level control. If it keeps running after you cut the washer off then, the water valve is bad and needs replacing. (Note that the valve can stick intermittently so it still may be bad if it passed the test) Water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
If the water valve doesn't stick in the first test then you need to check the water level control. First, remove the front of washer (insert butter knife between the top and the front pushing on the clips) then look on the side of the tub and you should see a tube attached to a box. Remove the tube (make sure all the water is out of the tub) look in the tube to see if is stopped up. Often it will stop up near the end. If it is, you can clean it out with a toothpick. Once it's clean, reinstall it and your washer is fixed. If the tube is not stopped up reinstall the tube. Now set the water level control on the lowest setting and start filling the washer with water. If the water stops when the tub is approximately half full (this varies with every model) turn it up to the next level (you may have to reset it). Repeat until the tub is full. If at any the water level gets above the last row of holes in the tub, unplug the washer. If the water stops running when you unplug the washer, replace the water level control. If the water doesn't stop, turn the water off at the wall then replace water valve. Water level contorls and water valves can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0 . LEAKS DURING WASH Is your GE washer leaking during wash? If so the problem is the tub seal (seals around the transmission where it goes through the tub), drain hoses (including the tub to pump hose) or the pump. First take the front off the washer (insert butter knife between the top and the front, pushing on the clips) then start the fill cycle. Now start watching until you see a leak. If the leak is coming from the tub seal, the transmission needs to be replaced (note that changing the transmission is expensive and takes special tools, so you may consider replacing the washer). If the leak is coming from the drain hose or the pump you need to replace it. If you don't see it leak at all, your soap may be the problem. To check this fill the washer with water and the amount of soap you normally would use. Then start the washer and watch the tube coming from the left back of the tub (the overflow pipe). If soapsuds come out of the overflow pipe then try cutting down on your soap or switch to another brand. This may fix your problem. These parts can be purchased at AppliancePartsPros.comshow?id=6bjnatppuce&bids=92089.10000015&type=3&subid=0
LEAKS DURING PUMP OUT Is your GE washer leaking during pump out? If so the first thing you should look at is the drainpipe (to your house plumbing). Fill the washer with water, and then turn it to spin and start it. Now while it's pumping, look at your drainpipe if water backs out (it may not back unless you have soap in the tub), then the problem is in your plumbing. If it doesn't, follow the same steps as above in "leaks during wash." Only this time watch for leaks during pump out as well.
Feb 13, 2011 | Hotpoint VBXR1090B Top Load Washer
Water overflowing - GE wvsr1060a1ww top loading washer
since the water stops running in and goes to the agitation mode when you blow on the tube, it is more than likely the pressure switch - one thing to check though, put it in the fill cycle [with water running in] and unplug the power cord. the water should stop running in. if it doesn't, the fill valve is sticking open and should be replaced
Aug 16, 2009 | GE Washing Machines
Water leaking from overflow tube
pour warm water and baking soda down drain and look for cracks in tube.
May 12, 2009 | GE Refrigerators
Water leaking during drain and spin
Hi!
You Need to check the following--
The fill hoses : These are located behind the washer and are connected to the water mixing valve and faucets. Pin holes and cracks on the hoses may cause them to leak.
The water valve: The water mixing valve is located behind the washer. The fill hoses connect to the water mixing valve. Inside of the valve is that the water gets directed to the filling spout. Water leaks happens when the valve develop pin holes or cracks. Bad fill hoses or water valve could be the reason why the washer is leaking water.
The Filling spout: Is just a directing part, this part directs the water from the water valve to the tank. Pin holes and cracks is what make this part to leak.
The tank : The major cause for the tank to leak is through holes or cracks that the tank develops because of vibration or metal items hitting the tank during the spin cycle.
The tub seal : The tub seal is made of rubber, it is connected between the transmission post and the center of the tank. Leaks developed when the seal gets worn out and it looses the ability to make a good seal between the transmission and the tank. A crack tank or worn out tub seal could be the reason why the washer is leaking water.
The overflow tube : This tube is use to direct the water away from any electrical parts like the motor in case of an overflow cause by a bad water mixing valve or bad water level switch.
The pump : The pump job is to remove the water from the tank to the drain pipe. This pump has an electric motor and an impeller. When the pump motor is turning, any water that falls in to the impeller, is push out to the drain pipe.
Most leaks are cause by a worn out seal between the front pump housing and the rear one.
The drain hose : The drain hose is made of hard plastic and some times it develops pin holes and cracks leaks. Bad pump or drain hose could be the reason why the washer is leaking water.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
Rylee
Apr 03, 2009 | GE Washing Machines
GE WJRR4170 washer comes out of overflow tube on super load. It does not on Large load size. I have the front off and can see a large difference in water level from large to super size. Is this adjustable?
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
Mar 15, 2009 | GE WVSR1060A Top Load Washer
LG Tromm WM0642HW washer leaking water!
I have the same problem - just a small amount of water leaking out from under the machine. I removed the top cover and found one of the water lines rubs on the vent tube and has wore completely through. Should be an easy fix, as the line runs from the #2 spigot on the water inlet to the detergent box - both connections are right on top.
Nov 02, 2008 | Washing Machines
GE profile washer
Thanks for the questionOn a ge washer theres a over flow tube located at the back left side Sometimes if you use a high sudzing detergent , it could leak not to much to worry about just change detergent to a low sudzing one THanks for the question The appliance doc
Sep 03, 2008 | GE WHRE5260E Top Load Washer
Water leaks out from underneth
We have a WDSR2080D GE washer and had the same exact problem. We replaced the water pressure switch ($30) to see if that was the cause. A malfunction in this switch would cause the leaking from the bottom because there would be no way for the washer to "know" that the tub was filled to the appropriate level--causing the tub to overflow. Then we found out that the water pressure switch was not the cause and found that the water pump switch was the problem. A malfunction with this switch would cause water to continue to fill the tub without stopping--which would cause an overflow. Think of it as turning on a faucet without the ability to turn it off. Happily, we are now with a working and non-flooding washer at only a minimal expense. Note that the schematics for your washer are not in the manual. They are inside the control panel, which means you have to take the front of the washer off as well as the control panel in order to see what's really going on. My guess is that GE would rather consumers not try to fix their own appliances so they put instructions and helpful hints INSIDE the appliance.
Jul 23, 2008 | GE WDSR2080D Top Load Washer
GE WHRE5550K Top Load Washer Logo
52 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
