Hi, I have a Hatachi AXM89MP3uk sterio that will be 2yrs old on 23rd Dec. It has just stopped giving any output. No buzz as the speakers are connected or disconnected and the same for the headphone socket. The CD player is reading the disc, and shows time elapsed etc. so it seems to be playing, the tuner is showing the sterio symbol as if it has a good signal, but no output through the speakers or headphones (both have been tried on other equipment and are working fine) is this a common fault and/or easily repaired? Thank-you in advance for any time taken over this matter. Kindest regards, Sev.
  • Sev_McK Oct 24, 2008
    Hi Betz,
    Thanks for the reply, but I have had it unplugged for over a week and still no joy.
I had this problem and found that it was a capacitor broken on the main circuit board. It was capacitor 639 which is a 20nF ceramic capacitor. I only had a 100nF so switched the faulty one for this, replaced the fuse F2 and it now works fine. If the fuse is blowing It is most likely this capacitor or the one above it, or the diodes next to them. When this capacitor breaks it puts 28Vac across the fuse and blows it. If you can use a soldering iron its not too difficult to fix. Hope this helps.
Posted on May 19, 2011
Hi I don't have a solution but the same thing has happened to me. I opened it up and found that the "fuse 2" had blown. I replaced the fuse but it blew as soon as I plugged the unit back in. If anyone knows why this would happen after 2 years I would love to know.
mac
Posted on Dec 05, 2010
    Sergeant:
    Champion:
  • 298 Answers
It may have been over loaded, try to unplug it for a few seconds then plug it back in, this should reset the amp in the tuner it self.
Posted on Oct 23, 2008
  • kristopher betzler
    kristopher betzler Oct 24, 2008
    wow, you may want to take it in ...to see if the amp. is still functioning.
I checked my speakers there not blown out still making buzzing sound. Why?
the buzzing sound is an symptom or indication that there is a defect on the output audio system from your unit. A good audio system does not give out a buzzing sound.
Check for shorted audio wire coming from your audio unit going to the speakers
Feb 23, 2016 | Audio Players & Recorders
Hi im after some help coz driving w/o music is no fun. Just done a sterio system upgrade to my car using mid-high end sony xplod components ie 6x9s in the rear, xm4s amp, 6.5s in the doors new head unit...
Congratulations on your new audio system. I will give you 4 scenarios: 1st. From your head unit, use the Fader to separate the front speakers from the back. (only front speakers playing) now using the balance separate the left from the right so only one speaker is playing. If the sound becomes more bass filled then you have a phasing problems which could cause cut out (protection) issues. Do the same for the back speakers, BOTTOM LINE: make sure that your connections from amplifier to speakers are all correctly connected where they should be.You will know that your speakers are correctly connected when the bass is richer while both speakers are playing as opposed to more bass when only one is playing. 2nd. Your head unit RCA output is of a certain voltage (V) [signal strength]. (1.2V, 2V, 4V, 5V) Lets say that your head unit has a 4V output, To match this up with your amplifier you must adjust the gain control on your amplifier to be at the 4V position. If your voltage output does not match your input voltage and the signal in result that is being sent is too high for the settings on the amplifier, you will over voltage your amplifier making it distort then heat up and most likely start cutting out to protect it self. this could also potentialy damage your speakers. 3rd. Check that the speaker cables are not shorting on metal anywhere, that includes the speaker terminals not touching the frame of the location that they have been installed. 4th. The cable size you are using is not adequate for the power needs of your amp. hope this helps. dreamsystems
Feb 13, 2011 | Sony XM-4S Car Audio Amplifier
Where to send a onkyo sterio to get it fixed
If you don't have a local service shop, then please post your general location here so we can provide guidance. Typically any TV service shop will either service the unit directly or deal with someone that can service audio equipment. We will be happy to provide a reference once your location is known.
Thanks,
Dan
Dec 14, 2009 | Onkyo Audio Players & Recorders
My laptop speaker won't stop buzzing. It began
A buzzing/humm sound could be a earth loop problem. This is caused by connecting amp equipment into different mains power outlets.
Use a power board and connect all your amps and laptop to the one power board.
Nov 08, 2009 | HP Pavilion dv9000z Notebook
Speakers on mobile phone not working
it might be a software problem reinstall it update online
Jan 27, 2009 | Sony Ericsson Cyber-shot C905 Cell Phone
NTL STARVIEW CODES FOR DUBLIN DEC 24TH
**UPDATED December 23rd 2008**
Latest codes for Starview Box:
CW Keys 23rd December 2008
00= D8 53 39 BD 3D CA 86 C1
01= EF 38 DF 11 3D 85 FE 2F
TW Keys 23rd December 2008
00= E7 D3 69 2E 6F 38 EA 78
01= E8 C9 E5 6E B0 49 53 F5
NTL Keys 23rd December 2008
00= 7F CD 76 82 BB 22 0A C5
01= 97 9B 22 E0 5B 13 B1 C7
IRELAND NTL KEYS -- KEYROLL 18/12/2008
Dec 24, 2008 | StarTech.com StarView SV211K 2-port KVM...
Eurovox codes 23rd dec scotland
oo code are E7 D3 69 2E 6F 38 EA 78
01 code are E8 C9 E5 6E B0 49 53 F5
Dec 23, 2008 | StarTech.com StarView SV211K 2-port KVM...
Hooking up these speakers with STR-DG810 receiver
ya does need a power sub out from a mini unit big sterios have sub pre outs sends signal only u could use speaker but u may blow them i would buy a kilshpsh set best buy 5.1 299 bucks to tie in sterio rock ya aaway
Jan 16, 2008 | Sony DAV-HDX500 System
Treo 650 2yrs old - speaker problem
Hi Michael,
Have you tried volumecare application? Please let me know the result.
Oct 25, 2007 | Palm Treo 650 Handheld
155 people viewed this question
 Grubhead
Grubhead
