Question about Jenn-Air 24 in. JDB8910 Built-in Dishwasher
Jenn air jdb8910 does nothing
Will not light up at all, looked inside and it never completely drained from last use, still water in bottom, now no lights come on or anything, worked fien yesterday
Had a similar problem with mine a few weeks ago. It was intermittent in not working on delay. My first thought was that the close switch was not working. Upon disassembling the door, and fiddling with the switch, I heard some sizzling on one of the circuit boards. A little more digging revealed some cold solder joints on a couple of board mounted relays.
I removed the board, re-soldered the loose relays, and everything has worked fine since.
Posted on Oct 30, 2008
GenTech nailed that one. I had the same problem and found the 2 relays (light blue colored) had loose solder joints. I resoldered them and everything works fine! In order to remove the board, I had to pull off all the connections. I had a hell of a time removing one spade lug and ultimately had to rip it off & resolder it. A more experienced repair person might have been able to remove that one w/o the trouble I had.
Posted on Sep 05, 2009
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Why is my maytag Neptune Model no# MAH5500AWW spinning very slow and not draining water out?
Complete drain must occur before spin. A no drain situation would be an actual full pool of water seen in the bottom of the machine if all the cloths were removed, sounds like you are experiencing a spin enable switch failure, which mainly prevents final high speed spin leaving the cloths dripping wet. The spin enable switch contacts become tarnished/corroded over time resulting in poor connection. If the door lock light comes on than your door lock wax motor is working. The spin enable switch is the last switch to the right in the door lock unit where the light bulb is. Part# is 22002162. If there is an actual pool of water in the bottom of the machine as if you simply removed the cloths from the unit but left the wash water, than you should look first look to your drain pump for failure, or obstruction of foreign objects, or excess lint in the pump. Pleazer Appliance...
74bd738b-53cb-465a-99c1-ba55e2189ba2.jpg 5e1e4646-e2e3-4e7c-afc7-7a0e188e6cf0.jpg
Apr 15, 2014 | Washing Machines
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
After the last wash I noticed the bottom of my dishwasher (Whirlpool quiet partner 2) was filled with water. After unloading the dishes I closed the dishwasher and pushed the Cancel/Drain button but the...
1.Check the drain filter for clogging.
2. Check the drain hose. Remove carefully to avoid water spill.
3. Check whether flows freely from the hose.
4. Check the drain valve if possible for you.
Sep 15, 2010 | Dishwashers
Dial contin ues moving and will not complete it cycle full of water and wont drain please help
MAKE SURE YOU CAN COLLECT THE WATER AND WILL NOT DAMAGE ANYTHING BEFORE YOU DO THE FOLLOWING! In the front bottom right, is a water plug. unscrew it. water will drain. check if debis in there and look at impeller. The reason why the dial spins, is because it is giving you a fault code. count the number of the red light blinks. i have the diagnostic manual that has the fault codes that shows how to check components with an OHM meter
Aug 28, 2010 | Splendide 6200
No lights go on, will not run
Float valve is jammed.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Not working?
Check for a clog internal or external.
Scoop as much water our as you can. Open the cover on the floor of the machine. Usually just turns and lifts out or snaps out some are screwed in. Take your time and try not to force anything. Look for a clog there.
Check for clog in the drain. The dishwasher will connect to the drain under your sink and run either directly to the drain or into your disposal unit. Remove open the connections and look for a clog. Clear if necessary.
Not the clog?
Water is pumped out by the machine via an internal pump located under the base. If it fails the water will collect until it trips the float valve. First scoop out all the water from the machine and run it again. If water comes in and it runs to the point it fills again and trips the float then either the pump or timer is faulty.
Pump check.
Remove the machine. It will be held in place by screws directly into the counter top. You may have to lower it to get it out. The front feet turn with a wrench to lower.
Turn off the water supply. Run the unit again until you get to the drain cycle.
Connect a test light or voltage tester to the terminals at the pump. Check for voltage at the pump. If you have voltage replace the pump. If no voltage the timer is faulty.
Timer problem?
Some can be replaced as a unit others are integral to the control panel. Turn style can be replaced. Touch control can not.
For more help go to my more detailed tip "Dishwasher will not run. DW101 how to fix". Or click on my profile and you will find the link there.
Hope this helped you. Please take the time to rate this tip.
Thanks,
Adrian
Mar 21, 2010 | Kenmore 13723 Stainless Steel Built-in...
There is a small leak coming from a screw hole by the light in the refrigerator what could it be from water keeps dripping out
The drain inside the freezer is clogged. Your freezer goes into defrost every 8 to 10 hours. When it melts the ice built up on the coils, the water drains out of the freezer from a drain at the back down to a pan located under the fridge. You will need to remove the inside back panel of your freezer. Look at the bottom in the very back. There you will find a slopping place with a hole in the middle.This is the drain. There is something clogging that hole. I have found peas stopping them up. Take a turkey baster and fill with water. Push water into the drain hole then look for anything else that might clog the hole. Put unit back together. Problem solved.
Please rate solution
Sep 07, 2009 | GE Refrigerators
Inlet/drain light comes on
hi,you need to switch the machine off,open the door and inside at the bottom is your drain ,lift out the filters and get a screwdriver there should be one screw to undo,get a pair of pliers and pull out the part you unsrewd.........have a good look inside there,should be something in there food/broken glass/ anything could be there...............................if not that its your drain pump.......
Mar 25, 2009 | Dishwashers
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Jenn-Air 24 in. JDB8910 Built-in Dishwasher Logo
407 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
