Question about Garden
Husqvarna 700DRT won't change gears
My tiller won't change gears. It's stuck in Forward drive. I can't get it to change to anything. I noticed that it appears my time axle may be slightly bent. The tines are not equally spaced between the tine and the housing. It is off by prob two inches. I think it must have bound the gears or something. Does anyone know anything about these. I know I hit a piece of wood underground while tilling so it must have bent then. It was a little hard to disengage the tiller then. I thought it was fine until I went to use it the next time and it won't go out of drive. Any suggestions on what to do. I don't know if it's worth buying a body. The engine is in awesome shape and runs like a champ.
    Sergeant:
  • 316 Answers
Hello, you need parts or a whole new trans,and try and not het any more rocks,,
Posted on Feb 21, 2012
pranaclimbin
  • 50 Answers
SOURCE: Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Posted on Dec 04, 2008
trippssmengi
  • 76 Answers
SOURCE: Craftsman Front Tine Tiller 6.0HP/26" -- can not start it
First check for spark, if you have spark than you can try spraying a little fuel into the carb and try to start it if it starts then dies its the carb
Posted on Dec 27, 2008
Typus
  • 69 Answers
SOURCE: Roper tiller 26 inch front tine Pulley/belt diagram
I am not sure either, but I think that it would be alot cheeper to buy a new tiller, than to use your strenght fixing a old tiller that you didn't bother to keep the instructions for (no, I am not trying to be harsh. I am trying to be nice. and I am not sure about it coming with instructions, they usually do.)
29259605.jpgSorry, that is the closest picture that I can get.
Here is a link that may help. (IDK, because it is blocked where I am at.) http://www.google.com/aclk?sa=l&ai=CqcKEPGEMSvvXJJyotgeEiOyLB_jqoUWYtdrOBMib0rsYEAMoB1DU-N7X_P____8BYMmOo4qkpMQRoAGUt9H9A8gBAaoEIU_Q6ppHU85NtRLlGbCSz8M4YQ7k6yZkGAMPo_XJ9i4rSQ&num=3&sig=AGiWqtyvlB5FasgaU109ezFuPnc-65WzHg&q=http://www.fixya.com/support/roper%3Fcmpid%3DG3372595023
Posted on May 14, 2009
SOURCE: Yardman Rear Tine Tiller tines won't turn. Belt
I had this same problem and took the first advice about the shift fork arms being too spread apart. I took apart the gearbox apart and found that the shift fork arms did indeed spread apart overtime and with wear. I'm having a buddy weld some reinforcement to it as long as he can maintain clearance in certain areas as to not disrupt the operation. If it doesn't work then I did find the shift fork assembly part for $50, I just googled the part number, clicked on various sites, and found a better price!
Posted on Mar 03, 2010
  • 221 Answers
SOURCE: mtd rear tines tiller won't engage tines. F and R
It sounds like the shift shaft or something in the gearbox the shift shaft engages. I know you didn't want to hear this but it is not uncommon. Most operators don't use the clutch bail when starting, stopping, and shifting as they should.
I hate to say it but this may require a trip to your service center for repair.
Posted on Apr 30, 2010
Gear box is stuck in netural on my Husqvarna DRT900H. Tiller only 2 years old
This machine has a crash gearbox, if it id stuck in neutral then something has happened to the selector shaft in the gearbox, unfortunatly the box will have to come apart, there is no external adjustment just make sure the arm is tight that connects to the gear change rod.
Oct 03, 2017 | Husqvarna Garden
Transmission will not come out of reverse
what year is it does it have Belt Driven or chain drive ? do you put it gear with lever does it have handle to put it in gear ?is ther something stuck on the blades ? does it turn either Way ?
May 26, 2014 | Garden
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Husqvarna ft900 won't start
did you open the choke all the way? also, what was the temperature when you attempted this at the onset? if it is cold outside, then set the tiller in the sun for at least a half hour then try starting.
May 30, 2012 | Husqvarna 12" Tiller Briggs 900 Series...
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
Tiller works in reverce won't go in forward drive tines will engage but does not have power in forward .
Go to smalleng.com and watch vid on how to adjust valves. It's a great place to start. Good Luck...
Aug 16, 2011 | Mtd Troy-Bilt Bronco OHV Tiller
My gear box is grinding on my rear tine tiller. Where do I find the plug to put gear oil in the gear box? My tiller is an older model, and has been really tuff, but I'm afraid to run it this year until I...
The gear box on many tillers is usually a square headed plug like the drain plug on your car and of course it is mounted on either the side or the top of the gear box
Mar 14, 2017 | Husqvarna 14" 90Torque Rear Tine Tiller
Husqvarna model 700DRT the rope pull is stuck
usually three/four bolts hold the recoil housing on the engine. two on top two on either side of bottom. let me know if im wrong i have other answers
Apr 08, 2009 | Mantis 2-Cycle Tiller
Transmission is stuck in neural.
Possibly just linkage problem.
Mar 28, 2009 | Husqvarna Garden
Garden Logo
1,030 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
