Question about EliteGroup ECS G41T-R3(V1.0A) LGA 775 Intel G41 Micro ATX Intel Motherboard
Lan problem.yellow mark.. - EliteGroup ECS G41T-R3(V1.0A) LGA 775 Intel G41 Micro ATX Intel Motherboard
  • Stuart
    Stuart Feb 11, 2012
    Is it in the task bar, or the device manager.
  • EliteGroup Master
  • 27,725 Answers
You will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router the driver should have come with a disc provided by your ISP internet service provider or your motherboard disc
click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
hope this helps
if you cant find the driver hopefully one of these will help you
http://alpha.majorgeeks.com/Intel_Network_Adapter_Driver_for_Windows_7_d6273.html
http://majorgeeks.com/SiS191_Gigabit_LAN_&_SiS190_LAN_Driver_d5923.html
http://majorgeeks.com/IntelR_PROWireless_LAN_2100_Network_Connection_d4598.html Latest
http://majorgeeks.com/downloadget.php?id=5240&file=15&evp=5fbb1c6e47482358c61a5236fb38a112
Posted on Feb 11, 2012
Ethernet controller
That yellow exclamation mark means you don't have the correct driver for your ethernet card.
You didn't say if your operating system was 32-bit or 64-bit so I'll give you links to both versions of the driver.
Here is the 32-bit LAN driver:
http://img.dfi.com/Upload/Driver/CM/Marvell_LAN_729.zip
Here is the 64-bit LAN driver:
http://img.dfi.com/Upload/Driver/CM/Marvell_LAN_731_x64.zip
If you need any other drivers for your motherboard you can get them here:
http://www.dfi.com.tw/DFI-Lanparty/support/MBDriverDownload.jsp?selectedDriveritemId=349
May 24, 2012 | DFI LanParty UT 915P-T12 Motherboard
Conexant PRISM GT 802.11g Wireless LAN (3886)
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
hope this helps
http://download.cnet.com/802-11g-wireless-lan/3000-2112_4-162293.html
Mar 07, 2012 | Computers & Internet
Need realtek rtl 8201 cl lan driver
you will need to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
click start control panel administrive tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers if you cant find the driver hopefully one of these will help you
http://download.cnet.com/realtek-8100c-lan-driver/3000-2112_4-150156.html
Oct 14, 2011 | Computers & Internet
After formatting Hard disk & loading new windowsXP SP2 ,i am unable to connect internet through my mtnl router HG520 ADSL2+
you need to install network adapter first before you can connect to internet
check it at device manager, is there any yellow mark?if yes insert you motherboard cd driver
then chose to install LAN card driver
the otherway is install from device manager. with cd driver inserted right click at yellow mark then chose update driver, follow the step untill process finish and the yellow mark at device manager disappear
try to connect to internet through your modem
i hope this helpful
thank you for using fixya
Feb 12, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
No network connections ie; LAN
Right-mouse click on "My Computer".
Click "Properties".
Click "Hardware".
Click "Device Manager".
Is the LAN adapter correctly installed, or are there question-marks or yellow marks for the device?
Is your computer connected to a DSL-modem? a router? a cable-modem?
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
What output do you get?
Dec 21, 2010 | Dell Latitude C610 Notebook
My lan card driver has show a yellow mark lan driver not installed
because lan driver not installed . install it's driver yellow mark will removed
Apr 16, 2010 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
GeForce6100SM-M lan problem
Hi dadynidhen, there is another way to install the LAN driver & that is through windows system properties. Find the yellow question mark again & follow the instructions below.
Right click once on the yellow question mark, a window will open & Left click once on “update driver”. Windows hardware wizard will open. Click No, not at this time. Than click the next button. Another window will open. Left click once in the circle next to, Install from a list or specific location (Advanced). Than click the next button. Again, another window will open. We want to remove the green check mark next to, Search removable media (floppy, CD-ROM...). Left click on the green check mark once & it will go away.
Click the browse button, click the + sign next to my computer. Find the folder in your system that holds the 32bit LAN driver. High-light the 32bit folder by left clicking on it once. Than click OK.
Windows will see the driver files & install the driver. Once done restart the system. Run windows update service. There may be an update for the LAN driver.
Mike
Apr 11, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
I DONT HAVE LOCAL AREA CONNECTION in network connection
You can download the latest lan card driver from their website, usually the drivers that are on the cd are not updated.
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=32&DetailID=552&DetailName=Feature&MenuID=7&LanID=9
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=32&DetailID=531&DetailName=Feature&MenuID=7&LanID=9
You can also install a separate lan card on your computer or you can also buy usb to lan adapter that you can insert on your usb drive, you can google USB TO LAN ADAPTER.
Mar 08, 2008 | EliteGroup P4M800-M7 Motherboard
EliteGroup ECS G41T-R3(V1.0A) LGA 775 Intel G41 Micro ATX Intel Motherboard Logo
534 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
