COPIER NOT RESPONDING WHEN COPY BUTTON IS PRESSED.
Nothing happens when copy button is pressed. I do not think the rollers are turning. I have paper in the bottom drawer but it is not feeding to make copies.
  • 3 more comments
  • acejrcpqn Oct 24, 2008
    my sharp sf 2530 copier hanged
  • Nike Merritt May 11, 2010
    what make/model?
  • Garey Pula May 11, 2010
    Does the machine make sounds like it is trying to feed? Does it come up wuith a jam/error code? What type of machine is it? Let me know so we can tryu and get this fixed for you
  • Carlos Perez
    Carlos Perez May 11, 2010
    have u checked the button itself? (the micro switch)
  • Mike S
    Mike S May 11, 2010
    What sort of copier is this?
    what happens if you press another button?
    Is there a Code?
    How many Drawers are there and which one is the deafult.
  • 162 Answers
Develop in any sensor, can cause the block the power supply (any tension). Clean
Posted on Oct 10, 2009
Paper jam
  • Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  • 2Turn off the copy machine before pulling out the paper.
  • 3Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  • 4Check for any paper fragments and clean up any torn pieces.
  • 5Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  • 6Replace the cover and paper tray and turn the machine back on.
  • 7Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push
    see the diagram for copiers and let`s the way of paper for troubleshooting .
  • 12_19_2011_4_33_16_pm.jpgsincerely. Merry Christmas.
    ernesto cuadra
    managua, nicaragua. c.a
    Dec 19, 2011 | Office Equipment & Supplies
    Tip
    How to Fix a Paper Jam in a Copy Machine
    It seems inevitable that the copy machine will have a paper jam. You need the copies immediately, so how do you fix the jam? Luckily, ingenuity and a manual, can help you fix the problem yourself. Fixing a paper jam, can elevate you to hero status amongst your co-workers.
    1. Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
    2. Step 2 Turn off the copy machine before pulling out the paper.
    3. Step 3 Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
    4. Step 4 Check for any paper fragments and clean up any torn pieces.
    5. Step 5 Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
    6. Step 6 Replace the cover and paper tray and turn the machine back on.
    7. Step 7 Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push.
    on Jul 14, 2010 | Office Equipment & Supplies
    Copier would not copy, when you press the copy button, nothing happens
    Hi:
    If the copier is at the ready screen and you press the copy button and nothing happens, Remove the toner cartridge and verify that is is not empty. If it is then the copier will not copy.
    Andrew
    Feb 16, 2011 | Toshiba estudio 305 Copier
    System keeps telling me i have a paper jam
    Does the paper exit the paper tray?
    If not, the half-moon shaped feed rollers may be slippery. Turn the copier on its back side to see the rollers.
    Usually they are facing upwards and the rubber side is unreachable. Turn the copier back to its original position.
    1. Press the copy button. When the copier starts feeding paper take the power cord off-QUICKLY. If you are quick enough the rollers remain at down position and you can clean them with some kind of rubber cleaning liquid or solvent. Perhaps alcohol, but it tends to dry out the rubber surface.
    Jul 04, 2010 | Xerox WorkCentre 4150 Black and White...
    Canon pc 720
    Check if you have any matter that is blocking the paper path, also try to clean the rollers that picks up paper. If you happened that copier is in a dusty enviroment, dust could deposit on rollers, and rollers when picking up paper will start slipping. Try to clean with alcohol.
    Jul 04, 2008 | Office Equipment & Supplies
    Paper jam
    well part inside your product (paper handler/sensor) got damaged. must be serviced / non-user serviceable part.
    Jan 22, 2008 | Epson 1000 ICS All-In-One InkJet Printer
    PC-795 Shuts Off Mid Copy
    clean big rubber paper feed roller above paper tray with a microfibercloth moistened with rubbing alcohol.
    open copier look in lower section under the toner cartridge you will see a black foam roller wipe it off also and then try to use.
    Jan 17, 2008 | Canon PC-795 Copier
    Power problem
    the left side door is open
    Dec 26, 2007 | Canon PC-400 Color Copier
    47 people viewed this question
    k24674
    jasbo
    jasbo
