Question about Acer Computers & Internet
Wi Fi switch on my Aspire 8950 is grey and unresponsive
Blue tooth is responsive Wi Fi grey -
  • suhendo
    suhendo Feb 11, 2012
    Lap top brand new - just had it a few days, worked fine, one morning - nothing. Neither the F3 or the little switch at the bottom left work. Taking it back to JB Hi Fi tomorrow.
    Master:
  • 388 Answers
Go t Acer support download the correct drivers
Posted on Feb 11, 2012
SOURCE: Acer 4720z wi fi driver on xp Os
شكراااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااااا
Posted on Feb 28, 2009
bijoybakal
  • 57 Answers
SOURCE: blue tooth device is not working
hi,
check if your device is enabled, you can do this by ---
right click my computer..-> properties--> hardware tab--> device manager --> right click on the blue tooth icon and clcik properties. --> check if enabled..
if it is enabled check if bluetooth is enabled at startup { type msconfig in RUN in start menu, click startup tab..check if it is enbaled in startup}... or else you have to manually switch on bluetooth each time u intend to use... hope it helps.
hope to get rated as helpful...
regards
bzoy
Posted on Jan 01, 2008
Whisperwolf
  • 110 Answers
SOURCE: Wi-Fi drivers for Acer Aspire 4710Z for linux
The drivers for Windows can be used if no specific Linux drivers exist. There's a program within Linux called NDisWrapper which is designed to use the drivers provided for Windows XP in Linux. Refer to your particular distribution of Linux for the details on how to set up NDisWrapper from within your distribution (I've only done it in Ubuntu so have no experience of other distros)
Posted on May 27, 2008
Ravege
  • 327 Answers
SOURCE: problem with wifi driver for acer aspire 4715z
Welcome to fixya
try going to driversupdate.org and see if you can down load there program and try to run it ....it helps alot on the driver updates and things like that and it is easy to use
hope this helps out have a good day
Posted on Jul 22, 2008
SOURCE: wi-fi driver can't be installed for acer aspire 4710z in windows xp
i am not satify with this solution
Posted on Sep 13, 2008
Where do I find the pairing code number pls.
No where from the specs of this model it does not have Blue Tooth capabilities. From the user manual there is no Blue Tooth capabilities. Pairing code would be for Blue Tooth.
You could use a 802.11N WI FI ethernet device and connect the TV to it but no blue tooth .
Mar 02, 2015 | Samsung Televison & Video
HELLO SIR I HAVE ACER ASPIRE 5740 I HAVE PROBLEM WITH FUNCTION KEYS. AND AT THE SAME TIME BLUE TOOTH BUTTON AND WI-FI BUTTONS ALSO NOT WORKING . CAN YOU GIVE SUGGETION TO FIX THESE PROBLEMS RAMU FROM...
Make sure that bluetooth and wifi drivers are installed.
Go to BIOS and check for any options related to wireless and Fn key settings (Like enable/ disable etc).
When Wi-fi button is turned on, LED indicates its status.
Also refer to user manual that can be downloaded from: -
http://laptop.bg/system/pdfs/85/original/QG_ACER_1.0_Eng_AS5740.pdf?1276169137
Hope this helps you! let me know if any clarification is required
CreativeTECH
Nov 12, 2010 | Acer Computers & Internet
I can´t get connected to wifi in acer aspire 300lci
The most common reason for lack of wi-fi is that the laptop maker put a hard-to see switch somewhere on the rim of the chassis. My Acer 3003lci has it disguised as an activity light on the front-center edge; if you acidentally press it, there's a light 'click', the orange light goes out, and the wi-fi device is turned off. Press it again, it's back on and takes a minute to find and reconnect to wi-fi. Others I've helped have HP laptops, where the switch is a slider with the tiniest blue pin-light to show whether it's on or off.
The 2nd most common reason is that Windows, in its infinite wisdom, thinks it can run the laptop's wi-fi device better than the device's firmware, and disables the device driver in favor of its own. If you tinker with the settings, you can fix this, but it requires much patience.
Oct 12, 2010 | Acer Aspire 3003LCi Notebook
When a technician opened my laptop acer aspire 3000 we saw two disconnected wires and he doesn't have the referrence to connect the wi fi switch whenever i turn on the switch for the wifi it doesn't turn...
hi i think i understand your question
the disconnected wires you talk about is one black and one grey
if you could let me know i will try and assist you
Jul 05, 2010 | Acer Aspire 3000 Notebook
I have downloaded windows 7 ultimate on my sony vaio vgn-cr353 notebook but mine blue tooth and wi fi is not working what i can do for that
Go to your blue tooth website and wi fi website and download the drivers for windows 7 and if it is 34 bits or 64 bits, this should work.
May 23, 2010 | Computers & Internet
How do i switch on wi-fi on my acer aspire 5735 laptop ?
Check in your laptop you find wi fi switch turn it on.
then check in device manager that your wi fi driver is installed and enable.
then view for wi fi networks then you find your router if it is in range connect into it.
let me know if you need more assistanse.
Thanks.
Sep 19, 2009 | Acer Aspire 5735 Notebook
Computers & Internet Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
