Marantz MA 700U monoblock
Ok fellow techs...I have an Marantz MA 700 U monoblock on the bench. Everything works great, but the customer complains about a clicking noise from inside the amp.
On the bench it will occasionally click...and then 30 seconds or so later, click again. I found that the front end section of the amp runs SUPER HOT, to the point where the board was baked. I watched the voltage points on the front end and they were pretty unstable, so I just shotgunned the whole front end ( it was baked that bad ) tested at 10 - 50 watts RMS continuous for around 2 hours and sent it out.
It came back a week and a half later, now it clicks occasionally. After much digging, I found that the clicking was actually.....hold on to your hats...when the output reaches 35 volts pk, a peak detector circuit clicks the relay over to the high voltage section of the power xformer primary slamming the rails up to + - 75 volts to achieve 200 watts RMS, then after 30 seconds or so....CLICK !... back down to 40 volts. for low power operation. Has anyone ever services one of these POS's before ?
HELP !!!
thanks..Rob
I have eleven MA700's. Of the eleven, three produce random clicking and popping noises at the speaker output with no input. Clearly this is a very common failure mode for the MA700.
I have opened one of the "poppers" up on the bench, and with the buffer amplifier signal cable to the power amplifier disconnected, the popping noise remains, so it's definitely not in the audio path on the buffer amplifier board. The buffer amp is connected to the power amp via an electrolytic, so there's no problem unplugging the buffer from the power amp.
I do see somewhat random engagement of the high power rail mode for the amp, but this is *not* co-incident with the clicking coming from the speaker. Also, just as a side comment, if the amp is putting 23Vrms of audio on the speaker output as designed before that relay "clicks", you'd probably not hear it happen -- the speaker is already seeing several watts, and that is going to be louder than the relay. Also, when the relay switch back, it does so very quietly.
When the high/low power state switches randomly, the relay clicking is audible at very low volumes, but this is obviously not the design intent. Erratic high/low power switching problems are going to be nearby QU05, very likely the electrolytic CU08, the diodes DU01 and DU02, or QU05 itself. I'd suspect CU08 first.
The main amp PCB does show evidence of strong heating towards the front of the chassis, where the driver section is located. Unfortunately, it looks to me that the mechanical assembly is complex here; taking it apart looks to be quite a big deal and I don't actually need the amp, so I'm just going to close up. However, at least this exonerates the buffer amp and gives you a pointer as to how to troubleshoot high/low rail power issues.
If anyone locates a specific component that is responsible for the clicking and popping, I would very much appreciate hearing about it. Likewise, if circumstances lead me there, I'll post what I've learned.
--Ben, AA7AS
fyngyrz comfyngyrz gmail com(insert @ and . as obviously needed)
Posted on Mar 14, 2013
Hello
I have a cople of MA-700 which randomly make a click sound; not the actual unit but on the speaker output.
Have found the service manual for the MA700's on the Internet and gladfuly will share it.
Wonder if you finally solve the issue for your client or if want to go deeper on the troubleshooting.
Regards
Eduardo Mora
edomoras@racsa.co.cr
Posted on Jun 06, 2010
Audio speakers
Have you installed Kicker capacitors? With the extra power you have you will need them to help with the load.
Jan 28, 2014 | MA Audio Car Audio & Video
I have 2 MA AudioMA100XE 600 watt woofers and a 1500watt monoblock amp hooked up to them now. they dont hit as hard as my old 800 watt ma audio amp that blew. why is that?
mono block anps are usually rated at lower impedance.
if your subs are dual 4 ohm , i'd wire all v/cs in parallel for a 1ohm load... unless the amp is all chromed up, than that rating is probably a WLS rating(when lightning strikes)... if the box says anaba group it typically does half of what it advertises.. :-(
MARANTZ MA 700 NOT SURE HOW TO MAKE CONNECTIONS. NO MANUEL. LIGHTS UP
you'll want to use the rca sub out from your pioneer, to almost any input (aux, tape, cd) of the marantz, then speaker cable from marantz to sub. once you get them hooked up, adjust volume, bass, on the marantz to blend well with main speakers at a nominal lvl,
Mar 20, 2013 | Audio Players & Recorders
I have bose 901 series 2 speakers, marantz 8200 and 2 marantz ma700 monoblock amps how do i hook everything up? Thankd
Do you mean SR-8200? You can't omit the details of a model number if you want a good answer.
Assuming it is...
http://www.retrevo.com/support/Marantz-SR8200-Receivers-manual/id/511ci775/t/2/
Run the 901's with the Active EQ between the receiver Front L and R Pre-Outputs and the mono block amps, one chanel to each.
Pre Out Channel X >>> Bose EQ Amplifer IN, then Bose EQ Amplier OUT >>> Monoblock IN
http://community.klipsch.com/forums/storage/74/1341919/200w%20mono%2005.jpg
I can't find a manual for the MA700. Set them up to a certain volume and then use the speaker setup routines of the SR to match everything up volume-wise. Control will be in the AVR.
Aug 22, 2011 | Bose 901 VI Main / Stereo Speaker
Yamaha YPT310 use of wrong adapter fried fuse won't power up
1200 ma provides more power than the 700 ma, and would not be affected by using it on a device that draws 700 ma. The voltage of the charger makes a difference as well as the polarity of the plug. (if it is dc)
If the 700 ma charger is not working, most likely the 700 ma charger is not working
Sep 16, 2009 | Yamaha Portable Keyboard with 61...
Marantz MA-7 schematics diagram needed
I am not aware of this beig available in PDF format. What is the problem you are trying to address? Perhaps we can resolve it without the schematic.
Dan
Apr 09, 2009 | Marantz Audio Players & Recorders
Power switch light for Marantz 4060 Quadradial Amp
HI....
An 8 V , 250 mA fuse lamp is fine if that 's what the original looks like
These folks sell lamps for Marantz
http://www.vintage-electronics.cc/
Mar 25, 2009 | Marantz MA-9S1 2-Channel Amplifier
Bass 2 powerful?
yes will definately blow them you need bigger speakers! im stuck on ma audio subs great wattage for the price ! and shake hard!
Feb 26, 2009 | Car Audio & Video
RCA INPUT JACKS
did it work well before?is it new? try moving the rca's and se if you hear any thing?
Jun 30, 2007 | MA Audio HK802SX Car Audio Amplifier
811 people viewed this question
 Grubhead
Grubhead
