Question about Bionaire Humidifiers
Where is the transducer on a bionaire ultrasonic humidifier BUL 7933-Um
No mist and trying to clean transducer per daily maintenence
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Posted on Nov 08, 2008
Bionaire BT-200 ultrasonic humidifier have stopped misting, though I can hear a hum as though something is still working. I have two of these in the same state.
I have the same model; it has a little disk about the size of a dime at the bottom of the well where the mist comes out. That metal disk gathers white scale on it, Clean that off. The best way I have found is with a Waterpik turned all the way up. The scale keeps the disk from vibrating.
Jan 24, 2017 | Bionaire Humidifiers
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
When I turned on my ultrasonic humidiifier it worked for 10 sec, then I observed the water coming through the bottom. When I removed the tank and the bottom full with water. How can I fix this?
Bionaire BWM401 leaking - YouTube
? 0:39
https://www.youtube.com/watch?v=Gy7VKJJeb3o
Jan 20, 2013 - Uploaded by urhorh
My Bionaire BWM401 leaking through the bottom. ... Review ofBionaire Cool Mist Humidifier BCM7932P-CN from Costco HD - Duration: 1:41.
Nov 28, 2015 | Bionaire Humidifiers
Humidifier will produce mist for a min then stop If you look you can see it producing mist within but it will not come out of the top Walgreens cool mist ultrasonic humidifier
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
Best of luck
thebqe
Feb 13, 2014 | Humidifiers
Cleaning a Cool Mist BCM6100U Humidifier
usually it calls for one cap full per gallon of water that the unit has. what you do then is that you put the solution in the water then you put the tank back on the base and then you turn the unit on and let the solution run through your unit.
Mar 22, 2009 | Bionaire Cool Mist BCM6100U Humidifier
I have bionaire cleaning product but no directions on how to use
the cleaning product that you have you need to use once cap full per gallon of water. so if it's 5 gallons you need to use 5 cap fulls. so forth and so forth. that is the easiest way to tell you. and then you let the unit run with the solutions and the water for the hole time until the water runs out. and your unit will be cleaned
Mar 22, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
No mist, but i can see a water droplet fountain on the surface
if it's a cool mist unit it will not produce any mist. now if it's a warm mist unit it should. that's normal. it is possible to replace the transducer if it is damage but you are going to have some leakage from it. but the only way to get the transducer mainly is from the manufacturer
Mar 12, 2009 | Sunbeam Ultrasonic Humidifier
Sunbeam ultrasonic humidifier runs but produces no mist
Nov 08, 2008 | Sunbeam Ultrasonic 81696 Humidifier
Humidifiers Logo
625 people viewed this question
Top Bionaire Humidifiers Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
