Question about Infinity Reference 1600a Car Audio Amplifier
Infinity amp 1600a no output - Infinity Reference 1600a Car Audio Amplifier
5 Suggested Answers
SOURCE: infinity 1600a cuts out wit real low bass when turned up load
This amp is 2ohm stable, but if you use a dual sub setup and use both sets of output terminals it is automatically wired parallel at 2 ohms if you then have 2 subs that are dual voice coil and the voice coils of both are wired in parallel then the load become .5-1 ohm and the amp is unstable (solution) wire 2 dual voice coil subs individually one from each terminal, and then wire the voice coils in series rather than parallel
Posted on Jan 26, 2009
  • 265 Answers
SOURCE: I have an Infinity 1600a amp pushing two Rockford
Try the head unit settings as depending on the head unit it can controll the amp sepratly
Posted on Apr 06, 2009
  • 156 Answers
SOURCE: my protect light came on, how do i fix it?
Check your wiring to make sure non of the wires are touching ground. If one or more of your speakers are blown, it could cause an open or short (or throw the impedence of the speaker(s) way out of specs). One way to tell if your speaker's voice coil is blown is to physically move the cone in and out from as close to the edges of the dust cover of the speaker coil as possible (not on the dust cover) keeping equal pressure on all sides. If you hear a gritty sound, it could mean your speaker's voice coil is history. On most high-powered amps, it's important that you're not using a common ground (some older inexpensive car units did this so you'd only have to run a single wire to each speaker and use the car body as the ground point for each speaker). I doubt seriously your system does this, but that's why it's important to make certain that the speaker wires are not grounded. You can disconnect the speaker wires from your amp and check each wire for continuity to ground with an ohmmeter.
Also, check the ground point of your amp...if it powers up, the source voltage is probably okay, but there's nothing wrong with running a cable directly from the battery just to make sure.
Good luck...
Posted on Dec 25, 2009
  • 256 Answers
SOURCE: How do I hook up my infinity 1600a at 2ohms with 2 4ohm speakers?
Placing the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp. Your amp should have a bridging indication. On the connection points of the amp, you should see a mark pointing to the first + and the last -. That will be your bridge and thus utilizing the full potential of your amplifier
Posted on Jun 09, 2010
How do i wire a single sub at 4 ohms? which speaker terminals would i use?
If your single sub is a 4 ohm sub, you just connect + and - on the amp to the corresponding + and - terminals on the sub.
If it's a dual voice coil sub, it would have to be 2 ohms per voice coil or 8 ohms per voice coil to be able to achieve a 4 ohm load.
This will show you exactly how you'd need to do it:
http://www.soundkraft.com/Subwoofer_Wiring.htm
Mar 07, 2011 | Infinity Reference 1600a Car Audio...
I have a a 12" alpine 1243d hooked up to an
You may have blown a fuse, check those to make sure they aren't blown. Verify that the connections are in place again and make sure the settings on the amp are correct as well.
If the fuse isn't blown and the connections are secure, I would make sure that the wire that you have ran from your battery is within the specifications for use with your amplifier.
Mar 05, 2011 | Alpine Type-R SWR-1222D Car Subwoofer
When I Connect the LFE Output of the Amp to the LFE Terminal of SW, the SW does not work, however, if the speaker output of Amp is connected to SW, it works ok.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Infinity-PS-12-Subwoofers-manual/id/21470dj882/t/2/
I'm assuming your amp for testing was NOT a subwoofer output. I could be wrong.
Your source is responsible for creating LFE output. Are you sure it's doing that?
Tune an FM station and connect any other active RCA output from the source (like a Tape Out) to the sub
Mar 05, 2011 | Infinity PS-12 Subwoofer
May 21, 2010 | Infinity Reference 1600a Car Audio...
My protect light came on, how do i fix it?
Good luck...
Dec 25, 2009 | Infinity Reference 1600a Car Audio...
I have an Infinity 530a 5 channel amp. new
May be the problem is on the sound you are using is not a 5 channel coded sound or check in the menu´s of the amp if the rear channel´s have sufficient db output, check the connections, check if you amp. is not working only as simple stereo (menus also)
Hope this helps
Jun 24, 2009 | Infinity Car Audio & Video
Apr 06, 2009 | Infinity Reference 1600a Car Audio...
Infinity 1600a cuts out wit real low bass when turned up load
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts on either terminal when you drive the amp hard, you need to check the wiring feeding whichever line is dropping too low.
Nov 16, 2008 | Infinity Reference 1600a Car Audio...
Sunpak softlite 1600A for fz20
According to this site, the Sunpak 1600A is NOT USABLE with the FZ20: http://www.botzilla.com/photo/strobeVolts.html The tested voltage of the 1600A is 46.6V, which is WAY above the 24V max specified by Panasonic. Don't even try it...
Sep 06, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Infinity Reference 1600a Car Audio Amplifier Logo
22 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
