Question about Kodak EasyShare C633 Digital Camera
Kodak easy share m93is charging problems
Ok have this kodak m93is have new battery light stays green when on charger does this mean its charging when i disconnect battery is in same spot has not moved up or down do i need to reset and where is the reset
SOURCE: Kodak z1275 easy share camera
never use kodak again!!!
Posted on Dec 17, 2008
SOURCE: My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera.  The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
Posted on Jan 26, 2009
MNfisherman
  • 11896 Answers
SOURCE: My Easy Share (Z730) is in the open position & will not close.
VERY COMMON WITH EASY SHARE. There are only a couple things you can really do. FIrst, try removing the memory card and try it. Than if that dosen't work. Try holding power button while gently wiggleing the zoom.
Posted on May 30, 2009
  • 141 Answers
SOURCE: Is the kodak easy share c180 digital camera webcam?
I won't say the camera is usable as a webcam because you will definitely severly shorten the life of the camera by using it as such. Firstly the camera is designed to take photos and short videos, NOT being left on continuously for use as a webcam. The heat generated by doing so could damage the delicate CCD (the part which collects light from the lens and converts it into electrical signals) Secondly most cameras are deigned to switch themselves off after a certain period of non use. Not handy for webcams.
Next there's the power issue. Unless you are using an external power supply for the camera you will be forever replacing batteries and for what an external power supply costs you could buy a proper made for the job USB powered WebCam complete with focus and sometimes zoom.
Next there's the mounting issue. Where will you mount the camera to give a well lit and steady picture of your face. Definitely not on top of the monitor due to extra heat generated by the monitor itself. Mix that with camera's heat and hello, and too soon, goodbye camera.
Webcams cost $20 if ou shop around maybe cheaper. OK your cmera will give a better picture but at the distance you're talking it won't matter. Plus you will need software to generate the webcam picture. MSN is a good webcam program. Plus depending on the output of the camera, usually only video. You may need a video capture card for your computer. The camera will give you a full screen image of what it's pointed at but you need a box to put a smaller picture in on the screen otherwise all you will see is one big face, yours.
So do you really want to wear your camera out prematurely simply because you can't afford a $20 webcam. The made for the job unit is cheap, will stay on all day and the power comes from the USB port. Everything you need and cheap. I think you know which way to go.
Good luck
Posted on Apr 22, 2010
  • 94 Answers
SOURCE: Kodak easy share c182"lens error 211" will not
The lens has been knocked, probably not worth rpair due to low replacement cost - do you have household contents insurance ?
Posted on Jun 09, 2010
Kodak easyshare dx6490 charger indicator light is on but battery wont charge
Sounds to me that if you bought 2 chargers then you have a bad battery. what are the odds that you have 2 bad chargers ? Time to buy a new battery.
Jan 25, 2013 | Kodak EasyShare DX6490 Digital Camera
Kodak easyshare m320 charge light is green, but not charged
Hello Dead Battery, Well this sounds pretty easy compared to most questions I get. If the camera says the battery is dead, then the battery is dead !! the problem with batteries is they loose their capacity over time. The charger can not put any more in it and says it is charged. Just get a new one and give it a full charge and this should do the trick.
Best Regards, Russell
Sep 29, 2012 | Kodak EasyShare M320 Digital Camera
Charger model FY 4101 green light stay lite all the time, and hoveround battery is still dead
When the green light stays on regardless of dead battery, this means the battery is defective. The battery must present a load to the charger, which causes the charger voltage to drop, turning the charger on. When the battery is defective, it will not load the charger, and the charger voltage stays at full charge value. This of course, causes the green light to be switched on.
Sep 16, 2010 | Electronics - Others
Laptop wont charge
Orange means it's charging or connected vs. green means fully charged.
At least that's the way my battery charger is on my kodak camera.
Jul 28, 2010 | Compaq Tablets & eReaders
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
Kodak Easy Share Printer dock plus. Original
you're not completely right. Kodak printer docks normally only charge the Kodak KAA2HR battery pack. It not charges normal Ni-MH rechargeable batteries of any brands.
Jan 12, 2010 | Kodak EasyShare Thermal Photo Printer
Battery won't charge on my ryobi 14.4v cordless drill yellow and green lights stay on
I had the same problem and found a solution on another forum...
Plug the battery into the charger. The yellow and green lights come on. Leave the battery plugged into the charger. Plug and unplug the charger power cord from it's power source a few times until the the red charger light comes on..... problem solved!
I think the "smart" circuit in the charger that is supposed to trickle charge before the regular charge cycle needs at least some battery power to test and start the cycle. If the battery is totally discharged, the test can't deternine the battery status and will not charge.... Plugging and unplugging the charger seems to bypass this teat and charge the battery normally. The charging process should work normally after this method.
Oct 22, 2009 | Drills
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Won't hold a charge
what rechargeable batteries are you using and what's your method of charging?
If your using a dock for charging - make sure you have the battery pack kodak kaa2hr otherwise the dock won't charge it
if you're using a separate charger - it's ok to use other AA ni-mh
please check the age of your batteries as well.. batts, even rechargeable eventually wear out - they can last up to 300 charging cycles and a year or a little more than that is enough for you consider buying a new set
if you say that you barely use the cam, batteries still deteriorate through time
Apr 12, 2008 | Kodak EasyShare CX7525 Digital Camera
Charging battery
I have the same camera.
But when your camera is flashing the green light, that means it's transferring pics.
If the light is just green on the camera, that means that it's charging i think.
But i don't know how to tell when my camera is through charging is my problem.
Nov 23, 2007 | Cameras
Kodak EasyShare  C633 Digital Camera Logo
20 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
