establish your first 'New Game' using only one remote.
restart game
Select a file to use.
Select
"2 Players" and a screen will prompt you to sync your second remote.
Press and release the A button on the second Wii Remote and you should
be set to go.
From the ground floor of the Tower, move to the left towards the door. There should be a door labeled "Map." Enter through the door by pressing the A button to access the map . From the map screen, the characters will appear near the tower. Move the characters towards the top left of the screen. There should be a town called "First Frolic" second from the left, enter this town to begin the game.
you need to press the red reset button in the battery compartment of the second wii remote AND the red button inside the small door on the front of the console
does the controller work? if not then open the battery case and press the red button and then open the SD card slot area and press that red button and wait and it should eventually connect. hope this helps!
hello i had the same game and same problem what i did was fiddled around and found out that you should go to the main menu select settings and go two player
Have had this problem before with wii sports. What I did was turn off the wii console and unplug from the power, leave for a few seconds then turn it back on when the health & safety screen comes up
Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
