Question about Casio FX-115ES Scientific Calculator
Casio fx-115es always displays a fraction, i want decimal format
SOURCE: casio fx-83ES
Thank god for that man, nearly chucked it in the bin before reading this.
Posted on Mar 31, 2008
  • 7993 Answers
SOURCE: how do i display decimals on casio fx 115es
The instructions are below the screen. It says Mode arrow and a table of numbers.
If you want to set (use) degrees, you press the MODE key followed by the 4 key. On the top of the screen deg will be displayed.
If you want to set RAD or GRAD, similarily, you press MODE followed by 5, or MODE then 6.
However if you want to convert a result displayed in a particular unit into other angle units, you press SHIFT MODE then 4 or 5 or 6, whichever is the case for you.
Hope it helps.
Posted on Aug 17, 2009
  • 7993 Answers
SOURCE: problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
Posted on Sep 12, 2009
  • 41 Answers
SOURCE: changing fractions to decimals
pressing the 'a b/c' key toggles between fraction and decimal formats
Posted on Sep 15, 2009
  • 7993 Answers
SOURCE: Why does it solve in fractions?
The calculator has two Input/Output modes: the default MthIO (new) and the old LineIO.
  1. In MthIO you enter fractions and radicals as you see them in textbook (multiple levels). Calculations are exact and results are generally a mixture of fractions and radicals.
  2. In LineIO, numbers are entered the old way and all numbers, operations are written on a single line. All fractions and radicals are converted into decimals numbers.
If you use the default MthIO you can let your calculator perform the operations in exact arithmetic. When you obtain the end result, you can easily convert a fraction/radical result into a decimal one by pressing the [S<=>D] key, or press [SHIFT][=] instead of [=].
However if you do not care about the MthIO and its nifty functionalities, you can configure your calculator to use LineIO.
To set LineIO press [SHIFT][MODE][2:LineIO]
Posted on Jan 29, 2010
Can a casio fx-115es reduce fractions
Yes. Simply enter the fraction and press =. If the calculator is in the MathIO mode it will display the fraction in its simplest form. If you're in the LineIO mode, press the S--D button to convert the decimal to fraction.
Aug 18, 2011 | Casio FX-115ES Scientific Calculator
How to show answers in an improper fractions format?
Press the [S=D] key to toggle between fractions and decimals. Converting a decimal result to a fraction is not always possible. There may be limit of 10 digits between numerator and denominator.
My Casio fx-115 ES Natural Display is solving 21.9 in a fraction when I put the calculator in scientific mode.... Why?
If the calculator is in the MthIO mode it will always attempt to display the result as a fraction. To convert a single result to decimal, press SD. To have the result always come out in decimal (according to the selected display mode), press SHIFT MODE 2 to select the LineIO mode.
Oct 07, 2010 | Casio FX-115ES Scientific Calculator
When i add 12.3 + 12.3 I get the anwser in fraction form instead of decimal form.
If the result is already calculated and displayed, press the [S<=>D] key It will convert a fraction or radical to decimal. This is always possible. If the result is decimal it may be converted to a fraction or a radical (Not always possible).
If the expression to be evaluated is still in the command line and you have not pressed the [=] key, you can force the result to be displayed in decimal format by pressing [SHIFT][=] instead of just [=].
More permanently. If you do n o care for fractions and radicals, set the Input/Output mode to LineIO. To do do press [SHIFT][MODE] to access the (SETUP) screen and select [2:LineIO]
Jun 16, 2010 | Casio FX-115ES Scientific Calculator
I cannot find how to change my answer display to a decimal instead of a fraction on a Casio FX-115ES. I am working with financial formulas and need decimals! Anyone???
More permanently. If you do n o care for fractions and radicals, set the Input/Outpout mode to LineIO. To do do press [SHIFT][MODE] to access the (SETUP) screen and select [2:LineIO]
May 20, 2010 | Casio FX-115ES Scientific Calculator
How to get answer in decimals instead of fraction
if you do not want to change your settings There are two ways to foecr calculator to display a result in a decimal format.
  1. Before pressing the [=] sign to get the result press [SHIFT] key. thus [SHIFT][=] displays a result in decimal format.
  2. If a result is already displayed and it is not in decimal format (fraction or radical) press the [S<=>D] key to convert it to decimal.
  3. The [S<=>D] key toggles between formats (fraction/radical to decimal and from decimal to fraction or radical depending on the format used in calculation.)
  4. That does not mean that every decimal number can be converted to fractions/radical.
If you want to have all results in decimal format you can configue your calculator to always do so. All it takes is to set LineIO as the default Input/output format.
Press [SHIFT][MODE] to access (Setup) and select [2:LineIO].
Just in case you want to revert to the other IO mode (MthIO)
Press [Shift][MODE][1:MthIO]
Feb 15, 2010 | Casio FX-115ES Scientific Calculator
When I divide, I get a fraction. How do I get a decimal
If your calculator is configured to be in MthIO, the fraction that is displayed is always reduced to its simplest form. (The denominator is the smallest possible.)
If you are adding fractions, the result is also a fraction in its reduced form.
If you want to convert a fraction to a decimal number, press the [S<=>D] key.
To set MthIO: Press [SHIFT][MODE] (SetUp) and select [1:MthIO]
To set LineIO: Press [SHIFT][MODE](SetUp) and select [2:LineIO]
In LineIO, all results are expressed in decimal format.
Jan 26, 2010 | Casio FX-115ES Scientific Calculator
How do i display a fraction?
Press [SHIFT][MODE][1:MathIO].
When in MathIO, you can obtain decimal results if you press [SHIFT][=] instead of just [=] to calculate.
Also, you can use the [S<=>D] key to toggle from one display format to the other ( Fraction <-> Decimals) or (Radicals<->Decimals).
Hope it helps.
Nov 14, 2009 | Casio FX-115ES Scientific Calculator
Cant get answers in decimal format, I would like to set up my casio fx83es so that the answer is in decimal format all the time.
To make sure that results are always in decimal format, put a decimal mark (point) at the end of one integer.
ex: 1./2 or 1/2. or 1./2. display as 0.5, so does 1. + 1/2
To convert from decimal to fraction and from fraction to decimal press a b/c
To convert from proper to improper fractions use [SHIFT][d/c]
Hope it helps.
Oct 04, 2009 | Casio fx-300ES Calculator
Problems with fractions on the Casio fx-115es
Hope it helps.
Jun 01, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
19 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
