Question about Echo Garden
Need coil and spark plug gap setting for echo cs 3000 chain saw
dontbother10
  • 2220 Answers
SOURCE: How do I change the primer bulb on my Echo CS-3000
The IPL for an Echo CS-3000 is here:
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
See page 8. There is no shop manual offered, you will need to interpret the pictures. Didn't look to difficult. GL
Lou
Posted on Sep 07, 2009
Testimonial: "Having the parts list helped me to understand how the primer bulb was installed. A great help. Thanks, Ed"
  • 277 Answers
SOURCE: how do I replace the purge pump on thr Echo chain
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Posted on Jun 21, 2010
#1 Taper
  • 1040 Answers
SOURCE: how to replace purge bulb
Once you are able to get to the four screws holding the primer bulb on, simply remove the screws, grab the bulb and pull off of carburetor. Take the metal sleeve off of old bulb and replace with the new one. Reverse procedure and GO CRAZY!
If I can help you any further, let me know.
JIm
Posted on Sep 16, 2010
  • 4088 Answers
SOURCE: what is the spark plug gap setting for small ECHO
0.020" should work well. Check the quality of the spark--it should be blue and snappy with the new plug. Hope this helps!
Posted on Dec 10, 2010
H2_Brad
  • 425 Answers
SOURCE: i have an echo chain saw model CS305, ser#
The air gap should be .010 not .001
Posted on Jul 16, 2011
Echo chain saw has no spark how to fix
Not being facetious here... change the spark plug as a first step. They require regular replacement. If that doesn't work, use a multimeter to check that the spark plug wire is actually releasing electrical pulses. If it isn't, you'll need to keep moving further up the line to the coil.
Sep 01, 2014 | Echo Chain Saw Service Repair Manual...
Need plug gap for echo cs 351 vl
Recommended plug is NGK BM-6A gap .024" to .028"
Apr 05, 2013 | Echo Cs-351vl Chainsaw Parts Manual Chain...
Echo cs-3400 wont start . no spark. what are the primary and secondary coil readings?
if you have no spark
check for faulty plug 1st, then pull kill wire off at kill switch, then check for grounding ht lead ,
then pull kill wire off at armature , if still no spark most likley faulty ignition armature
i suspect the part number you need if its type 1 is 15662639130
replace it and set air gap and reassemble and test
here is web site for parts
http://www.ereplacementparts.com/echo-cs3400-type-chainsaw-parts-c-35043_35970_36021.html
or you could try www.partstree.com , go to echo saws , then find your model
cheers hope it helps
pauly 46
Jan 28, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
What is the spark plug gap setting for small ECHO CS3450 chain saw with new autolite plug?
Dec 10, 2010 | Echo Garden
I've replace the spark plug, put in fresh gas and tested it for spark. My CS 100 chain saw will not start. Any help would be appreciated.
The spark at the plug (gapped 0.020") should be blue and snappy. If ok, pour a little fuel mix into the plug hole and try for start. If pops several times, then you have fuel delivery problems. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the primer bulb fills with fuel when pumped several times. If nothing, either the primer is damaged or the carburetor needs cleaning inside. While in the carburetor, inspect the lower chamber diaphragm for hardness or cracking. Go to: www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. Hope that some of this helps!
Oct 23, 2010 | Echo CS400 18" Chain Saw
My saw won't start. how can i check the ignition?
pull the kill wire off at the ignition coil - retest for spark , if now spark faultry kill wire or switch indicated
but if no spark fit spark tester in line with h t lead and spark plug
gap tester is basically a piece of wood with 20 mm hole in middle and a hole drilled through to centre from opposing sides
the a nail that fits firmly is pushed through 1 on each side
and meet in the middle of the hole , but the points of ecah nail must align together and be exactly no less than 6.00 mm apart from each other ( place the tester inline between h t lead and plug ) use whater adaption you may need to connect to the saw
and pull the engine over as you would
if all is well the spark should jump across this gap and the gap at the plug while under compression pressure
you will see it in the the tster window
if no spark coil is problem
replace coil and set air gap to 0.010" and refit wires ands covers
pauly46
Oct 02, 2010 | Echo CS400 18" Chain Saw
How do I change the primer bulb on my Echo CS-3000 chain saw
Lou
Sep 06, 2009 | Echo Garden
Echo chain saw 16 inch will not start
You need to play about with the timing adjustment.
You can adjust the timing by two different methods.
The first is to adjust the space on the spark plug.
The other is to adjust the gap between the contact, and the coil/magneto.
There ya go, FixedYa !))
Don't forget to rate, thanks.
May 09, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
67 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
