I ordered a new 72 pin connector today for my ancient NES system. Is there a trick to opening up the console? Do I need a special tool?
Thanks in advance.
Gary
Comments:
Nov 18, 2008
- Thank you. The screws were in fact all Phillips and easily removed. I had no problem installing the new connector. However, the Zelda II cartridge would freeze at times. I disassembled the console and used contact cleaner on the new connector. The game (and the others I tried including Super Mario 3) now have worked flawlessly without any resets. Thanks all for your helps.
to my knowledge no, all screws on the NES are phillips screws.
However,
If you see some funny star shaped screws then you need what they call a gamebit. Check ebay. There are two sizes of "gamebit" so if you need the tool check you get the right one.
I've opened up several NES systems and they all had standard philips head screws. No problem getting in.
You have to remove the motherboard to get the new connector on, and its a tight fit, so you'll have to apply some pressure.
The real trick to reassembly is getting the black cartridge holder in place so it works right. No reason for it to be there except that the NES is trying to look like an old fashioned VCR. Clever, except for the fact that the top loading vcrs were history by 1985. Anyway, experiment with how tight you have it screwed in, and eventually the cart loader thing will stay down when you load the game in.
Also, start working with the NES by putting in carts. But not the Mario Brothers/Duck Hunt game. The earliest NES games have a thicker circuitboard that will be hard to remove from the new connector. Try other games and after a few carts the connector will be ready for anything.
One of my NES consoles has blinked red for years. It also used to reset constantly. I replaced the...
(More)
One of my NES consoles has blinked red for years. It also used to reset constantly. I replaced the 72-pin connectors and cleaned the system. It still blinks red no matter what. Any ideas?
My NES games work fine, however in order for my games to work, I have to insert the cartridge in as...
(More)
My NES games work fine, however in order for my games to work, I have to insert the cartridge in as for away from the 72 pin conector as possible. Even though this works, the image when I play the game is very fuzzy and ruins gameplay. Is it my TV? Is it my NES? Are there any soulutions? Please help me fix my NES so I can play the old classics again!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
