FixYa.com
Tags:
iLO -3200 32 in. LCD Television
ILO LCD Color HDTV does not change channels /... (by 36 users)
posted by Lpike on Aug 08, 2006
I can't get the TV to respond to anything other than on/off. I have tried from the side buttons and from the remote. I can turn it on and off but no menu, +/-volumn,+/- channels, entering channels by numbers....none of the buttons on the remote do anything except the Power button.
It comes on and reads ANALOG TV as usual then identifies the Channel A 47 with the word Mono underneath.... It plays the channel just fine but that's it..... just that one channel.... Then last thing I recall having done was gone into the TV Menu and set the channels... Could I have screwed something up there? Is there a way to reset the thing back to factory defualts?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
35 Other Users Have The Same Problem
Comment by Guest, posted on Jul 22, 2008
i have same problen displai analogo chanel 59 the set no move
i am luis i have same problen
Comment by mskickstand, posted on Jul 11, 2008
My TV is a 32 inch ILO LCD purchased in Dec of 2006 and the same thing happened to it in July of 2007. I change the channels through my cable box, but it stuck on a volume that is low enought that if you have any other noise (A/C, dishwasher, etc) you can not hear it. Also cannot do anything but turn it on and off. Walmart would not help, the extended warranty I bought is not worth anything, they said they would send me a label to ship the TV back, no lable and no one answers if you call the # now.
Comment by Guest, posted on Jun 25, 2008
can not change channel
Comment by Guest, posted on Jun 20, 2008
yes
Best Solution
posted on Apr 14, 2008
Helpful (85)
hathead23
Rank:Master Master
Rating: 85%, 16 votes
shopjimmy.com you need a new control board easy fix diy
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 18, 2008
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
iLO TV is made by tatung.
Solution #3
posted on Feb 22, 2008
Helpful (85)
vigvette
Rating: 78%, 2 votes
The phone number for the WAL MART version iLO 32HD is 1-800-216-5156 7:30 AM to 5:00PST
You must have your model number,serial # and a copy of a reciept for them to even start talking to you...
You must be a shop to purchase parts.. Their operators are RUDE..
They say if it's out of warranty it's 149.99 to repair it + parts + shipping...There located in California
InitialDVD.com
This is now a CHALLENGE for me... more info to follow
Mike
Solution #4
posted on Dec 09, 2007
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
Hold the menu button on the tv. as long as you hold the menu button, you can use the remote to control the channels, menu etc. my solution, tape down the menu button on the tv
Solution #5
posted on Aug 08, 2006
Helpful (85)
take
Rank:Wiz Wiz
Rating: 79%, 437 votes
sorry but is not a defualts problem, and there is nothing that you can do, so call a tech or better take it to a shop and pray for a cheap repair....good luck
Solution #6
posted on Jul 10, 2008
Not Rated (0)
lafoy
Rating: 85%, 1 votes
Matthew D. Schelkopf [mds@chimicles.com]
Class Action Lawsuit Attorney investigating a case against iLo
iLo Has had my TV for 5 Months now!!!
Solution #7
posted on Jun 09, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
mine stuck on the composite all i can do is play xbox....... I DONT EVEN LIKE XBOX ANYMORE!
Solution #8
posted on May 22, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
SAME PROBLEM. WISH I WOULDA NEVER BOUGHT THIS THING.
Solution #9
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Someone post the tech-support contact information for this iLO company.
The german electronics comany at www.ilo.com has a huge disclaimer on their web site: We are NOT iLO home electronics. Apparently this wal-mart el-cheapo company has a very bad track record.
If there's a class action lawsuit, let us know about it!
Can you Help with these Flat Panel Televisions problems?
No main picture
I have a 21 inch ilo flat... Answer This...
screen went blank
We were watching television... Answer This...
tv problems with channels and...
32' ilo doesn't change channels... Answer This...
I have the ilo 32 inch tv...
trying to program the tv to the... Answer This...
ILO*32HD stuck on one channel
I bought ILO-32HD last year,... Answer This...
35 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 09, 2008
My tv has no pictues and says cable, a 62, no signal what can I do
Comment by Guest, posted on May 27, 2008
I HAVE A 32INCH AV/TV/PC MONITOR LCD TV WITH HDTV TUNER BUILD IN .....ILO-32HD.....JUST A LITTLE OVER ONE YEAR OLD AT THE WAL-MART PRICE OF $797.00.IT IS STUCK ON THE HISTORY CHANNEL AT A MORE THAN COMFORTABLE VOLUME. THE REMOTE TURNS IT ON AND OFF AND THATS IT. THE CONTROL BUTTONS DO NOTHING.I HAVE UNPLUGGED AND REPLUGGED IT. I CHANGED THE REMOTE BATTERIES.I EVEN BOUGHT A NEW REMOTE AND SO FAR NOTHING WORKS.
Comment by jonathan9120, posted on May 20, 2008
my thing is on 60 in it want chage
Comment by Khoop26, posted on May 19, 2008
I am having all of these same problems. so is it a key control board or a controller board?
Comment by Guest, posted on May 17, 2008
its stuck on channel 10. cant change channel,volume,menu,etc from remote or directly from the tv.but it turns on/off just fine from the remote and tv,the channel that it's stuck on(10) works fine.All i want is to be able to connect my cable to it,maybe get it to ch.3 Even if i cant have remote.
cant change channel,volume,menu,setup etc but the power works fine. channel is stuck on ch.10 which works fine.
Comment by Guest, posted on May 02, 2008
I tried to change the channel on the tv instead of the remote and now NOTHING on the tv will work at all and neither will the remote.Tried everything and nothing will work. UGH!!!
Comment by Guest, posted on Apr 29, 2008
Ditto....My TV is stuck on channel 24. I've now taken it to two repair shops with no avail. With all these problems, Walmart or the Mfgr should take the units back. Hey ! just give me in-store credit I don't care. It's such a lot of money to some of us (which they targeted the low-income for this product) Can anyone HELP!!!!
Comment by Jamiecupp, posted on Apr 02, 2008
The tv is acting the same as the above person described. The volume is low but on and the channel is on 3 cable, but won't react to anything. We even tried buying a universal remote and found the code, but it wouldn't do any more than the original remote. The controls on the top of the tv will not work either. Help email me and send an email PLEASE
Comment by Guest, posted on Apr 01, 2008
Same exact problem. Can't do anything but turn it on and off with the remote and it is stuck on the S-Video input. I can't use my HD outputs from my Wii or Xbox with it. Also bought from walmart.
Comment by tomjean10, posted on Feb 24, 2008
I have the same problem. Had the TV right at a year, and the only thing that works on the TV and on the remote is power. Stuck on 1 channel. Thank goodness it's stuck to Directv, so I can still change channels through that.
Comment by Guest, posted on Feb 22, 2008
I can't believe this I have the exact same problem, P.O.S. tv
Comment by sdangel, posted on Jan 10, 2008
O yes i have the same problem but the tv works great with the cable box because my tv stayed on channel 3 and i can hook up my cable box and watch the channels from cable and with the cable box I can turn up the volume or turn it down... I would like to get my money back for this piece of JUNK Lawsuit I bought mine at Walmart as well.. Here in San Diego
Comment by JEG2008, posted on Jan 04, 2008
I have the exact same problem. At first, the TV would not recognize any inputs - I would have to turn it on by the remote control, then turn it off by the button on the TV itselt, wait 30 seconds, then turn it on by the button on the TV - then it would recognize the component video or cable inputs. Now, nothing works except the on/off switch - I can't change channels, control volume, etc. Of course, this is all just past warranty. Amazing that so many people are having the same issue. WalMart, if you're listening, I'm thinking this sounds like a class action lawsuit.
Comment by Guest, posted on Dec 30, 2007
We have had this tv for about a year. It worked until about a week ago. Same problem as you guys. Has anyone been able to fix it. How?
Comment by Guest, posted on Dec 18, 2007
Remote will only turn TV on and off, only one channel. This stinks that so many products experience the same manufacturing fault.
TV only goes on and off, one channel????
Comment by Guest, posted on Dec 12, 2007
I have same problem, no volume, controls on tv don't work except to turn it off/on using the remote. Sometimes no picture just sound. Initial Technology has tv now. They said it will cost 99.00 to fix it..
Comment by Koechnerd, posted on Dec 08, 2007
I have the same problem does anyone know what it will cost to repair this piece of junk?
Comment by Guest, posted on Dec 07, 2007
We can't change channels with the up & down button on the remote or the side of the TV.
pretty much same problem, auto scanned channels and tv now is stuck on a sentence which reads "This in an encripted channel" and now will not do anything no matter what we try. We reconnected the cable, unplugged for a while, turned on and turned off a few times, remote just turns tv on or off. Other buttons on remote do nothing. Please help solve this problem. If have a solution e-mail me at: maggie2801_2005@yahoo.com. Help asap!!! Lorraine
Comment by Guest, posted on Dec 06, 2007
does not change channels / volumn
Comment by Guest, posted on Nov 30, 2007
Same problems.
No control panel no control on remote.
This monitor suck ass!!! I will never buy this brand ..........
I threw it out the windows.
Comment by altersteve, posted on Nov 18, 2007
I also have the "stuck" problem. Does anyone know if an "engineer menu" is available? If so, how do you access it? I build custom electronics for a living, so I know you can hide some really cool things ("easter eggs" as they are called).
If you have any info, or if you have an old iLo you want to sell for parts, please drop me a message at altersteve@gmail.com.
thanks
Comment by Kayser28, posted on Nov 17, 2007
Same problem exactly! Has anyone been able to fix it?? I have tried unpluging, disconnecting the cable, replacing batteries on the remote, turning the tv on while holding down the menu button, but nothing has made any difference at all.
Comment by ACXIONPR, posted on Nov 10, 2007
same problem
Comment by Guest, posted on Nov 08, 2007
I have same problem. Any advise?
Comment by leisure, posted on Nov 04, 2007
im having difficulties with turning on my tv.
Comment by Guest, posted on Nov 03, 2007
ilo-26HD lcd televsion stuck on one channel. wont respond to the remote or the buttons on the tv itself. Turns on and off only. The channel it is stuck on plays fine. Any suggestions, I see I'm not the only one with this problem.
Comment by deezy337, posted on Nov 03, 2007
tv does nothing, but come on. i can't set channels, nor operate the menu screen
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
