Question about Worx All-In-One Blower/Vacuum/Mulcher
Cannot remove bag
Just purchased a Worx all in one. When it came to taking the bag off I tied to unlock it but it won't budge. Any ideas?
  • sajaha Mar 16, 2009
    same problem. Bag went on but will not budge to come off. Very frustrating!
  • 62 Answers
I am not familiar with this brand, but I will be glad to try and help you. Did you put the bag on, or did it come out of the box with the bag on? Any idea if it twists and locks, or does it have a latch on each side?
Posted on Oct 24, 2008
How do I, get the outer bag off to replace it.
Do you have a bag dock that holds your paper bags? If you do, squeeze the bottom of the part that goes around the bag opening so that you can remove the hinged part and then you can spread the first part & take it off & then remove the bag. If you do not have a bag dock, there is a "U" shaped metal clip that goes over the opening on the connector assembly. Remove that clip & that will allow you to remove your bag. Hope this Helps!
Jan 19, 2015 | Oreck XL Ultra Bagged Upright Vacuum
We are needing to remove the tie end rod from the front right side of a 2001 toyota sienna and it is not budging, how do we get it off
Loosen all nuts and use some penetrating oil if tough. Sometimes some heat on the nuts will allow them to budge. If you mean getting the tie rod out of the steering knuckle, then use a good 3 lbs hammer and hit the knuckle where the tie rod is wedged into. dont go crazy, but a good solid even hit until it comes loose. The vibrations from hitting will allow the tie rod to pop out like nothing. may take a few hits depending how hard and how long the part has been in there. Hit the knuckle inline the the main part of knuckle to prevent breaking off the ear. do not hit 90 degrees of how the knuckle sits, the ear may break if you go too hard.
May 06, 2014 | Cars & Trucks
The tie end rod will not budge.
You need what is call a pickling fork to remove tie rod ends. If you have a small enough jack you can jack up the tie rod end from the bottom putting the jack under the tapered bolt. Jack it up and put a good amount of pressure on it and hit the knuckle with hammer where the tie rod goes through the steering knuckle. You may be able to rent a pickle fork, or they sell for around $20 dollars.
May 06, 2014 | 2001 Toyota Sienna Tie Rod End Replacement...
Need manuel for Worx Lawn mower
Sears Direct has manuals. Sorry, all I can find.
Sep 04, 2013 | Worx 19-Inch 24 Volt 17 Ah Mulch/Bag/Side...
Fan pulley nut won't budge
it may be reverse threaded
Aug 11, 2012 | BMW Cars & Trucks
Would i have to remove the over head cams to replace the tie rods on my 1999 chrysler 300m
Tony- No, you don't. If you are removing the tie rods off the steering ram, the best way to do this is to remove the shroud from behind the hood and just before the windshield. Remove the wiper arms. Lift the hood. Notice the phillips head or torx head screws that hold down the plastic vented piece that runs from fender to fender. Remove all of those screws and put them in a bag so you don't loose them. Take off the plastic valance and set it aside in a safe place where the kids won't walk on it and break it. Now, the good part: To the left and to the right of the steel support valance (for lack of a better term) there are 3-4 13 MM bolts holding down each side of the piece. Remove them and put them in the same bag. In the middle or just off center of this valance is yet another bolt, either 13 or 14 MM and it is a long one too. It supports the wiper motor. Remove it and put it in the bag too. Now carrefully lift the support off the car, thus exposing the wide-open spaces behind the engine. You can easily see the PS ram and the opposite ends of the tie rods. I have to do this very thing very soon to replace a bent tie rod tube. But while I am at it, I will replace the tube and both tie rod ends, since I'll have to take it in for an alignment anyway- and so will you.
After that is all done, replace all your parts from the bag onto the valances, bolt the wipers back down and GO!
Sep 23, 2011 | 1999 Chrysler 300M
Trimmer is one yr old. Battery was kept inside during the winter and now won't take a charge. I called the Worx service nbr. Waited for 35 min. Went on the website and can't...
You can buy replacement batteries on ebay. If you can afford it I would highly recommend buying a quality trimmer at your local hardware store. I have had experience with the Worx trimmers and they are just plain cheap.
Jun 06, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Worx All-In-One Blower/Vacuum/Mulcher Logo
390 people viewed this question
Top Worx Garden Experts
Tim Whalen
Wayne McNeil
john milligan
Are you a Worx Garden Expert? Answer questions, earn points and help others
