Question about Philips GEMINI P-601 Fan CooledStereo Power Amplifier Car Audio Amplifier
Why does my gemini p-601 fan cooled stereo power amp not say car audio amplifer
2 Suggested Answers
trintek
  • 111 Answers
SOURCE: gemini P601
the gemini p-601 is not bridgeable. you can select either speaker pair a, speaker pair b, or both pairs, but you can not bridge it without potentially damaging the unit.
Posted on Nov 16, 2007
Lower the fan speed on Gemini XGA-4000 Amp
Your card regulates the speed of your card?, then you can instal a same , only higer efficient fan or just lower the temp of the surrounding, lowering the fan speed ain't smart at the moment, since it propably needs the cooling. Can't you place a largercooling block?
Oct 22, 2014 | Gemini DJ Gemini XGA-4000 Power Amp
Power
USE PROPER GAGE WIRE CHECK ALL FUSES TO THE BATTERY,THE FUSE ON THE AMP,MAKE SURE YOUR CONNECTED TO ELECTRICALANNTENA POWER WIRE ON STEREO (ITS USUALLY BLUE WIRE OR OARNGE WIRE ON BACK OF STEREO)BE SURE YOU HAVE A GOOD CLEAN METAL TO METAL GROUND WIRE CONNECTED TO BODY CHASSIS///SOME NEW STEREOS HAVE DIFFERENT WIRES ON THEM FOR CONNECTING AN AMPLIFER BE SURE TO CONNECT TO THAT WIRE THE REMOTE AMP PWR WIRE
May 25, 2013 | Kicker 06ZX750.1 Car Audio Amplifier
12 volts to amp, when connected no volts, it turns on in my friends car.
The ampliflier require an amount to power volts to perfrom. You friends car may have a power stabilier installed to produce appropiaet supply to stereo systesm. usually, a direct wire from the engine to the amplifer may least function as manufacturers default specifcation. If the amplifer performs at all, a fuse is blown to protect the devices in wiring cuircuits. if the device functioned in another car, it is not damaged. Consult with an auto electrician to attain appropiate wirign or acqurire the component parts to wire the vehicle. Important notes. Each device usually will have an instruction on installing. However, the power source from engine depending on type of vehicle may require regulators to share the current to stereos amplifiers and speakers.
Jan 29, 2011 | Clarion APA450 Car Audio Amplifier
I have a pioneer car stereo-12V DC, a sony xplod amplifer(2 chanel)-12V DC and I want to use them in my home, what kind of power supply will I need?
You want to use a 12 Volt power supply. This takes your 110V power and converts it to 12V power. Which size you need completely depends on how powerful your amplifier is. Your stereo needs about 10amps of power and looking at the fuse size on your amp, you need to add thses to the 10 amps for the stereo and this will tell you what kind of power supply you are looking at.
Aug 09, 2010 | Pioneer Car Audio & Video
How do i wire up my amplifer into my car
cable to battery, cable to ground(in the trunk somewhere. rca cables and remote wire from the back of the car stereo.
Aug 04, 2010 | Legacy 2CH 1000W AMP Car Audio Amplifier
Car audio amplifer blowing fuses
why are you in stereo for subs? mono all the way.
Feb 21, 2010 | Kenwood KAC-7252 Car Audio Amplifier
I want to use my 901 speakers with the yamaha rx 797 receiver and also my bose 601 in same room can i do that?
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver2_bing.gif will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers2_bing.gif and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers2_bing.gif.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier2_bing.gif that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
Jan 05, 2010 | Yamaha RX-797 Receiver
In need of the wiring diagram with values
contact the company that makes the amplifier. I have bought schematics from car stereo manufacturers before, it shouldn't be a problem.
Mar 28, 2009 | Philips GEMINI XG-3001 Fan...
Gemini P601
Oct 27, 2007 | Philips GEMINI P-601 Fan CooledStereo...
Philips GEMINI P-601 Fan CooledStereo Power Amplifier Car Audio Amplifier Logo
Top Philips Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Philips Car Audio and Video Expert? Answer questions, earn points and help others
