Question about Sony STR-DN2010
How to reset sony str dn2010
How do I reset my sony str dn2010
2 Suggested Answers
  • 94 Answers
SOURCE: sony str db870 master reset
If the power of the Receiver is ON, press Power to turn OFF the power. Then, hold down the MODE + button and press the Power button together.
S.F Intialize appears in the display and all sound fields are reset at once.
Posted on Sep 22, 2009
How do i reset a sony STR-K740P receiver??? - Sony Str-k740p Radio Receiver
Tuner reset
You can change the AM tuning scale to 9 KHz or 10 KHz. After tuning in any AM station turn off the receiver. Hold down the Preset tuning + and - ve together.
All preset stations will be erased when you change the tuning scale. To reset the scale to 10 kHz (or 9 kHz), repeat the procedure. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 12, 2016 | Sony Audio Players & Recorders
Is there a main fuse? how do I replace it
Yes there always is a main fuse but it depends actually on what exactly are you talking about.
May 03, 2015 | Sony STR-DN2010
My Sony STR-DN2010 Shuts off When I turn up volume. Also, the HDMI Out to the TV stopped working.
The unit shutting down when you turn it up sounds like a bad speaker hooked up to it. That is the most likely cause. As far as the hdmi problem, with the receiver turned off, press and hold the power button until it says 'clearing' on the front panel. This will reset the unit. Many times it is just a setting that is messed up. If that doesn't fix the hdmi problem, then there is most likely a problem with the hdmi switching IC which will require that board to be replaced.
Mar 26, 2014 | Sony STR-DN2010
Remove protector
protector is to preurve the amp if you can rfmove the amp will suffet same as removeing the govener on diesel engine if its there its there for a reason
Aug 17, 2012 | Sony STR-DN2010
How to reset sony str-dg800 to factory settings
For the STR-DG800 you need to power off. Then hold power button 5 seconds. When "push entrer" appears on display push "memory/enter" button. System will turn off and reset.
Nov 17, 2010 | Sony STR-DG800 Receiver
Sony str db870 master reset
Sep 22, 2009 | Sony STR-DB870 Receiver
Sony str-DE435 Flash Protector
this is not a reset problem, you have a defective audio output, is either the outputs transistors or the drivers IC's ( integrated circuit) and sometimes if you are lucky is just loose connections on the drivers IC;s.
good luck
Jun 18, 2009 | Sony STR-DE435 Receiver
How to hard reset a sony str-DE898
I couldn't find anything about a Lock Code in the manual but here's the general setting-reset procedure:
Turn OFF the receiver
Hold down the I/0 for 5 seconds - "PUSH ENTER" appears on the display
Press ENTER
Apr 08, 2009 | Sony STR-DE898 Receiver
Protector message
The only way to reset protect is to eliminate the problem which activated it. Problem may be insufficient line voltage or unit's output circuit. Have unit checked out by prof, tech
Sep 30, 2007 | Sony STR-DE825 Receiver
Sony STR-DN2010 Logo
261 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
