Question about Watches
How to set perpetual movement-seiko 6a32-oo8o a4
Calandar on wrong date want to correct
  • 2501 Answers
SOURCE: Perpetual 100m 6a32. I had the battery replaced,
Try pulling the crown wheel (winder) to position 2 (1 is fully in, 3 is fully out and 2 is in the mid position).
Turn the winder anticlockwise slightly and this should move the date until it is the correct position.
Posted on May 04, 2011
pgh_pa_guy
  • 2992 Answers
SOURCE: changing the date on a timex perpetual calendar watch
You can download the Perpetual Calendar instructions from Timex's website here.
If you don't like clicking on a link, here's the URL:
http://assets.timex.com/instructions/perpetualCal.pdf
Hope this helps. If this solution has been what you needed, please take a moment to rate it a fixya, and thanks for asking here!
Posted on Mar 11, 2009
SOURCE: How to reset the calendar on a Seiko Perpetual calendar
How to boot a mp3 player
Posted on Mar 26, 2009
mcdevito75
  • 1970 Answers
SOURCE: 0512037FA Wrist Watch: how do you set the date in the window of a seiko 6...
mcdevito75 here, The stem should have 2 positions to set the DATE without haveing to cycle the watch 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it's first position, it may take practice so be patient, once in it"s first position you can easily change the DATE, change it to 1 DATE before the DATE you want. NOW! push the stem back in and then pull it out to set the proper DATE and time of day, your watch is set and will change on time, around Mid Nite.
Posted on Jul 23, 2010
  • 101 Answers
SOURCE: Hi, I am a seiko
If your watch stopped working while changing the time it can be for a couple of reason . One is i never set the watch between the hours of 11 pm and 4 am or else your movement can be damaged. The main reason is usually that the watch crown was not pushed all the way in to the first set . If the watch crown and stem is pulled out and not in the start position the watch will not run. Also after setting time you might need to reengage the watch by pressing on the jumper buttons on the top side of the crown they look like push buttons.
Posted on Oct 18, 2010
Is there any way that I can set my Seiko perpetual calendar watch at home?
What a great watch! It has a super-fine piezo-electronic motor to move the date wheel! Very cool. Its quite a show to go through the date/leap-year check, and then observe the watch catch back up to the correct time afterwards. Battery lasts ~five years.
I downloaded the manual (your model number on watch back) after a short search online (beware of trojans/viruses).
Setting after a battery replacement requires shorting certain pins inside the watch to set the leap-year, and date. The back unscrews, and may require the special watch-wrench, available online. I unscrewed mine VERY CAREFULLY with fine pliers, confirming that I was doing this in a clean, dust-free location. The instructions are quite specific, must be followed carefully to set up correctly. Have a fine wire jumper to set the leap-year. I learned this because I did not want to pay an inexperienced jeweler $100 to replace the battery.
Oct 13, 2014 | Seiko Watches
How to set date on seiko perpetual calendar watch
You can not set the date..it MUST be returned to Seiko for repair. A perpetual calendar watch does not lose the date if it does something is wrong. Seiko will repair for you.
Aug 11, 2014 | Seiko Watches
I put a battery in a seiko 8f33, the time and day are working fine.The date will not work. I have been thru the process of reprogramming. What have I done wrong???
Your watch has a perpetual calendar which can only be set from inside the watch using the touchpads around the edge of the movement.
This link is for the instructions
http://www.seikousa.com/support/ib/pdf/SEIKO_4F32_8F32_8F33.pdf
Dec 05, 2012 | Watches
Perpetual 100m 6a32. I had the battery replaced, and now the date is not square in the window. The window shows the bottom of todays date and the top of yesterdays.
May 04, 2011 | Seiko Perpetual Calendar with Dark Silver...
Hello. I have purchased a seiko premier perpetual snp025 watch. From the moment I opened the box the 2nd hand is moving consistently at 2sec intervals and it does not move normally every 1sec. Also the...
Two sec jumps is low power in the elec store,,, winds with movement back and forth as your arm would swing. Sometime the day date function is changed by pressing the small button type crown in slightly with your finger nail.it may have on or two detents if so it adjusts both functions. if not the stemcrown needs to be used to set day and button to set date.
May 09, 2017 | Seiko Premier KineticĀ® Perpetual Watch for...
Hi, I am a seiko 8f33 perpetual calendar watch. I just got it back from Seiko...had the battery changed and new band. the problem is that I tried to set the date and the watch stopped working. Does...
Oct 17, 2010 | Seiko SKA192 Wrist Watch
I have a Seiko Premier Kinetic Watch SNP005. The problem is that the date is supposed to change around midnight. Now the date changes around 9-10 in the morning. I have read the manual and the only...
Thank you for contacting FixYa.<br /> You will have to contact Seiko on this one. I would tell you to just change the date to the day before and then forward the time, but I think I would just contact them as it is such a delicate timepiece.<br /> <a href="http://www.seikowatches.com/technology/kinetic/index.html">http://www.seikowatches.com/technology/kinetic/index.html</a><br /> Best regards.
Aug 25, 2010 | Seiko Premier KineticĀ® Perpetual Watch for...
May 18, 2010 | Seiko 0512037FA Wrist Watch
Resetting the 'day'
Your Seiko has two pulls,first pull for DAY / DATE,and the second pull for the hour and minute.Just do the first pull then wind it clockwise for DAY and the counter clockwise for DATE.Feel free to ask whatever the result...
Hope this may help;
Regards,
VOTIT
Sep 03, 2008 | Seiko 0512037FA Wrist Watch
Watches Logo
409 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
