Question about Microwave Ovens
Kitchenaid microwave model#ykhms2050ss2
Light,fan and disply off when open door
MicrowaveSvc
  • 9047 Answers
SOURCE: KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Mar 11, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave runs with door open
I would say you have a failing door switch or the mount which holds your door switch is loose or broken. In most designs, it is the upper door switch that will produce these very symptoms when it is intermittent or its mount is broken or loose. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. Slamming the door, damage during shipping or transportation and sloppy manufacturing techniques or materials are the primary causes of trouble with the door switch mounts. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 22, 2007
fridgetech
  • 473 Answers
SOURCE: when I open my microwave door, it starts running
Yes it is running.  This should be checked by a professional for safety reasons.  If it is older I would just replace the microwave because repairs can be too expensive compared to a new one.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
SOURCE: kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
Posted on Feb 06, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Advantium 120 Microwave fan stays on, off only when door open
Looking at the schematic in the service manual here, I would say relay RY6 on the small sub PCB (relay board) has shorted contacts.
That's the relay that runs both the fan and turntable.
It's possible that it may be a bad connection or driving component on that board, but in my experience, it's virtually always a stuck relay.
The part number on the relay as shown in the photo is hard to read, but it looks like "OJ-SH-112LM".
I should have one of these or I can point you to one if you want to contact me with the exact number.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 31, 2009
Kitchenaid microwave open door switch does not work
on my microwave, the door sticks some times & I put my fingers under door on latch side & push up, & I can hear it release & open. other than that there may be a broken part. follow the link below.
KitchenAid Microwave Door Won Open
Jan 23, 2015 | KitchenAid Microwave Ovens
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
My KCMS1555SSS-2 will run only if I partially depress the door open button.
<- That is likely a loose, misaligned, or broken door switch or door switch mount.
You can find the support documents for this model here, including the parts list, which includes helpful exploded views.
Also see these help files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can order Kitchenaid parts from the Pros here.
Jan 05, 2014 | KitchenAid KCMS1555SSS Microwave Oven
Door open button won't work on KitchenAid microwave model YKCMS135H
Page 3 of the exploded view here shows the door open parts 24510L and 250201 (or 23551B if your full model number is YKCMS135HSS).
What look like part numbers seem to be reference numbers.
For further help you will need to contact Kitchenaid Canada here.
Sep 05, 2012 | KitchenAid KCMS1555RSS Stainless Steel...
My microwave displays time etc, but does not turn on
That model number from the tag on your oven should be KCMS1555SS0, KCMS1555SS1, or KCMS1555SS2.
We would need more detailed information about what it's doing or not doing.
Does it respond to key presses?
Does the inside light come on when you open the door?
Can you enter the cooking time?
What happens when you press "Start"?
Does it run but not heat?
Does it count down but the inside light and fan do not come on?
Please post a new help request with the model number and detailed sympotms.
May 25, 2011 | KitchenAid KCMS1555SSS Microwave Oven
Microwave exaust fan starts on its own
There's a humidity sensor in this microwave oven that turns on the fan automatically if it senses an excess amount of humidity (steam from cooking for example) to possibly protect humidity or moisture from building up inside the unit.
Apr 01, 2010 | KitchenAid KHHS179LSS Convection /...
Microwave high intensity light turning bright orange
You have a shorted grille relay on your control board. I can repair this for $69.95, which includes insured return shipping.
For details and more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | KitchenAid KHHS179LSS Convection /...
Microwave Fan won't shut off, no display
Depending on which brand you have I would think that the Thermal switch on top of the magnetron or one of the door switches has probably given up the ghost. However, if the display does not come on you probably have a micro or Psu fault on the display panel. Not to be attempted if you are not familiar with microwaves or electronics. Please unplug before opening. Good Luck, JUS004
Jan 05, 2008 | Microwave Ovens
KitchenAid KCMC155J
Mar 11, 2007 | KitchenAid KCMC155J Convection/Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
