Question about Boating
Johnson 40 hp outboard disassemble lower unit
How to disassemble lower unit
  • 11 Answers
SOURCE: Disassemble 88 SPL Lower Unit
I dont have a diagram to send you, but if you take the model number and serial number to you local Johnson/OMC dealer they have all the diagrams and have even photo copied them for me to use
Posted on Jul 24, 2009
Editor925
  • 285 Answers
SOURCE: 40 Hp Johnson outboard motors stalls out after a
May likely be one of two problems:
1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
Posted on Sep 17, 2009
  • 57 Answers
SOURCE: I want to disassemble the lower unit on the 115hp
you actually want gear housing exploded view and/or lower unit mid section exploded veiw-i have the mercury service manual for the inline series 75 thru to 150 2 strokes-but my printer/scanner down at moment -hopefully fixed this week so will be able to scan and send to you
Posted on Oct 15, 2009
SOURCE: how to remove the lower unit on a 35hp Johnson outboard yr 2000.
if you haven't fixed this already, take the pastic water pick up covers off there are two joiner nuts in there undo them, there is a plastic cone on each end take them off and it will slip through. I own the same model and year outboard.
Posted on Jan 13, 2010
  • 159 Answers
SOURCE: lower unit removal for johnson 225 hp outboard
Yes
Posted on May 19, 2010
Testimonial: "ill give a go in the morning thanks again"
How to tune up 15 hp Johnson outboard
For minor tune-up. Remove, clean or replace spark plugs. Use Johnson recommened fuel additive and recommended fuel type. Replace lower unit grease. Spray clean carburetor. Check fuel line and filter. check water pump function.
Oct 14, 2017 | Johnson Boating
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views ยท 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
No water flowing out my 40hp envenrude outboard water exaust port
Plossibly clogged intakes (grim in intakes) or thermostats not opening. I would suggest pulling the lower unit and then your thermostat housing and use a water hose to back-flush it out. Also check the thermostats in boiling water to make certain opening.
May 09, 2014 | Clymer Evinrude/johnson 2-40 Hp Outboards...
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
I have a 1998 Johnson 130 hp outboard motor. Have already taken lower unit off but can't get it apart. Is there a secret to taking the lower unit apart? I would like to have a diagram.
Here is a site where you can purchase the service manual to repair your outboard motor:
http://www.tradebit.com/G/manuals/-/0-0-johnson+130+hp
Jul 13, 2011 | Computers & Internet
How to remove the lower unit on a 35hp Johnson outboard yr 2000.
Dec 30, 2009 | Boating
1985 40 hp Johnson outboard wouldnt open up and
sounds like your mix is off and it's fowling the plugs. probably too rich. make sure the level in your carb bowls isn't too high. Really sounds like you should clean and bench set your carbs. Especially if a plug change helps but doesn't last, then it's got to be your fuel mix, or maybe timing.
Jul 16, 2009 | Sport & Outdoor - Others
Boating Logo
228 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
