Question about Yahoo Messenger
Will not load correctly
I have tried several times (unsuccessfully) to load this program. I ceep getting the same error. "Incorrect command parameters" I have no idea what this means or how to correct the problem. At one time I did have yahoo messenger installed on this PC without problems but now cannot get it back. I have deleted and uninstalled every yahoo program on this PC and tried to start fresh but to no avail.
  • 507 Answers
See if your computer has a virus or a trojan
http://www.kaspersky.com/virusscanner
http://housecall.trendmicro.com/
clean the craps out of your computer this one's a free cleaner
http://downloads.phpnuke.org/download/cclearner.htm
there's an uninstall tool inside that one too called ccleaner use that as well to make sure every instance of old version of ym are removed and deleted.
then download a clean one and install
http://messenger.yahoo.com/download/
Posted on Oct 24, 2008
Trying to reinstall xp sp3 but it gets stuck on kernel ****** dll
Dll errors occur due to various reasons incomplete installation or removal of a program, missing, corrupt, or incorrect .dll file paths, and more.
Failure to fix these errors can result with severe PC problems
If you can't run the chdksk utility in normal mode try it in safe mode
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
hope this helps
Oct 17, 2012 | Dell Dimension 2400 PC Desktop
File system error 65535
I would suggest you to run a SFC scan on the computer.
1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.The access the drive by typing command for example - if you are facing trouble in C drive type C:
2. Type the following command, and then press ENTER:
sfc /scannow
How to use the System File Checker tool to troubleshoot missing or corrupted system files on Windows Vista or on Windows 7
http://support.microsoft.com/kb/929833
Also try running a Check disk on the computer.
Check a drive for errors
http://windows.microsoft.com/en-us/windows7/Check-a-drive-for-errors
Hope this information is helpful. Please let us know if you require further help.
Regards
Sep 10, 2012 | Western Digital Elements powered by WD 320...
System Commander 9 fails setup
Have you tried loading System Commander 9 without Linux? the reason I ask is when you run a dual operational systems there tends to be issues that come up with certain programs, there have been to many problems with this type of settup.
Apr 17, 2012 | Computers & Internet
I have windows vista home premium OS on my laptop, when I try to update windows to install SP2 I get error code 490. How do I install SP2 pls advise.
Hi
Try running an SFC scan,
To do this, follow these steps:
  1. Open an elevated command prompt. To do this, click Start, click All Programs, clickAccessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  2. Type the following command, and then press ENTER:sfc /scannowThe sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Dec 14, 2011 | Dell Computers & Internet
Every time I attempt to load a new program-Recovery commander starts and I can not load a new program. Deleted program-problem still exists
Try setting your computer back to when it was working correctly. To do this do the following:
Go to start
All Programs
Accessories
System Tools
System Restore
Click Next
Follow the prompts and choose a date from the list when you know your computer was working correctly
This should work for you, let me know if you need further assistance
Please leave rating/feedback if you found this helpful, thanks!
Lori
Oct 17, 2010 | Vcomm Recovery Commander (804526023624)
I am using Vista Premier. My Streets & Trips
uninstall. type regedit in run. In the left pane click HKEY Local Machine. Find Software and Click. Find Streets & Trips Delete it 'All". close the box. clean your drive. Restart & reinstall
Jul 30, 2010 | Microsoft Streets & Trips 2009 Full...
Wont down load yahoo messenger
Try clicking on start,control panel, add and remove programs, uninstall yahoo all the way and try reinstalling it again. Hope that helps.
May 25, 2009 | Yahoo Messenger
Side-by-side configuration
The "side-by-side" component is associated with the Vista Windows Resource Protection (WRP). You may have a corrupted file in the SxS folder.
To resolve this issue, use the System File Checker tool (SFC.exe) to repair these files.
1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as Administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow/Continue.
sfc /scannow
(The sfc /scannow command scans all protected system files and replaces incorrect versions with correctMicrosoft versions.)
This may take some time to run, so be patient.
Hope this fixes the problem.
Apr 07, 2008 | Acer Aspire 3680 Laptop
Yahoo Messenger Logo
78 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
