Question about Dishwashers
I have a kitchenaide model kuds24sewh5 dishwasher that the drain pump will not shut-off. what is wrong?
SOURCE: need reset code
Go here to see instructions to reset circuitboard:
http://www.flickr.com/photos/zenzoidman/389141915/in/set-1155952/
Posted on Jul 15, 2009
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
dutchman05
  • 487 Answers
SOURCE: dishwasher doesn't drain completely at
filter or pump are obstructed. Clear out both and it will run. If not you pump is broken
Posted on Apr 26, 2008
  • 220 Answers
SOURCE: How do I reset modelKUDS24SEWH5
Push these buttons in this order High temp wash>Heated dry>high temp wash>heated dry  it may freeze up again if there is an issue somewhere.
Posted on Sep 13, 2009
  • 128 Answers
SOURCE: Kitchenaid dishwasher will not turn on or drain
Float valve is jammed.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Not working?
Check for a clog internal or external.
Scoop as much water our as you can. Open the cover on the floor of the machine. Usually just turns and lifts out or snaps out some are screwed in. Take your time and try not to force anything. Look for a clog there.
Check for clog in the drain. The dishwasher will connect to the drain under your sink and run either directly to the drain or into your disposal unit. Remove open the connections and look for a clog. Clear if necessary.
Not the clog?
Water is pumped out by the machine via an internal pump located under the base. If it fails the water will collect until it trips the float valve. First scoop out all the water from the machine and run it again. If water comes in and it runs to the point it fills again and trips the float then either the pump or timer is faulty.
Pump check.
Remove the machine. It will be held in place by screws directly into the counter top. You may have to lower it to get it out. The front feet turn with a wrench to lower.
Turn off the water supply. Run the unit again until you get to the drain cycle.
Connect a test light or voltage tester to the terminals at the pump. Check for voltage at the pump. If you have voltage replace the pump. If no voltage the timer is faulty.
Timer problem?
Some can be replaced as a unit others are integral to the control panel. Turn style can be replaced. Touch control can not.
For more help go to my more detailed tip "Dishwasher will not run. DW101 how to fix". Or click on my profile and you will find the link there.
Hope this helped you. Please take the time to rate this tip.
Thanks,
Adrian
Posted on Mar 17, 2010
Kitchen aid dishwasher m # kdfe304dss wont drain , can hear clicking sound from underneith.what do you recommend? 14 months old.
KitchenAid Dishwasher Not Draining - Model KUDP02CRBL0
www.repairclinic.com/RepairHelp/...Dishwasher/...-/KitchenAid-Dishwas...
See All Dishwasher Parts for model KUDP02CRBL0. Cause 1 Drain ... If the drain pump motor is not working, the dishwasher won't drain. To determine if the ...
How to repair a dishwasher, not draining - troubleshoot ...? 6:18https://www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYMost of the time if it is not draining, the garbage disposal is clogged or there ... If you have a newer model dishwasher that looks different from the one .... But with the help of your video, I was able to show her where her ... How to Fix a Dishwasher thatWill Not Drain : How to repair your home - Duration: 1:50.Missing: kdfe304dssDishwasher Repair-Will Not Drain-Part 2 - YouTube? 4:14https://www.youtube.com/watch?v=dYHTdzQrsBAApr 20, 2013 - Uploaded by Frosty LifeInstructions 1 Press the "Cancel/Drain" button on yourKitchenAid dishwasher after the Clean light comes on to manually drain the standing ...Missing: m ‎kdfe304dssReviews on kitchenaid dishwasher kdfe304dss
Jan 17, 2016 | KitchenAid Dishwashers
Kitchenaid kuds02frss1
The wash pump and drain pump are different. So it is likely the wash pump is choked and trips or the motor is faulty.
http://www.searspartsdirect.com/partsdirect/part-model/KITCHENAID-Parts/Dishwasher-Parts/Model-KUDS02FRSS0/0593/0130000/W0602076/00008?blt=06&prst=&shdMod=#
It is likely the flap valve (item 5) or the chopper (item 6) are damaged and could be replaced before you get to the wash motor.
Apr 17, 2014 | Dishwashers
KitchenAid fills and drains but won't wash
With a lot of such appliances, the pump motor runs one way to wash, reverse to pump out. Refusal to do this usually is a loose wire, poor connection in the timer, or a wire on wrong. Check the schematic carefully for that.
Nov 30, 2013 | KitchenAid 34 in. KUDP01FLSS Stainless...
I have a kitchen aid KUDS24SE dishwasher that I believe has a piece of glass stuck in the chopper. How do I get to it? I have the impeller out is there a repair manual online somewhere?
there will be a screen inside pump where food chopper sit here is a link showing the full schematic for your dishwasher piece by piece taken apart just choose the section and examine the sump area and you will be able to see how to get to the chopper If you have any further questions message me back and please remember to rank this opinion as to how it helpedin your appliance situation Thanks again
Rick
heres the link
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDS24SEWH5/0593/0130000?searchedModel=KUDS24SE&blt=
Dec 09, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
I just installed my kitchen aid dishwasher model kudco03fvss and it won't drain. There is standing water in the bottom of the dishwasher. It is a brand new appliance. There is no water going through the...
Hi, my name is Audrey. I am a KitchenAid employee and thought the following link might help address the draining issue you're having with your dishwasher:
http://kitchenaid.custhelp.com/app/answers/detail/a_id/84/kw/not%20draining/session/L3RpbWUvMTI4ODEwNzU5Mi9zaWQvOVEyalRzZGs%3D
If I may be of further assistance to you, you may send me an email through our customer service address,
KitchenAid_CustomerExperience@KitchenAid.com
and type 'Attention: Audrey' in the subject line. Please include your full name and model/serial number, and I would be happy to try to help resolve the situation with your dishwasher.
Oct 25, 2010 | KitchenAid KUDC03FVSS 23 in Builtin...
Sep 13, 2009 | KitchenAid KUDS24SE Built-in Dishwasher
Old dishwasher doesn't drain
Disconnect the drain line from the sink and put it in a pail.
Turn the timer to a pump out cycle and see what comes out of the drain.
If it still drains poorly, replace the pump impeller.
Mar 11, 2009 | KitchenAid Dishwashers
KitchenAid KUDK03ITWH dishwasher will not pump water out
Well,
You bought this on my birthday, so there can't be anything wrong with the dishwasher. :-)
1) Check that the drain hose did not get pinched during installation.
2) Check that the hose leaves the dishwasher in an upward fashion, to the bottom of the counter-top, before heading back down to the dishwasher connection.
3) Did the dishwasher ever work properly? And if it did, were you using the sink at the same time?
Reply back what you find out. Will be glad to help more.
Feb 02, 2009 | KitchenAid Dishwashers
Dishwashers Logo
Top Dishwashers Experts
