Question about Toshiba TZ50V51 50" Rear Projection Television
Protective screen for tz50v61
I been trying to find this protective or outter screen, for the longest time, can anybody help?
  • freightshake Oct 24, 2008
    Maciso, I am still looking for the protective screen.
  • Anonymous Apr 28, 2009
    I am having the same problem. I need to replace the outer screen. Where can you get this?
  • 125 Answers
I am very often buying tv if you still are looking for the screen let me know
Posted on Oct 24, 2008
  • Jose Posada
    Jose Posada Oct 24, 2008
    are you looking only for the protector screen or the whole screen assy including the fresnel and the screen
The outter screen is ripped/busted. Is it a replaceable part?
This part is called a protective screen and is part number: KR03265
It can be purchased from encompass.com using the above number for $206.39 plus shipping.
Hope this helps,
Dan
Mar 09, 2011 | Hitachi 57S715 57" Rear Projection HDTV
Toshiba big screen modle # tz50v61 , power light comes on but tv does not , light keeps blinking . when i try to power it up , light comes on and then starts to blink again . tv will not power up . VERY...
that sounds like it could either be a convergence issue, or power supply issue. If you go to the following link and leave them a email with your model number and symptoms they will help you identify which part you need.
http://servicemanuals.vstore.ca/
Apr 20, 2009 | Toshiba TZ50V61 50" Rear Projection...
How to clean inside of screen?
Your tv has two screens on it. The outter screen and the inner screen. The outter screen has a frame around it held on by clips. You can remove this outter screen by gently prying it from the tv. There is a small gape between the outter screen and the tv casing. When prying the outter screen be carefull not to dsanage the tv case or the outter screen frame. Take note of the location of each clips because you will need thses to put the outter screen back on. Clean with a good gentle screen cleaner, (Do Not Use Windex). Philips screen cleaning gel for plasma & LCD works very good. Install the outter screen back on the tv by making sure the clips line up and use light pressure to snap it back in place. Do Not Hit Outter Screen To Force Clips Into Place.. I do this on my tv about once every 6 months or so.
Jan 04, 2009 | RCA P61960 61" Rear Projection Television
Cracked screen on my Toshiba TZ50V61
maybe I can get you one but I need the sizes in inches by the way some tv has more than 1 screen can you tell me if all of them are broken? I was unable to singn in for a while due to a problem in the system
Oct 13, 2008 | Toshiba TZ50V61 50" Rear Projection...
I need to the outer protective screen for TZ50V61 too
did you make sure that the others screens are ok?I think there are three
Jul 28, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba tz50v61 replacement protective screen
Andrews Electronics
www.andrewselectronics.com
25158 Avenue Stanford
Santa Clarita, CA 91355
  • Phone: (800) 274-4666
  • Fax: (800) 289-03
Apr 09, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba model tz50v61 convergence
need to repleace convergence ic # stk392-110 or stk392-160 on hitachi brand
Mar 16, 2008 | Toshiba 42H83 42" Rear Projection...
Need a new screen
Check out PACPARTS.COM..They have a lenticular screen in stock for 117.00..Type in the model number of the set and you can see a list of all replacement parts. Hope this helps
Oct 10, 2007 | Toshiba TZ50V61 50" Rear Projection...
Black lines and menu problem
Check for bad caps in vertical circuit. Solder any/all bad connects. REPLACE vertical o/p IC w/OEM or better quality. I usually use Tosh,Hit,or Pana. 2)Check/replace tactil switch (menu)on front panel.
Sep 28, 2007 | Toshiba TZ50V61 50" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
138 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
