Question about GE WVSR1060A Top Load Washer
GE top loading washer water tub off kilter - GE WVSR1060A Top Load Washer
Oceti
  • 51 Answers
SOURCE: GE WHRE5260E1WW Washer
The mixing valve needs to be replaced. It should be under $50 and is easy to do.
Posted on Jan 23, 2008
SOURCE: GE Front Load Washer
Had the same problem and did 2 things to fix. Remove the bottom panel on the washer(3 screws on bottom front). Just to the right of the center is a white plug that you can unscrew. Before you unscrew, get an 8x8 cake pan underneath to catch the water that comes out(bigger if there is water stuck in your washer). Unscrew cap and take out filter. My filter had pocket change, bandaids, tape, hairpins etc in it(kids do their own laundry and aren't vigilant about checking pockets). Screw filter back in and put panel back on.
Also, lint was drying on washer tub viewing glass where gasket hit it. Gasket wasn't making a good seal there and thats where water leaked out. Clean the dried lint off. No more leaking for me.
Posted on Aug 10, 2008
Macintoast
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
  • 512 Answers
SOURCE: GE top loading washer does not spin out water
The belt could be broken, if not. Unplug washer for 2 minutes, plug back in, open and close lid 7 times, this should reset electronic motor.
Posted on Jun 12, 2009
  • 9 Answers
SOURCE: GE washer will NOT spin, but does all other functions.
You need to have the fan belt checked. It must have been loose or broken.
Posted on Jul 22, 2009
Leaking into wash tub
The water inlet valve needs to be replaced. It is not sealing.
Here is a link to the part you need.
Aug 13, 2012 | GE Profile WPRE6100G Top Load Washer
My ge washer shakes alot
The washer has 4 rods that support the tub for suspension and four rubber straps to keep lateral movement to a minimum. With time the straps which are called bungys get stretched and worn out. Some times water sloshes over the top of the tub . SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 12, 2012 | GE WJRR4170E Top Load Washer
GE WBB4500EWW Top Load Washer throws water out of the tub and out of the drain tube when I start spinning a super sized load.
Must be bad bungys.deb6c74.jpgOver time these stretch and allow too much lateral movement. 0932956.jpg
May 31, 2010 | GE WBB4500EWW Top Load Washer
Low water level in top load washer
Load selector switch has a hose attached to it that goes to bottom of washer tub. It is probably clogged with soap. Open top where switches are, disconnect tube and blow it out. Problem should be solved. The only other thing it could be would be load selector switch has gone bad. But I am betting tube is plugged.
Feb 25, 2010 | GE WBSR3140DW Top Load Washer
My washing machine tub is off kilter, the water runs in, that's all. It worked fine, washed, rinsed & spun last load, & now won't rotate or move, please tell me what to do?
There are 4 support arms on this unit and the tub has popped off. Using a flat blade you will need to locate and push in the locking tabs for the front panel. 1 on each side and when you locate push in while pulling the front panel toward you on that corner. You will then be able to see the support and with help from someone. 1 of you lift the tub up and the other will slip the rod back into position. You can look at any of the others to see how it hangs. Hope this helps and good luck.
Feb 24, 2010 | GE WBSR3140DW Top Load Washer
I have a top load GE model #WBB4500G, and our clothes comes out smelly. It is horrible. We are constantly having to rewash clothes, this is rediculous. I've heard of this problem with front loaders, but we...
You have an inner and an outer tub. The outer tub may be holding too much water. The smell may be the soured water in the outer tub. You should take the washer outside and drain it completely. Then replace the drain hose before you put it back inside. Hopefully, this will slove your problem.
Sep 04, 2009 | GE WSXH208A Front Load Washer
Drain hose on GE washer clogged with sand
Hi, It is easiest if you have a wet/dry vac and **** the water out of the tub. You can also try and **** the water out of the drain hose and hope the plug is small enough that it breaks lose. The most common place the hose gets plugged is where it narrows after the pump going out the back of the washer.
I hope this helps you.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE WDSR2080D Top Load Washer
GE WJRR4170 washer comes out of overflow tube on super load. It does not on Large load size. I have the front off and can see a large difference in water level from large to super size. Is this adjustable?
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
Mar 15, 2009 | GE WVSR1060A Top Load Washer
You can hear water still in the washer - not inside the tub where you put the clothes but inside the washer machine.
I believe you are referring to a GE top loading washer. GE uses a liquid filled balance ring around the top of the washer to help compensate for off balance load. The sound is perfectly normal.
Aug 28, 2008 | GE Washing Machines
Worn outer tub
yea youl need to replace the tub alright, cgances are the bolts holding the inner tub to the transmission shaft have also broken off, which is why the inner tub spun off kilter and rubbed a hole in the outer tub,. the bolts (2 of them ) woulds have benn locking the inner basket to the tranny shaft, visible after removing the agitator
Apr 14, 2008 | Frigidaire FWS1339A Top Load Washer
GE WVSR1060A Top Load Washer Logo
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
