Question about Amana ALW480DA Top Load Washer
Washer over fills model lw7503w2
Every thing works right exept it over fills it has a load size and reset tried that i think it could bu the switch but im not shure any ideas before i start using it as target practice
  • 46 Answers
Hi not common for the level switches to fail ,check the small hose the feeds the controlfor holes or kinks or blockages
cheers grant
Posted on Oct 23, 2008
My ge top load washer wont start already change out board. not sure if my lid switch or magnet is bad?
Sure does sound like your safety switch isnt working. To be sure please give me model number to unit and I can do some checking and get right back to you
Apr 11, 2015 | GE Washing Machines
Maytag top loader won't agitate. will fill and spin
Try this:
When the washer should be agitating, try turning your load size switch back and forth a few times. If you are on a medium load, going to a larger load should cause it to begin filling again, going to a smaller size should start the motor for agitate. If this works, your pressure / water level sense switch is okay, but the switch for load size is faulted / or is on its way out. If you went from a medium load, to a higher load, then your pressure switch is faulted as well.
Sep 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machine wont recoginze the load amount to fill with water, ex..small, med, it justs keep filling up to the brim??
Sounds like your problem is one of three things. Most common is that you have to "reset" the water level. This is done by turning the water level knob passed the large load size, and then down to small. Any time you want to go to a smaller sized load, you have to do this. Another possibility is that the pressure switch is bad, this is an easy fix (although not as easy as the reset) The switch can be purchased thru a local parts supply house. And the last thing could be a bad water valve. This will leak and continue to fill the washer after it is already full, this however is usually followed with water all over the floor. If it is not the reset, write me back and I'll walk you thru the other repairs. Hope this helps!
Dec 08, 2009 | Maytag Performa PAV2200
What does the ''Reset'' position on the ''Load Size'' knob do?
if you have filled machine to say small water level and change your mind you turn to reset and then set your new level hope this helps
Nov 06, 2009 | Coffee Makers & Espresso Machines
My washer will not spin.
hi..the reason to this problem is probably due to the
lid switch.
check this out..
thank you..
kindly rate my response..
Jul 20, 2009 | GE WBSR3140DW Top Load Washer
Will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Maytag performa pav2300
Just rehook the clear tube back onto the air dome (back right side of drum), drain any water from the drum, the refill, pressure switch will reset itself. Start to fill on small load size first, then move up when washer starts to be sure it reset all the sizes.
Aug 06, 2008 | Maytag Performa PAV2200
Washer will not fill
I had a problem almost like yours. The hose attached to the load size switch had a clog in it, and the washer wouldn't fill with water or spin. Will need to take the front panal off to check the whole line.
Jun 06, 2008 | GE WBSE2090A Top Load Washer
Washer stops in the middle of a load
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $25 and is fairly simple to replace if you follow the steps on the link below:
I hope this helps you. Please post back if you have need further assistance, or require parts.
May 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Amana ALW480DA Top Load Washer Logo
167 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
