Samsung p801 error code e6 - Washing Machines
  • 1 more comment
  • gao_tan Jan 28, 2009
    The washer fills up with water & when it goes to spin, it stops, beeps and says E6 on the display. When we change the setting to spin only, it will fill up with water to rinse, and then show E3, or will go to spin and display E6 again.
  • jmd87 Feb 02, 2009
    same problem...i try it empty and its happen again
  • Anonymous Mar 24, 2009
    Same problem here!
Were any of you guys able to fix this problem?
Posted on Sep 23, 2010
5 Suggested Answers
  • 6277 Answers
SOURCE: Samsung Front Loader P801 5
First the 'E6'. The only Manufacturer's decode I have for Samsung 'E6' is 'water temperature rising/ falling too quickly, check thermistor'. I would go through the balancing act (detailed below) and then see if it recurs. If so it's a service call I'm afraid ;-0(
Now the dancing
Although you say it's level I would recommend you try my method to make absolutely certain before considering something inside ;-0)
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly!
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Apr 07, 2011
  • 6277 Answers
SOURCE: Hi I have a samsung model
Although you say it's level I would really recommend you try my method to make absolutely certain!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 09, 2011
SOURCE: Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Posted on Dec 20, 2009
  • 3 Answers
SOURCE: I have a samsung sensor
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
Posted on Sep 22, 2010
What is error e6
e6 error air conditioner Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your e6 error air conditioner question. Get free help, tips & support from top experts on e6 error air conditioner related issues.
air conditioner e6 code Questions & Answers - Fixya
...one inverter 12k I have a DeLonghi one inverter and when I want to turn On the heater then the code error display E6 and the error code is Communication ...
1-Time Flash & E6 error troubleshooting, part 1 of 3 for ...
? 3:04
https://www.youtube.com/watch?v=sYNN1Rvc7r0
Dec 18, 2012 - Uploaded by MitsubishiHVAC
1-Time Flash & E6 error troubleshooting, part 1 of 3 for Mitsubishi Electric .... Ductless Air Conditioner ...
Jan 23, 2016 | Heating & Cooling
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
Lg top load washer e6
E6 is listed by Samsung as :- Water temperature rising/falling too quickly. Check thermistor.
Oct 21, 2012 | LG WFT1071TP Top Load Washer
Samsung Front Loader P801 5 years old - bangs and dances during spin even at low speed get error message E6 when it cuts out. No mention of E6 error in manual. Troubleshooting section of manual of no help....
Now the dancing
Good luck,
John C
Apr 07, 2011 | Samsung Washing Machines
I have a samsung sensor quick P801 800 front loading washing machine. It is giving me error code E6. Is this an easy fix?
Sep 14, 2010 | Samsung Washing Machines
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Samsung washing machine B1215J E6 error what is this
I have the same E6 error code and violent movement when in spin. have tried to level and such with the same results. Always acts like it's majorly unbalanced
Feb 08, 2009 | Samsung WF337AA Front Load Washer
Samsung P801.washer....Error Message " ED" WHY??
"ED" is a door open error. try Closing the door properly or else there might be jam at the door.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
1,591 people viewed this question
Top Washing Machines Experts
