Air Tools & Compressors Logo
Posted on Oct 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Generator won't start & now starter will not shut off when it has power
  1. Could not start generator.
  2. Generator is electric start.
  3. Even when key start is shut off power is still going through to start generator until battery runs down.
  4. After battery is dead hooking up a charger also tries to start generator with the key turned off.
Anonymous
Level 1:
Scholar:
  • Contributor 65 Answers
  • Posted on Nov 20, 2008
Anonymous
Contributor
Level 1:
Scholar:
Answers
65
Questions
0
Helped
29303
Points
98
I'm assuming the key ignition switch has been replaced with a new one. If this didn't correct the problem then the problem could be in the STARTER RELAY stuck in the 'on' position, or in the STARTER SOLENOID switch (located on the starter motor ) stuck in the 'on' position.
The STARTER RELAY should be located around or in a POWER DISTRIBUTION BOX . After locating the STARTER RELAY and gaining access to it, try hooking your charger or jumper cables, whatever way you want to power the battery to make the starter turn over, then while the motor is turning over then pull the STARTER RELAY out and see if that stops it from turning.
If it does then the STARTER RELAY is probably at fault and needs to be relaced. It the motor continues to turn over then the problem is more than likely the STARTER SOLENOID sticking in the 'on' position, and will need to be replaced. That should take care of the starter problem.
Next will be the 'not starting problem'. That could be fuel delivery, spark plugs, coil or ignition control unit. Would be so much more helpful to include date and make of an appliance when seeking help.
Anonymous
Level 2:
  • Expert 104 Answers
  • Posted on Oct 26, 2008
Anonymous
Expert
Level 2:
Answers
104
Questions
Helped
71601
Points
192
I have seen this happen in cars- the problem is most likel the ignition unit -they do not spend a lot of money on them in production. So here is what is happening . When you are putting key in and out metal filings are being deposited inside unit- this is now causing a short and draining batteries. Start here.This happened with cars a few years ago and they were catching fire in driveways.Call dealer and get replacement ignition- should be cheap fix. Good luck.
1helpful
I've a Honda eu3000is generator, new carb, new starter. It will electric crank but not start but I can pull start it.
it seems like your ignition switch may not be removing the ground while in the starting position try removing the ground wire from key switch if it turns over and start with key replace switch assy.
2answers
Can an electric starter be installed on a Troy Built 5550 watt generator model # 030245?
It may be possible but parts alone would make it cost prohibitive.
It would require a flywheel, alternator, rectifier, starter, battery, ignition switch, cables, and misc. plus labor.
Craftsman 5600 watt generator AVR Location? It does not appear to be inside the cover of alternator.
The most common cause of portable generators failing to produce electricity is from the loss of residual magnetism.
Generators work by moving electrical conductors through a magnetic field. Your generator does not have magnets. The magnetic field is created by taking some of the generator output voltage and converting it to DC and feeding it to a coil to make an electromagnet.
When there is a small amount of magnetism left over from the last time the generator was running, it is called residual magnetism. The little bit of magnetism is enough to produce a small amount of electricity. This small amount of electricity is needed to create an even stronger electric magnet. As the engine turns this magnet moving its electric field, through the stator windings, your generator produces even more power.
When the residual magnetism is lost, the generator will produce no power at start-up. This residual magnetism can be lost naturally from not being used or from the load on your generator being connected when the generator is shut off. It can also happen from running a generator with no load for too long.
Generators need to work and it helps maintain that residual magnetism. When they are running, a load should be connected to it. It helps create an even stronger magnetic field. Before you shut it off, turn off the switch or breaker to disconnect the load. If you shut off a generator with the load connected, it can essentially drain or demagnetize the electromagnet. Try and avoid running out of fuel.
How to fix it:
There are a few methods of restoring a generator residual magnetism
12 Volt Generator Battery Method
Locate the voltage regulator for your generator.
Unplug the two wires that connect to the generator brushes. Normally one is red and the other is black or white.
Connect the black or white to the generator ground battery terminal.
Plug in a light, turn on the generator breaker or switch and start the motor.
Connect the battery +12 volts (red cable) to the red wire on the terminals you removed for three seconds.
Remove your wires and replace the plug. The generator should now be producing power again.
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Try this again. Starter works fine, checked fuel line,sprk plg and cln carb, just doesnt fire
Try checking your oil sensor. These are common problem areas that will shut your generator down, and prevent it from starting.
2answers
Generator wont start up unless i spray starter fluid into it
This sounds like a dirty carbureator. Just bad enough that it won't start cold.
If my generator shut off due to low lubricant will it reset automatically? If not is there a reset valve/button?
The pull cord is like a starter on a car (separate from the motor/engine). If the pull cord will not turn it could be because the motor/engine is seized.
1helpful
Add electric start to dg7000 generator by Dewalt
This is really not an option. The engine would need a starter motor and battery and starting key switch. You will probably have to replace the unit with an electric start option.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Top Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
