Question about Brother MFC-5840CN All-In-One InkJet Printer
Cleaning My MFC-5840CN post unable to clean and it will not do any thing until that post is cleared . seems like you should be able to reset it some how. HELP
  • 2 more comments
  • OZARKMEDIC Nov 10, 2008
    THE UNABLE TO CLEAN MESSAGE COMES ON AND WONT GO AWAY, CANT GET THE MAINTENANCE/CLEANING FUNCTION TO DO ANYTHING IT BEEPS AND REPEATS THE MESSAGE.
  • lahori39 Nov 11, 2008
    can not print
  • Anonymous Nov 14, 2008
    unable to clean, see troubleshhot guide.?
  • Anonymous Nov 28, 2008
    digital read says UNABLE to clean...see the Troubleshooter but I've unplugged it and checked for anything in the machine, torn paper, paper clips etc and nothing is fixed.
Unable to cleane
Posted on Dec 03, 2008
My brother 5840CN. lit says unable to print. the manual says to take the jam out - there was no jam. Turn it off, then on. i did that. It still says unable to print, look at troubleshooting page
errr.....No, no it does not. The Manual says that "unable to clean" means one of two things.....
1. The MFC has a mechanical problem.-OR-2. A foreign obstacle, such as a clip or ripped paper, is in the MFC.
but regardless, I don't believe it *IS* a 'cleaning' problem per se.Try resetting the power purge counter.
Press menu > Mono Start > 4x Arrow up after another. All lights will flash.
1. Power clean - Press 7>6>4 >Mono? Start.
2. Power Purge: 7>6 >3 >Mono Start.
Press 9>9 to exit maintenance mode. Run a print quality test print.
http://www.brotherprinterrepair.com/cleaning-a-brother-mfc-420cn-printer-head/
Tallon41
Sep 16, 2012 | Brother MFC-5840CN All-In-One InkJet...
My printer Brother MFC-5840CN reads Unable to Clean What can I do
Welcome to Fixya
You need to clear the ink waste counter and clear the purge counter. Please see procedure below:
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 OK (the display is showing this message)
- now push the START button 25 times until you see PURGE: xxxxx
- Press 2783
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
Thank you for using Fixya!
Apr 20, 2011 | Brother MFC-5840CN All-In-One InkJet...
MFC-5840CN All-In-One InkJet Printer: Unable to clean...
I would like to know what exaclty are u trying to clean..
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/000200/000061/faq000261_034.html?reg=as&c=au&lang=en&prod=mfc5490cn_all&Cat=7
for a more detailed cleaning follow this HP document and check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01427322&cc=us&lc=en&dlc=en&product=3692888
May 18, 2010 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean
This is very common on Brother MFCs - they self clean excessively and when they've done a set number of self-cleans, they refuse to print and give the error message you quote.
There is a work around - you can reset the self-clean counter - but this carries a small risk the waste ink from cleaning that is normally stored insde the machine in a tank/sponge MAY leak out. I've done the work around on my Brother MFC and, so far, no leakage so if I were you I'd take a punt.
Just Google "brother mfc unable to clean" and somewhere in the results will be how to reset the counter - it's all done from the keyboard so no tools required.
Sep 07, 2009 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean
you might try cleaning the grid on the drum cartridge with a fine brush like a painters brush
Jan 13, 2009 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 5840CN "Unable to Clean" Message
I have the same problem, and it just started today, how do I fix this problem?
Sep 02, 2008 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean message in brother dcp-115c aio
I saw on this site codes for another MFC to clear memory and reset the cleaning unit count code to zero. It worked on two of my brother mfc 820cw units. The third mfc 5840cn had unable to print error message 46- nothing at Brother. they want you to take everything to a repair shop.they don't help at all. Then the error went to 4F when I tried toclear the memory.As Iunderstand that message- it means I have to replace the printer head. Have no clue where or what it is. But I can read a manual as well as anyone and follow directions to fix it! Can't be worse than it is now! Good luck
Jul 22, 2008 | Brother DCP 115C All-In-One InkJet Printer
Message window reads "unable to clean" and machine will not print period
Press:
Menu/Set, Black, Up arrow 4 times, 80, then press black until "Purge" appears on the screen, then press 2783, stop/exit, 99.
Jul 18, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN Unable to clean
- Machine off
- Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press the "stop" button.
- press “99” to exit the maintenance mode.
Apr 25, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
165 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
