Question about Toshiba Satellite A105 Notebook
The tool could not get HDD physical information.
Error 0100360000. Toshiba Sat. A105 - S2194
HARD DRIVE MK8032GSX
Laptop was turning off/on or going to off mode. I tried safe mode, last known config, etc, but it did not work. Notebook continued turning off/on, than I tried recovery disk, but after disk started and uploaded I got no second step to follow with. Screen was empty. I sow hard drive is very very slow and I left it overnight. In the morning, I got message described in the title subject.
  • Zoro22 Oct 24, 2008
    Yes, you right and this is what I did. Brend new HDD with 6 months warranty is 32.99 + $ 9.99 shiping.
  • 108 Answers
Laptop hard drives are usually the 1st to go when it comes to issues with laptops.
I would recommend replacing it. Roughly 50 bucks for a 40 or 60Gb laptop Hard drive. Install it and try your recovery cd again.
My wifes laptop is from 2001 and it has gone through 2 hard drives. Its just the way they are. Backup data, always!
G'luck
Posted on Oct 24, 2008
Testimonial: "Fixed"
  • Jerry Oct 24, 2008
    Cool =]]
Boot manager is missing on Satellite A105-S2051 laptop
Anything that the reps from Acronis did that you no longer want (together with all the information on the hard drive) can be got rid off by wiping the partition information on the hard drive. You will be given just such an option when you begin to install Windows 7 by booting off your Windows 7 installation DVD. You should not get any MBR error messages if you have correctly booted off an installation DVD. The errors you are getting indicates you are still trying to boot from a hard drive (that is probably "wiped clean" or new, and does not have an operating system installed).
Oct 08, 2017 | Toshiba Satellite A105-S2051...
Ports dosnt show up on device managere on Toshiba satellite a105s2194
Your hard drive is probably dead.However there are stillhopes for hard drive datarecovery.
Put the hard drive in a plastic bag to be compatible for the freezer. Freezingsometimes works to revive a dying hard drive, at least for a shorttime(Probable just about 20 minutes), but be sure that the bag is sealedtightly so that condensation and ice crystals don't form. Put it in yourfreezer for 24 hours that will do the trick. While it's still cold, plug itinto your computer.And you may be able to view it in 'my computer'. And you mayact quickly,because you may only have 20 minutes to recover your data off itand after that the hard drive is completely dead.
If it fails, you will have to go to a recovery office where supply datarecovery service but let's hope not because it will cost you a lot of money andwhether they can recover data is not guaranteed.
Here is a tutorial to guide you how torecover hard drive data.
Oct 10, 2011 | Toshiba Satellite A105-S2051 A105-S2194...
My Toshiba Satellite A105 was accidentally dropped on the floor. When I turned it on and after choosing "HDD" from the Boot Menu, the screen would display this: PXE-E61: Media Test Failure,...
Sorry but Unfortunately Hard drives (HDD) are very susceptible to physical shocks and can be damaged that way. It may be possible to take it to a repair center to see if they can salvage some of you data but their are no guarantees.
If you found the information helpful please rate my response.
Aug 07, 2011 | Toshiba Satellite A105 Notebook
ERROR: 01-0134-0000. The tool could not get HDD physical information. Please Press [OK] to turn off the computer. I CHECKED THE net 7 it says i have bad boot up sectors in HD Please help
Actually, the error-message is "worse" news than just having a few bad sectors.
It indicates that the electronics on the circuit-board under the "spinning" part of the disk-drive
are not returning any information, when queried.
So, the disk-drive is "dead".
If it still is under warranty, then exercise the warranty to get a replacement disk, at minimal cost to you.
Nov 02, 2010 | Toshiba MK1637GSX 160 GB IDE Hard Drive
I got a toshiba satellite A105-s2194.the screen will work up to bios screen,then nothing.
sound like a hard drive problem. Try to boot from a cd, usb drive.
run a hard drive rescue program.
Had the same problem with a 105-s2151. had to changed the HD.
Dec 17, 2009 | Toshiba Computers & Internet
I need the hardrive drivers mk1637gsx 160 HD SATA
Theres no such thing as Hard Drive Drivers
Restore disks are created to only work with the default hard drive that came with the laptop. Even if you bought an exact replacement it still wouldnt work as the restore discs looks for the unique serial number of the hard drive and therefore prevents people from using the recovery discs on other toshiba systems or non toshiba systems.
Id suggest borrowing another windows installation disc and using the key on the certificate of authencity on the bottom f the laptop to activate.You might have to ring microsoft to activate it but just explain whats happened and it should all go ok.
If you found this helpful , please rate my solution below
Kind Regards
1234s282
Jul 02, 2009 | Toshiba Satellite A135-S4427 Notebook
ERROR: 01-0134-0000. The tool could not get HDD physical information. Please Press [OK] to turn off the computer what can i do to escape this
Sounds like the HDD has fallen victim to Malware of the destructive type. Does the drive boot at all? If not use the software that came with it or go to the website and download a copy. You will have to restructure your HDD.
Jul 02, 2009 | Toshiba MK1637GSX 160 GB IDE Hard Drive
Toshiba a105 s2194 won't turn on.
Please try to remove the battery and just connect the power adapter to turn it on. You shoudl get the screen to work. After which, power off and then connect the battery back.
If this does not work, it maybe a hardware proble with the screen or the inverter
Mar 10, 2009 | Toshiba Satellite A105 Notebook
Replacing hd for Toshiba sat a105-s1712
Yes, a new Hard Drive is not parititioned or formatted so you will need the start up disc to partition and format the new hard drive for it to work
Dec 25, 2008 | Toshiba Satellite A105-S4004 Notebook
HARD DISK SMART IS BAD
Go to My Computer.
Right click on your hard drive and select Properties.
Select Tools.
Click "Check Now" to run check disk. If it finds any problems it will fix them.
Apr 10, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
325 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
