Question about White Sewing Sewing Machines
Troubleshoot Model W338 "Sew E-Z" Sewing Machine
Won't pick up bottom bobbin thread to sew stitches on fabric. Changing the direction of the bobbin case does not do anything.
5 Suggested Answers
sew dutch
  • 25 Answers
SOURCE: Top thread won't pick up the bobbin thread
re insert the needle, maybe you did not put the needle up as far as it is to go. Make sure the flat side of the needle is to the back of the machine. Without any thread in the machine hand turn the wheel and look to see if the hook of your bobbin would/could catch the thread (to see if timing is right)
then thread the machine and hand turn the wheel and see what it is doing.
Your timing might be off, but I do not think that is likely. Though it is possible that when the needle fell out, it hit something hard, broke, and pushed the machine out of timing. then you need to bring it in.
Posted on May 26, 2009
  • 26 Answers
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Posted on Aug 22, 2009
  • 980 Answers
SOURCE: Singer Golden Touch & Sew
Try a new needle first failing that you may need to retime the machine, you can email me for an attachment of instructions kendourof@yahoo.com
Posted on Aug 27, 2011
marigold1m
  • 3 Answers
SOURCE: singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Posted on Nov 28, 2011
I have the 9500 Memory craft sewing on tricot and the bottom side looks beautiful...top side is horrible...
Generally, when sewing machine issues appear on the top of the fabric, it is an indication of a problem with the bobbin/bobbin thread. Issues on the bottom of the fabric are generally top-thread related. AVOID using old or bargain bin thread. Try changing bobbins. Is it the correct bobbin? Make sure the thread is wound smoothly on the bobbin and no threads protrude outside the bobbin edge. Check that the bobbin is installed turning the correct direction and the bobbin case is threaded correctly. Also, the bobbin tension may need to be adjusted (probably a last option before having it serviced). If adjusting the bobbin tension, be sure to mark the tension screw setting BEFORE changing anything and then adjust only in 1/8-1/4 turn increments. A slight possibility is that the bobbin case is old and needs to be replaced.
Oct 17, 2017 | Sewing Machines
Tip
Sewing answers
manuals can be found at,
ManualsLib Makes it easy to find manuals online
singer manuals and support,
Customer Support
tips and hints,
Sewing Resources
how to videos,
SingerSewingCompany
presser feet tutorials,
SingerSewingCompany
singer replacement parts,
Replacement Part Availability
parts for ANY machine,
http://www.sewingpartsonline.com/
household machines,
Sewing Machines
industrial machines,
Industrial Sewing Machines
babylock,
http://www.babylock.com/support/faq
singer manuals.
Instruction Manuals
Troubleshooting/Frequently Asked Questions
Please click on any question below to display the corresponding answer.
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
on May 24, 2015 | Sewing Machines
I have a XL2600I and the top thread is only picking up the bottom thread about every inch. What can I do or replace?
try a new needle--use the right needle for the fabric being sewed
rethread the machine, using every thread guide
take the bobbin out of the bobbin case and reinsert it, making it sure it counter clock wise in the bobbin case
also could be a timing problem
Mar 15, 2016 | Sewing Machines
Why does the top thread sometimes picks up the hook and then picks up bobbin but bobbin then crosses over and makes a mess? Wont work
Basic Tips for All
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? n
May 21, 2015 | Sewing Machines
Y does my top thread pick up on hook and when it catches bobbin thread it gets tangled up on top of bobbin
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? v
I NEED A FOOT FOR THIS MODEL SEWING MACHING
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? c
Every time I try to pick up the bobbin thread, after I use it somehow the thread leading from the bobbin is getting cut and I have to rethread the machine every time.
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? f
May 17, 2015 | Singer Sewing Machines
How can I stop my material sliding around when I am sewing?
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? t
May 16, 2015 | Sewing Machines
Needle not picking up stitches
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? o
May 16, 2015 | Janome Sewist 525S Mechanical Sewing...
I have my grans Elna Contessa305, I am no expert sewer but know how to thread a machine correctly. However, the stitching at the bottom keeps getting knotted and making a big mess. I've re-thread
try changing the needle --one that is correct for the fabric being sewed
try a different thread
make sure the bobbin is inserted correctly into the bobbin case
and turned the right way.
make sure the top thread has not come off the thread take up lever
Feb 12, 2013 | Elna Sewing Machines
Sewing Machines Logo
285 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
