Question about Canon imageRUNNER 5000 Copier
E000014-0000 We have a Canon imageRunner 5000 that has continuously displayed this error code. I have tried to clear it using the "clear" trick but it keeps coming back over and over again. Can you tell me what the code refers to?
  • Anonymous Oct 23, 2008
    I have the same problem as of today. I turned off the copier yesterday, turned it on today and all is fine while the printer is warming up. As soon as the printer is warm, the Error code: E000014-0000 comes up. I have
    unplugged the copier to allow it to reset and that did not correct it. I would
    appreciate any help in resolving this major inconvenience. Thank you.
    cm in Oregon
  • weymanpierce Dec 17, 2008
    I have the same error code (E000014-0000) and the machine will not reset. The solution I found on-line is not very clear.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 32 Answers
Check the fuser motor is functioning it is called fixing motor check the conection the wire in motor is leak
Posted on Jan 28, 2016
Yours machine problems is heater section is very hard rotate so you are clean the top roller and bottom rollers by using thinner or kerosine
Posted on Oct 28, 2008
ERROR CODE E000350 001...
This is a fuser/thermistor error. You may have to get it serviced, but try to reset the error code using the following:
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Apr 20, 2015 | Canon imageRUNNER 5000 Copier
E0003-0000 or e0003-0002 how to solve it ?
just clear error using additional * then (2+8 same time) again * after this process in screen displays copier select then function in function menu clear in clear menu select all option one by one and press ok after each selection and restart ur machine....
if problem continues replace the thermistor in the heater section
Mar 02, 2012 | Canon imageRUNNER 5000 Copier
ERROR CODE E000004-0001 IN 8070IR COPIER
This is error given by the thermistors in the fuser. Not detecting a temp change or too much temp difference between the thermistor ( front edge and Middle ). You can reset it by going into service mode. Press additional functions, then 2 and 8 at the same time, then additional functions. Press copier, then function at the top of the display, CLEAR, then ERR, then OK. Power down the copier using main power switch. Wait a few seconds then power up again. If the error continues then you will have to have the thermistors replaced if the heater is working. The heater should give an E000 code if not heating up.
Jun 09, 2011 | Canon imageRUNNER 5000 Copier
I have problem canon ir 5000 e355,,....please help me
How to clear the error code:
1. Enter Service Mode: Press * Additional Functions, 2&8 simultaneously, then * Additional Functions again.
2. Then select the [COPIER] option. Under [COPIER], select the Function tab.
3. Under the [FUNCTION] tab, select the [CLEAR] option.
4. In [CLEAR] there is a selection E355-CLR. Select it and hit OK.
5. Reboot the machine.
If the error occurs again:
1. Make sure the connection is secure and tight to the Main-Controller board from the connector cable to the Serial Number board below.
2. Reseat the Main-Controller board into its slot.
3. Go into service mode and clear the error code as explained above.
* If the error still continues, you probably have a bad Serial Number board and it needs to be replaced.
Aug 27, 2010 | Canon imageRUNNER 5000 Copier
Error Message E000001-0000
its a fuser error high temp or lower temp
try to rest this error in *28* FUNCTION,CLEAR,ERROR then on off the machine
if the error the same try to replace tem sensor
Oct 28, 2009 | Canon imageRUNNER 5000 Copier
Error code 005 for canon GP 335 CONTINUES TO APPEAR
press additional function button once and press 2,8 buttons at a time & press additional function button again & execute the following
select <copier> <counter> <misc> <fix web> then press clear button on the display.
automatically the web counter will be zero , the proble also cleared.
Jan 27, 2009 | Canon imageRUNNER 210S Copier
E00002-0000 error code
clear the error from the service mode
Oct 25, 2008 | Canon ImageRUNNER 3570 Copier/Printer
E000001-0000 error code
it s a thermistor problem
to clear the error do the following.
press additionel functionel* button & press 2&8 at a time &press additionel functionel button* select COPIER>FUN CTION>CLEAR>ERROR>OK.
Aug 06, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
822 people viewed this question
old marine
old marine
