Question about Haier Dishwashers
Haier HDW100SCT flood switch activated how do I reset it?
5 Suggested Answers
  • 15 Answers
SOURCE: The flood switch has been activated on my dishwasher
Remove the bottom drawer by pressing in the tabs on either side of the drawer (bottom edge towards the front).
Dry out the compartment with towels and let air dry.
Posted on May 01, 2009
SOURCE: does the haier hdw100sct dishwasher have an
yes it should have it should heat the interior of the unit up, this will dry the dishes. The element is usually at the bottom.
Posted on Mar 30, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Haier HDW100WHT flood switch activated
Hi. In the bottom of the unit there is a float. I did not look up your exact model but this is pretty simple to resolve. There will either be a round or rectangular float in the bottom of the unit. They are always on the front portion of the tub near the door but can be on the left, center or right of the front portion of the tub depending upong the style of the float.
What has happened is that food particulae has gotten under the float and coated the float stem. All you need to do is locate the float and clean the stem and the bottom of the float. A pencil / easel paint brush works great or an old make up long brush. Yu have to be able to reach the float stem.
How the float switch works is that the water lifts the float and terminates the fill cycle of the wash or rinse by actuating a micro switch under the dishwasher.
Clean up the float and stem and it should work normally. To test the float you gently lift it listening for a click after about 1/2 inch movement. It should click as you let it down AND lift it up. Once you hear the clicks routinely your back in the dishwashing business. If after cleaning the float you still do not hear any clicks then most likely the float micro-switch has failed under the tub / behind the front kick panel.
Thanks for choosing FixYa.
Kelly
Posted on Sep 20, 2010
tbirdfan1
  • 3051 Answers
SOURCE: f1 fault shows flood switch activated, how to
Hello there
This is how i did mine
saved about 300 dollars
First thing I did was pull the front panel off the drawer, batch%2010-23-04%200031.jpg
Fisher Paykel DD602 dishdrawer with the front panel removed.
With that front panel off, I pulled the wire harness connectors off the main control board (lower right-hand side) to inspect for gookus. None found--my quest continued.
The next step to remove the botton drawer from the unit so I could inspect the flood switch. In order to do this, I had to remove the wire harness cover on the underside of the drawer. This is what the underside of the dishdrawer looks like with the botton cover panel removed:
Fisher Paykel DD602 dishdrawer, looking at the underside of one of the drawers with the wire cover plate removed.
With the bottom cover off, I could unclip the wire harness, fill hose, and drain hose. Then I unclipped the linkage at the back of the drawer and lifted the drawer off the slider arms. All this to expose the flood switch, shown on the left-hand side of the bottom panel in the picture below:.
Fisher Paykel DD602 dishdrawer with the lower drawer removed. The flood switch in mounted on the base, left hand side.
After noting the positions of the wires on the flood switch and removing them, I unclipped the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. With the switch housing out, I could ohm out both switches and both checked good. I inspected the contacts and noticed that one of them was oxidized, evidenced by discoloration.
and clean off the contacts. That'll restore the current flow for that circuit. ." So I cleaned the contacts and reassembled the dishdrawer. I ran the top drawer and...no F1 error code! I ran it several more times just to be sure.
Posted on Nov 23, 2010
Haier dishwasher stuck on auto wash
I think the flood switch has triggered which forces the pump to run continuously but does not take any other input. I am assuming it is the pump sound that you are hearing as soon as you connect power to dishwasher. The float switch is at base of dishwasher. You can press the disc visible near the filter sump. It should move up and down when you press it. If it is not moving then the spring is stuck and needs replacement. However if the disc is ok but you are still getting the problem, then you will have to check for flood switch failure. The flood switch is under the dishwasher and to access it you will have to pull the dishwasher out and lay on side. Make sure the mains power is disconnected and water inlet tap is shut.
see items 17 and 21 in this diagram.
http://www.searspartsdirect.com/partsdirect/part-model/Haier-Parts/Dishwasher-Parts/Model-DWL7075MBSS/3126/0130000/50037858/00001?blt=06&prst=&shdMod=
might be a bit slow to view.
Apr 19, 2014 | Haier DWL7075MBSS 24" Built-in Dishwasher...
Flood switch activated on haier dishwasher.
Check an clean filters first.
Check over flow pan if its that make sure you have towels down to catch the water.
Hope it helps
Dec 20, 2012 | Dishwashers
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Flood switch activated, intermittent beeping, motor will not turn off
Please confirm if it is a single or a double drawer.
How do you know the flood switch is activated? Do you have a display on your dishwasher and what is it showing? If no display then which lights if any on the panel are on?
Motor will not run if flood switch is activated in the fisher paykel drawer dishwwasher.
Nov 20, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Does the haier hdw100sct dishwasher have an inbuilt dryer to dry the dishes at the end of cycle? feel like i've been sold a dud
Mar 30, 2010 | Haier 24 in. ESD100 Built-in Dishwasher
Apr 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Haier HWM5TL E2
I looked at the Haier website and all other usual sources but could find nothing. I think you should e-mail service@haier.com.au with the same query. Good luck
Sep 30, 2007 | Washing Machines
Dishwashers Logo
356 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
