Question about Homelite Consumer Products Backpack Blower/Vac, Carb
Homelite back pack blower
Will not start
  • chasingsumme Nov 01, 2008
    i think it should say that by the time you pull it long enought to get it to run, that the energy to use it is gone. by back pack blower has been this way since day one. does not matter how much choke is given or how many times the primer bulb is pumped, mine is one year old used approx 20 mtimes, and even with a recent tune up it is no better, runs good if you can ever get it to start.
  • Anonymous Nov 17, 2008
    I have the homelite backpack blower and have encounetred the exact same situation.
Will not run at full speed long then,it luggs down and just wont run wide open . i have tryed adjusting everything.
Posted on Nov 21, 2012
HI,
Try this: remove the air filter cover and the foam filter. you should be able to see the inside of the carb. Toggle the choke lever and you'll see a brass flap close over the carb throat. open the choke and the flap moves so air can pass into the carb.. When choke is on, the flap must complete close and seet over the throat to effectively function. If seeting does not occur the air moves though carb and prevent cold start. If you see that the flap does not seet you need to note the area that is preventing complete closure. Once you know this just remove the flap (usually a small screw hold it to the toggel switch) from the carb. Use a small file to revome the area that is preventing full closure and reattach the flap. (go slow so that you do not remove too much of the flap; if needs to seet well for the function to be restored). After you reattach the flap toggle the switch to assure proper seeting. If you see good and complete closure you are ready to cover the air cleaner and start. 8-12 pumps on the bulb, full choke on the carb and 3-5 pull should be all that is required. One final note: before reinstalling the brass cab flap, clean it with paper towel so no shavings are pulled into the engine cylinder.
Hope this helps,
Ryan
Posted on Dec 11, 2008
  • 48 Answers
Not enough info - when was it used last - does it have spark- does it have compression etc
Posted on Oct 23, 2008
2 Suggested Answers
  • 7 Answers
SOURCE: homelite back pack leaf blower
Close both the high and low speed air screws (clockwise). Reopen each 1 1/2 turns
Posted on Nov 03, 2009
I would like to download a manual for my homelite back pack blower s/ n MB 2570715.
Go to manualslib.com and put in the model number and you can download or read the manual. Hope this helps.
Oct 03, 2016 | Homelite Garden
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
How to replace a trigger on the arm of a homelite 250 gas pack leaf blower
look up the service manual online. if you can get the trigger assembly it should be a straight forward replacement. only issue will be the getting the correct torx screws.
Aug 30, 2015 | Homelite Garden
Have a homelite "the Back Pack " best i can make out 0817h
IF U GOT 6 MONTHS TO A YEAR FROM IT YOU DID VERY WELL!!!
YES THERE IS A KIT, SEND ME THE BRAND AND MODEL OFF OF THE CARBURETOR. MOST COMMON KIT IS A ZAMA RB-29 BUT CHECK YOUR MODEL TO BE SURE!!
Nov 19, 2009 | Homelite Consumer Products Backpack...
Homelite ut08107 will not fire. no spark at plug.
It may be the coil if there is not any spark. Or a wire could off at the coil. One more thing it could be is the spark plug wire may have came loose from the coil. These a few thing to check.
May 04, 2009 | Garden
Need oil gas mixture for homelite HB 100 blower
50:1 with premium oil i.e. Echo, Stihl, Husqvarna.
40:1 with Homelite or generic brands
Apr 12, 2009 | Homelite Consumer Products MightyLite...
Homelite back pack leaf blower
Mar 20, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
683 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
Roland W VanLue
Roland W VanLue
Jay Finke
Jay Finke
Are you a Homelite Garden Expert? Answer questions, earn points and help others
