Question about RCA HD61LPW165 61" Projection HDTV
RCA HD50LPW62AYX2 50" - color wheel replacement procedure
Hi, I have a 50" RCA DLP with the model number HD50LPW62AYX2. I need to change the color wheel but cannot find any how-to's when I google it. Although, there seems to be a lot of info including how-to videos for Samsungs. I believe the color wheel part number I need is RCA 267888. Any information or pictures (depicting the location of the color wheel) you can give me would be greatly appreicated! Thanks, Mike
  • 1 more comment
  • michaelngai Jan 09, 2009
    Thanks for the information. I will attempt your steps first chance I get. Since I didn't know how to get to the color wheel, I did not order the part.
    Here's where I found the part,
    http://www.partstore.com/Part/Thomson/RC...
    I'll let you know once I take the TV apart. Thanks again!
  • Anonymous Feb 02, 2009
    I pulled the color wheel out of my rca tv. ordered a new one, it's back ordered so i decided to take my old one apart lots of black carbon?
    cleaned it out with wd40 a ,llittle silicone lube cleaned the color wheel with windex lol replaced it. oh **** it workes perfect. Don't know how long it will last but i'll let you know.
RCA 267888 Color Wheel: I ordered a new color wheel and it was back ordered so I took my original wheel apart, soaked it with wd-40 then blew it dry. (lots of black **** Carbon?) cleaned the color wheel with windex LOL, then replaced it. works great, don't know for how long but i'll let you know
Posted on Feb 02, 2009
REMOVE ALL SCREWS AROUND SCREEN AND REMOVE SCREEN. REMOVE 2 SCREWS HOLDING PLASTIC PIECE IN MIDDLE. GENTLY SLIDE OFF CIRCUIT BOARD (JUST GLUED FROM THE BACK). REMOVE PLASTIC PIECE TO EXPOSE OPTICAL CHASSIS. REMOVE THE LAST REMAINING SCREW FOR LIGHT FIXTURE. REMOVE 3 SCREWS HOLDNIN COLOR WHEEL. REMOVE RIBBON PLUGS AND REERSE THE PROCESS TO INSTALL. JERRY.(ROCKMANJV@COX.NET. LET ME KNOW HOW HAT GOES. i'M WAITING ON THE PART RIGHT NOW. WHERE DID YOU FIND YOUR PART? THEY ALL TELL ME THE PART IS ON BACKORDER. SEE YA!
Posted on Jan 06, 2009
2 Suggested Answers
SOURCE: 50" RCA DLP color wheel replacement procedure
Mine started to howl last year, I sprayed out the motor using carb cleaner / lubricant. Its been running fine for over a year since.
My guess is, the bushing gets plugged with dust particals. If you catch it as soon as it starts to squeek, the carb cleaner trick may work for you too.
Posted on Dec 06, 2009
I have the m50wh72s rca dlp....and will be changing my bulb with thanks to this site!.....but what about the colorwheel?...is it easy to change ?....and is it exspensive to buy?
The color wheel if used may no longer be available from RCA. With the exact model number GOOGLE the model number with the words COLOR WHEEL after it and if I remember some of the wheels were rather expensive.
Let me know if you have questions.
Regards, SD TECH
Sep 17, 2011 | RCA Televison & Video
50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
No Picture but sound
if you have a dlp with the 267888 color wheel, the wheels cant be replaced as RCA no longer makes them. If you use one of the other type color wheels you can get a replacement at the following link. They would need the model number of your set as The D52W19 isnt a dlp and doesnt have a color wheel. So just let them know what the model number of your set is.
http://servicemanuals.vstore.ca/
Jul 10, 2009 | RCA D52W19 52" Rear Projection Television
Instructions on How to change an RCA Color Wheel
You can get help at;
They will charge for manuals but they also give on-line tech support free!
Apr 06, 2009 | RCA HD61LPW165 61" Projection HDTV
My rca tv not working
the lamp which you rteplaced is not seated properly.and also it can be the problem of colour wheel or the ballast.to check out all three just check out this links 1 by 1 for colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
for lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
for ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Feb 09, 2009 | Toshiba 32AF41 32" TV
Oct 23, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA HDLP 50W151 scenium color wheel
They make two different color wheels for the Rca DLP are you positive you got the right one. As usually its a straight forward install no adjusting needed. Post the chassis number off the back of your set and I will try to help you out with it.
Apr 07, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW165 61" Projection HDTV Logo
1,570 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
