Question about LaCie Computers & Internet
Lacie Super Writemaster door will not open
When trying to put in or take out a dvd, the door seems to stick. Have been using homemade hook to pull it on out and just push on the door to get it to close all the way. Now it just does not want to open. Any suggestions?
techman
  • 3130 Answers
SOURCE: DVD loader mechanism
It is called the slider assy. The slider moves the laser assy back to home or start position. It is a small belt underneath or there is gunk or hair in the gear mechanism. A very common problem with CD/DVD players/recorders. Very good though that you saw it was not comming back to home place. I wish I had a manual to assist you but I do not. Im telling you the most common problems with the slider mechanism. Good Lck
Posted on Oct 09, 2006
techman
  • 3130 Answers
SOURCE: Dvd tray will not close
Sorry to say, but you pulled the bugger out of alighnment, and the only way to fix it would be to get a manual and see how it goes together, unless your very mechanicly inclinded and can figure out the loading mechanism. It may be a cam driven loading tray or a gear or belt driven. Also there are limit switchs that a part of the drawer hits to tell the unit when it reaches the fully open postion as well as the fully closed potion. good Luck Please do not forget to rate this thread.
Posted on Oct 20, 2006
SOURCE: dvd player won't open
I had the same problem for my panasonic dvd player (ht540). Neither of the above solutions worked so I found this one on the panasonic website:
1. turn off unit by holding down the POWER button for 10 seconds.
2. unplug the power cord and wait for one minute.
3. plug the cord back in and turn on the unit
4. when the dvd begins to play, press "EJECT".
It worked for me. The site for other troubleshooting is:
http://www2.panasonic.com/consumer-electronics/support/FAQs/details-FAQs+for+DVD+Recorders-UCM_PRD_CNT_001989#dvdrec6
Peter
Posted on Nov 16, 2007
kikoksky
  • 119 Answers
SOURCE: My writemaster DVD RW door wont close
try updating the drivers. if it will not work give me additional information
Posted on Jun 13, 2008
  • 3 Answers
SOURCE: Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Posted on Jul 08, 2009
What voltage is the LaCie Super Writemaster?
Refer its user manual for details. Its specification page will have all. Gopakumar Gopalan Google
Feb 11, 2015 | LaCie Computers & Internet
Firewire connector doesn't match
It sounds like you may have one of the newest MBPs that doesn't have a firewire port. If that is the case, it is still possible to connect firewire peripherals through a Thunderbolt to Firewire adapter cable.
Aug 06, 2012 | LaCie Super-writemaster Dvd Multi Recorder...
My Hp 1040i dvd writer won't play homemade videos I insert the dvd it detects the dvd but when I go to click the drive it just opens it like if it was a blank dvd you know like when you go to exlpore the...
installed POWERDVD program into your system unit and put the homemade video again and click on the powerdvd icon and click play button on it and it would start playing.
Nov 11, 2009 | HP DVD1040i 20x Super Multiformat Dvd...
Dvd burner drawer keeps opening.
did you try to use it in other computer?it is a simple test ,just to make sure that it is ok.by any chance, is there anything that obstruct the tray or something like that?
Jun 21, 2009 | Samsung Super-WriteMaster SH-S183L Burner
How to...?
the problem of your dvd -wr is only lose connection ,try to push the IDE cord at the back of you DVD-WR or else pull it and return
Oct 02, 2008 | Samsung Super-WriteMaster SH-S162A DVD?RW...
Writemaster door won't open.
your problem is a mechanical meaning you have to use a paper clip or any thin hard wire you can insert on the pin hole below the eject tray to manually open the disk tray. it will be wise to have it replaced since this problem will continue.
Jun 17, 2008 | Samsung Super-WriteMaster SE-S164L DVD?RW...
Computers & Internet Logo
52 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
