Question about Refrigerators
GSS25QSWC not freezing
Emptied, removed food and ice and turned off for a few hours. Turned back on but still doesn't seem to be freezing
  • 33 Answers
SOURCE: Freezer is not working. Compressor keeps kicking on ever few minutes
about $250.00
Posted on Jan 01, 2008
SOURCE: Hotpoint FFS70 fridge/freezer
water keeps appearing beneath salad bin we have checked to see that nothing has come into contact with back wall of fridge ,and we have used a straw to keep the defrost gutter drain hole clear but water still appearing beside gutter drain hole .
Posted on Mar 02, 2008
refritech08
  • 149 Answers
SOURCE: defrost timer
this uses a adaptive defrost board its located in the fridge compartment in the back left side remove the cover and you'll see the adaptive defrost board if you have any questions don't hesitate to e-mail me @ hvac.tech7872pr@gmail.com
here's an URL of the diagram (copy paste link to your browser)
http://www.partselect.com/Schematics/Frigidaire/XFXTKOQX.gif
Posted on Aug 02, 2008
jonniewalker
  • 1031 Answers
SOURCE: Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Posted on Mar 29, 2009
  • 5 Answers
SOURCE: Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
Posted on May 29, 2009
Freezer won't freeze and fridge side freezing vegetables
In the back there is a radiator and it is frozen solid, you have to deice it, unplug the fridge and take the cover off and remove the ice build up, hair dryer should do the trick, or leave it unplugged for few hours.
Tony
Dec 08, 2017 | Samsung RS2630WW Side by Side Refrigerator
Frigidaire FRS26LF8CS3 Side by Side, Freezer ice/cream melting, lower bin food side freezing
(There is a defrost heater on the evaporator in that area.If
you have a VOM you could check it with the power plug pulled out of the wall socket)
if you access the area turn the defrost timer on (clockwise)it should get warm in that area and you shoud hear a popping sound
If you want to tackle the job for yourself all the manuals are here
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FRS26LF8CS3&User=&Search=Search
Nov 27, 2007 | Refrigerators
Freezer too warm
First off, how old is the unit? Without knowing, my advice, and what has worked many times, is to unplug the unit, and turn it upside down. Thats right. Upside down. May take a couple or few people, depending on the weight. What this does, is to have the refrigerant begin running back to the top of the unit. Sometimes it settles in the bottom, and has to have extra help to start moving properly again. If, after about 6 to 24 hours it doesn't seem to have helped, it could be that you have lost the fluid, but that doesn't seem very likely. If you had, it would run consistently at the same warm temperature. If it helps, you may want to repeat the procedure to insure that it is completely free flowing. Cheap fix, if it fixes things. Good luck.
Nov 15, 2012 | GE Monogram ZFSB23DRSS 36" Monogram...
I have an Gallery series Fridgidaire side by side fridge, model number GLHS68EJSB0... the line to the water filter keeps freezing and unable to depense water... we have the setting on the fridge set to the...
We have the exact same problem. But ours is in a vacation home so we have to keep the water turned off all the time. It seems something in the ice line freezes when the fridge is empty. Then, no ice, no water. When we turn the water back on, after a few days of having food in the fridge, it seems to make everything melt and flood the tray then leak out onto the floor all day and night. The fridge temp goes down to 12 degrees when the fridge side is empty. It seems to stabilize when there are items inside. We put several gallons of water inside instead of leaving it empty and it helps with the temp but not with the leaking. We have had service come out several times and they just said, "don't leave it empty and turn off the water when you leave." What good is that? I don't have water or ice for the weekend when I go up to the house! OR I clean up floods the entire time!! Now it's out of warranty. Now that I see it happens to people in their main house, I would just say NEVER EVER EVER BUY FRIGIDAIRE AGAIN!
Sep 24, 2011 | Frigidaire FRS3R5EMB Side by Side...
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
HOOVER CLASS A FROSTFREE FREEZE HNMF 2805A L-80 FREEZER IS WORKING BUT FRIDGE INSIDE IS COVERED WITH SHEET OF ICE AND BLOCK OF ICE AT BACK FOOD AND LIQUIDS ARE FREEZING HAVE ALREADY TRIED TURNING DOWN...
I had same problem. Needed a new thermostat. Lasted about 18 months, then needed to replace fridge. Ice build up is between the inside and outside layers of the fridge as well. May just be more economical to replace. Cheers
Oct 26, 2010 | Hoover HCA331FFK
Maytag top freeze freezes food in the refrigerator section
this used to happen to me, it is accualy the ice macine make sure you empty the ice compartment regularly
Sep 05, 2009 | Maytag Refrigerators
Kenmore Side by Side not getting cold enough to freeze food.
Evap fan...cond..fan ...do they turn.....seems like a comp...problem...does the evap ice up...?
Aug 18, 2009 | Kenmore 57029 Side by Side Refrigerator
The Icemaker is not working
When the door was open thawing and freezing occurred and your ice maker is now frozen up. there may even be ice in the water line feeding the ice maker.
Empty the entire side by side and unplug it for 24 hours with both doors open. This will solve your problem.
Your cold and frozen food will have to be stored elsewhere during this process so nothing spoils.
May 28, 2009 | GE GSS22JERBB 34" 21.9 Cu. Ft....
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
