Question about GE Refrigerators
Gss25wgpa ww water line going from wall valve to refrigerator split and leaking
When moving the refrigerator into the house the white hose that connects to the wall water valve got hung up on door frame and split. When hooked up it started leaking water all over the floor. Can you tell me how to replace it?
catriver
  • 878 Answers
SOURCE: water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Posted on Dec 22, 2006
aborcass
  • 2651 Answers
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Posted on Feb 23, 2008
SOURCE: refrigerator leaks water down the inside
Usually when there is a leak you can follow the stream from the source.
But since you stated you checked the tubing for leaks, maybe you have a seal problem.
Try checking your door gasket, it may not be sealing properly, therefore causing condensation on the inside of the unit and either freezes in the freezer section or creates droplets of water in the refrigerator section.
Posted on Sep 22, 2008
  • 123 Answers
SOURCE: Water leak under refrigerator, Frigidaire, FRS6R5ESBC
chk out dis video
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Posted on May 14, 2009
localwonder
  • 6784 Answers
SOURCE: Maytag refrigerator is leaking water
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. This can, also, cause a run-off, as stated in your post. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
NOTE_It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Posted on Dec 13, 2009
Whirlpool refrigerator is leaking cold water from the lower left hand corner.
Behind the refigerator are valves and water hoses going to the water dispensor and the ice maker. Anyone of these hose could have a leak either at the connection or the hose. I would not attempt at repairing this unless you are real familar with this problem or appliance repair man.
Feb 16, 2013 | Refrigerators
How do I replace the water dispenser tube for a Kenmore Coldspot model # 106.53769201. The end of the line disintegrated at the spot where you put your glass under the dispenser.
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Jan 16, 2011 | Kenmore 57029 Side by Side Refrigerator
How do i turn off the water supply to the fridge if its pipe is leaking?
There should be a small valve behind the fridge. Pull it out from the wall, and look behind it with a flashlight. They are usually near the floor at the wall. Turn clockwise to close it. In older homes, the water line can be run under cabinets to under the kitchen sink where water pipes are..
Old installations use 1/4 inch copper tubing. Newer ones use 1/4 inch nylon. Some use flexible white hoses.
If you close the valve and it still drips, then the entire water system will have to be closed off to replace the valve. These valves and new connection kits are available at sears, home depot and lowes.
Jan 08, 2011 | Maytag MZD2766GES Side by Side...
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
GE Profile Arctica refrigerator - water is leaking from the bottom of the solenoid where the plastic hose goes up to the water filter (on the outside of the refrigerator.
Turn off the water supply and check for cracked or broken water tubing/line. Make certain that there is teflon (white) tape on threads connecting water inlet hose from shut off valve at wall to water valve at refrigerator. If there is no apparent damage to tubing or hose, then your problem may be with a water valve solenoid that is not seating/closing tightly. Replace the water valve assembly, if necessary.
Note: If plastic tubing is damaged, etc., you can splice the tubing with a "coupler" and/or more tubing purchased from Home Depot or Lowe's.
Feb 19, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Kenmore bottom freezer refrigerator warming up
Hi
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Regards
Berry
Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Water dispenses very slowly on Fridge
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The coil of tubing is normal so you can move the fridge out from the wall without damaging anything.
Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 14, 2010 | Refrigerators
Leaking outdoor hose bib
ok this is an easy one.  you have what is called a  frost free hose bib.  this is split or has a hole in it after the seat.  the seat is inside the house wall.  you need to cut off the copper inside the house and replace the valve .  if it is not a solder joint than have someone hold back on the copper on the inside and you should be able to spin it off and replace it.  P.S if this is the case make sure you use T-tape on the threaded conection
Jun 21, 2009 | Plumbing
Icetube leaking water inside freezer and outside back of freezer
Your refrigerator needs a new water valve and possibly some new water tubing. You can find the correct part by going to sears.com and entering the refrigerator's model number in the parts search field. When you have the valve, shut off the water to the refrigerator. If you're not sure how to do that, just shut off water to the entire house. Be sure to run the kitchen sink after you shut the water off to relieve any presure and double check that the water is completely shut off.
Be sure to unplug the refrigerator before you start this project...water and electricity aren't friends! Using a 1/4" nut driver or socket, remove the cardboard or metal cover off the back of the refrigerator. Follow the water line to the water valve, unscrew the nut going to the valve, and remove the water line. There are 2 screws holding the water valve to the refrigerator cabinet; remove the screws and gently pull the valve out. Unplug the electrical connectors and remove the water lines. Take the new valve, connect the water lines and electrical plugs, screw the valve back into place, attach the water line and turn the water back to to test for leaks.
Since the valve has been leaking inside your freezer it would be a great idea to clean out your freezer and let the water tube and lines thaw. Find a place for your frozen food, unplug the unit and let it sit overnight with the doors open. Don't forget to remove the ice bin, as these make quite the mess when the ice melts. Once it's thawed, plug it back in, make sure the water is on and not leaking and enjoy!
Jun 03, 2009 | Kenmore 57029 Side by Side Refrigerator
Wirlpool fridge leaking from filter
filter housing or the lines that are connected to the housing
have had a few of the lines that split i know it is hard to see under the fridge but you can remove the filter housing and unbolt the water valve from the rear of the ref and wangle thelines and housing to the rear of the ref to see where the leak is at
Apr 11, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
