Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Still operation when wet?
In my supreme incompetence, I didn't cap my snapple properly while it was in a purse along with my Powershot SD400. When I finally discovered my fatal mistake, my camera could no longer turn on and its lens was partially extracted. Will my camera ever work again? Or have I just committed camera murder via iced tea?
My cam got a little wet just a couple of drops and it is all messed up!! help mee!!
Posted on Sep 01, 2008
It happened to me too. Shame on me. I read in a book about normal cameras, that after having been dropped into salt water, they should be rinsed thouroughly with fresh water, cause the salt is it that does the damage. Maybe it is the same with suger etc. I rinsed my cam. .... It did not help though. Maybe worth a try before you dump it. And dont dump it anyways ... there are people searching for broken cams on ebay for parts. I got a little money for mine. Good luck
Posted on Aug 27, 2006
  • Jens Momme Aug 29, 2006
    Take out the batteries before getting the cam wet !!!
    Scholar:
  • 72 Answers
The problem with a liquid such as iced tea is it has all sorts of chemicals in it to preserve it make it taste better ect. But the components is the circuit of this camera are sometimes less than one millimeter apart and water and liquid are conductive and corrosive. The problem is the repair could get expesive if the damage is repairable. Then comes the other problem just how much damage did it do. You could fix one problem and a couple of months later the camera is back in the shop for another problem caused by the liquid but did not show up until another time. Costing you more money. New camera comes with warranty. But always before you toss take out battery let sit for day or so and try to see if it works. If it does you win, if it does not it was worth a try.
Posted on Aug 08, 2006
4 Suggested Answers
darntoothysa
  • 489 Answers
SOURCE: lens error restart camera but
Hi
Your lens is defective needs to be cleaned, repaired or replaced. If you got sand in the gears it will definitely jam up the lens! Sometimes you can tear down the lens and clean out the sand, and if none of the gears are damaged the lens will then work properly again.
There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know this because I OWN ONE that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help! Good luck from
Darntoothysam com
Thomas
Posted on Oct 10, 2008
  • 38 Answers
SOURCE: MacBook Pro won't recognize canon powershot SD400
Hello. You need to probably reinstall the drivers. but first you have to remove the drivers that are all ready installed. first unplug your usb cord. then to remove the drivers allready installed,, on your computer, press start, then when the box open's up, then right click on computer. another box will open up. then left click at the bottom of that box on properties. another box will open up, then click on device manager. after you click on device manager another box will open up with all your devices. look for the previous camera you had installed. it might be under imaging devices. once you locate that, then right click on it. then choose uninstall. Make sure you have your new software loaded in your cd/dvd rom drive. after it is done uninstalling, just restart your computer. at the bottom right of your screen, it should say, found new device, it will ask you from where do you want to load the new drivers for it. click on the drive that contains the software. it then will load your new drivers up. It then should communicate with your camera. Hope this helps. Ron
Posted on Sep 08, 2009
  • 11967 Answers
SOURCE: Won't take a picture and lens will not retrack
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 05, 2010
My slr nikon d1500 camera has stopped working i get the card out it was a little bit sticky i think there is something wet it maybe tea or soda ...it was in my bag my purse was sticky too...i tried to turn...
If it has been damaged by something you have done, then the warranty will not cover it, and repair will be expensive.
I am a little confused, anyway - I can find no reference to a Nikon D1500, and the image displayed and title of your posting is 'Canon PowerShot SD1400 IS IXUS'. Do you actually know which camera it is that you have ?
Sep 22, 2017 | Canon PowerShot SD1400 IS IXUS 130...
How do I unlock card on my canon sd400 camera
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Sep 04, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Powershot SD990 got wet will not turn on
If moisture got inside and you tried to turn it on, you probably shorted out the circuits.
Dec 26, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Delete photos
The Canon PowerShot SD400 has no internal memory. All pictures are recorded on a memory card.
Aug 27, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Liquid under screen on canon powershot
No, place it in a hot place instead to evaporate the liquid, cell phones in the ferezer is for clearing the memory chip, not drying it out.
Aug 06, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Won't Even Turn On
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Feb 16, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Powershot sd400 elph,got wet
If you tried turning the camera on while the electronics were still wet, it may be too late to offer any help.
Assuming you do this again, any piece of electronics that is immersed in water may begin to corrode immediately upon exposure to air, and if you don't want to take the chance of corrosion, you should take your camera to a professional repair depot.
Without disassembling the camera and drying out the pieces manually, there's nothing you can do except open every available crevice (lense, battery area, CF memory slot), remove the battery and memory card (which can then be dried CAREFULLY by hand), and hope that all pieces of the camera will eventually dry out (I'd leave it in a dry, warm environment for at least 3-4 days - longer if you can wait).
Nov 30, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Had camera in purse?!?!
you can buy a new screen and have that installed but it will be at least 60 bucks... check out ebay
Jul 29, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
229 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
